Pacific coast Datsun Posted March 26, 2008 Report Share Posted March 26, 2008 I need a L 16 exhaust manifold for my 521. The end of mine is warped & blowing out gaskets. I already tried the double gasket trick BTW :D The yards down here have been Datsun-less lately. Link to comment
DanielC Posted March 26, 2008 Report Share Posted March 26, 2008 Is it the pipe end of the manifold that is warped. I was able to pull the studs out of mine, and then get a new 12" mill file, and file it flat. No, it was not easy, and it did take a while, but it was cheaper and faster than taking it to a machine shop, dropping it off, returning in a few days after it was done, and picking it up. Link to comment
Pacific coast Datsun Posted March 26, 2008 Author Report Share Posted March 26, 2008 Ok to clarify, it's where the pipe connects, sorry. That sounds like an option & alot cheaper. A grinder can be used too as long as it's held flat against it. Another thing i want to do is replace the old ass studs & use grade 8 nuts & bolts w/ loctite, tired of them coming loose. TY DanielC Link to comment
]2eDeYe Posted March 26, 2008 Report Share Posted March 26, 2008 I re-threaded mine with helicoils and ran GR8 studs. Worked awesome, I was able to get the nuts nice and tight. Link to comment
Pacific coast Datsun Posted March 26, 2008 Author Report Share Posted March 26, 2008 Steve that rocks, i think mine r stripped too causing them to back out. Do you remember what the thread size was for the NEW bolts ? Link to comment
]2eDeYe Posted March 26, 2008 Report Share Posted March 26, 2008 I wanna say 8mm, but I can check the helicoil set when I get home. One of the old ones was broke off and the other threads were so rusty they could barely hold themselves in place :P Link to comment
mklotz70 Posted March 26, 2008 Report Share Posted March 26, 2008 If you or a buddy has a belt sander, it's flatter than the grinder and faster than a file :) Link to comment
DanielC Posted March 26, 2008 Report Share Posted March 26, 2008 The stock studs on an L-16 manifold are M8 x 1.25. I had to drill mine to get them out. If you ever work on a L-series Datsun engine, you need a M6 x 1 tap and die, a M8 x 1.25 tap and die, and a M10 x 1.5 tap and die. Link to comment
Pacific coast Datsun Posted March 26, 2008 Author Report Share Posted March 26, 2008 You guys rock. Wish i had a belt sander...:rolleyes: May have to drill mine out too, 1 of them snapped off the last time i tried to tighten it. Damm they just dont make 37 year old bolts like they used to...:D Link to comment
]2eDeYe Posted March 26, 2008 Report Share Posted March 26, 2008 Sure they do. There just brand new :D Link to comment
Farmer Posted March 27, 2008 Report Share Posted March 27, 2008 Pacific coast. I have a spare l16 Exhaust manifold. I bought it off ebay because it came with the Head pipe connection. Dont need the manifold. You can have it for free. Just pay for shipping. Its missing one of three studs. Larry Link to comment
Pacific coast Datsun Posted March 27, 2008 Author Report Share Posted March 27, 2008 Sweet! My zip code is91910, ill gladly pay shipping. Just let me know your zip & ill figure shipping. & thanks. Link to comment
Farmer Posted March 27, 2008 Report Share Posted March 27, 2008 97526. You got paypal? Larry Link to comment
datzenmike Posted March 27, 2008 Report Share Posted March 27, 2008 Loosen them after running motor when hot, or torch the flange beside it if worried about breaking them off. Replace with SS studs, nuts and lock washers, never rusts, stronger than stock, bolts ALWAYS come off no trouble even years later. Link to comment
Farmer Posted March 27, 2008 Report Share Posted March 27, 2008 It will be 16 dollars for shipping. Already got it packaged, measured and weighted. Ready to go. Larry Link to comment
Llittle_Llama Posted May 5, 2008 Report Share Posted May 5, 2008 he ever get it? if not i want it..... Link to comment
machowgn Posted May 7, 2008 Report Share Posted May 7, 2008 hello, Mike here in california, I think I might have a spare, call me at (408) 221-9550 . Link to comment
Llittle_Llama Posted May 9, 2008 Report Share Posted May 9, 2008 not trying to hijack your thread, but if you already got one i need one too, so who all has one!?! Link to comment
Gensaiken Posted May 9, 2008 Report Share Posted May 9, 2008 I have one but it has the tubes on the top for the smog stuff. Link to comment
J.C_620 Posted May 14, 2008 Report Share Posted May 14, 2008 i have one with perfect threads and brass bolts no smog crap i cant use it cause i do not have a downpipe if anybody needs it or can use it call me up 336-428-1176 i am located in north carolina Link to comment
