The 0069 dime
the510keeper
New Project Datsun heads, check it out.
This was Phils baby the last week he was here. He did the engine swap, breaks swap and gas tank swap.
Out with the engine
Purple stuff cleaner and scotch brightes, along with a pressure washer, cleaned out the cowl and all the drainage holes
Time for L20B / 5 speed Phil pulled out of Atom Church's wrecked 4 door.
New filler neck, and good gas tank, the old one was in unusable shape
Replaced the rear wheel cylinders, and rubber break lines, installed some rims and tires.
Front got coilovers and good working breaks and struts. The car had been sitting for awhile.
I used a clamp and then tac welded so it can not move. if some one wanted to they could grind off the weld and move it up or down
Then Victory gave the beast a bath
Stop staring
This is what the driveway looked like before the swapmeet
  • Replies 64
Sick wheels buddy! Those look like they came off a red 510 :D
You guessed it
On with it I say
Victory started cleaning floor, vaced up something dead, and a crap load of dirt.
Then washed it all down with simple green
I have better angles of this pic but for my nuts sake, I decided not to post them.
Scraped off the matting and found only small areas of light surface rust
Next step yank the seats and see what under the rubber mat up front
