datzenmike Posted August 22, 2019 Report Share Posted August 22, 2019 Got these bad boys today. 10th anniversary 280zx was scrapped recently. (is '81 the anniversary???because this has the decals but says 12/'81 build date and has the horizontal MC bolts) Engine in pieces in the back, transmission gone. There are old calipers in the back and these were likely new as the pads are really thick. Rotors are rust speckled but smooth and not grooved. Just need a wire wheel. It's not like I need them it just that I'm rescuing them from the crusher. Got the special mag lug nuts. And one of those old dealership cast pot metal license frames. This reminds me the rears are also disc brake. Need to go back and look, maybe they were replaced too. Quote Link to comment
datzenmike Posted August 25, 2019 Report Share Posted August 25, 2019 Brakes were replaced. There were two really rusty calipers in the trunk so these are the replacements. Look at how meaty the pads are. No grooves on the rotor and everything came apart easily and cleanly. The pads had small brass? coppery colored particles in the pad compound... Took one side apart and cleaned it, mostly surface rust and cobwebs. Quote Link to comment
datzenmike Posted August 28, 2019 Report Share Posted August 28, 2019 I scored a set of Maxima wagon struts years and years before I retired my truck and got a 710. Just couldn't stand to see them wasted. I'll clean and oil then both and store them. Quote Link to comment
ddrum Posted April 26, 2020 Report Share Posted April 26, 2020 Hello, so I recently did the whole 280zx suspension upgrade on my 510, and I sort of just aligned the tires more or less by looking at them. My camber on the other hand looks kind of bad. I do have the stock upper 510 strut mount with 510 stock spring and perch on the 280zx strut with bump steer spacers. How do you guys go about to fix the camber? Thank you, Erick Quote Link to comment
john510 Posted April 26, 2020 Report Share Posted April 26, 2020 What are you using for the lower spring perch ? Quote Link to comment
ddrum Posted April 27, 2020 Report Share Posted April 27, 2020 Hey John510, I'm using the stock 510 lower spring perch. Quote Link to comment
Datdadb210 Posted April 7, 2023 Report Share Posted April 7, 2023 On 8/8/2011 at 9:52 PM, qwik510 said: Yep. Like these: http://www.futofab.com/plugins/content/mavikthumbnails/thumbnails/350x135-images-stories-lca%20left%20side%20800%20pixels%20wide.jpg Where do I buy these Quote Link to comment
thisismatt Posted April 8, 2023 Report Share Posted April 8, 2023 1 hour ago, Datdadb210 said: Where do I buy these Probably from the site you quoted 😉 Quote Link to comment
iceman510 Posted April 10, 2023 Report Share Posted April 10, 2023 On 4/7/2023 at 6:58 PM, Datdadb210 said: Where do I buy these http://www.futofab.com/index.php?option=com_content&view=category&layout=blog&id=22&Itemid=22 Quote Link to comment
