]2eDeYe Posted October 7, 2008 Report Share Posted October 7, 2008 12lbs? Nice, extra flow must boost the pressure a bit. :cool: Still the same cold? Quote Link to comment
moparvwfreak Posted October 7, 2008 Author Report Share Posted October 7, 2008 i have been thinking bout your L-16 Phleb but gas to get teh 400+ miles round trip would not be cheap. but i will keep it in mind. i should run another pressure test on the oil system. last time i did one though my hot oil pressure was at about 20 PSI if memory served. i will also take a new filter ans cut the one on the truck open. i have a spare Ford one that i can put on. that will also give me just enough oil loss to run a bottle of Lucas through and hopefully calm things down. Quote Link to comment
datzenmike Posted October 7, 2008 Report Share Posted October 7, 2008 2eDeYe;86269']12lbs? Nice' date=' extra flow must boost the pressure a bit. :cool: Still the same cold?[/quote'] The max pressure is the same as the old about 55 when cold or revved up when hot. Cheap insurance and peace of mind. The hi volume pump is the one to have if you shim the spring too. Quote Link to comment
moparvwfreak Posted October 7, 2008 Author Report Share Posted October 7, 2008 last check when cold and reved mine was pushin 60 PSI. as said i will check it again though. Quote Link to comment
moparvwfreak Posted November 4, 2008 Author Report Share Posted November 4, 2008 i just scored some new rear wheels for the truck. i THINK they are 15x10s. the hub was too small to fit a 4x yota axle so i figured they would fit my datsun. if they do i am gonna have some MEAT in the rear fo my truck. damn i might need some badass flairs if they actually fit right. oh and talk about dish. uber sechsee!!!! Quote Link to comment
moparvwfreak Posted November 17, 2008 Author Report Share Posted November 17, 2008 i finally found some mud flaps for the truck today. one isn't perfect but it'll do for a daily. the other looks damn near perfect. i'll clean em up and see how they look. i also snagged some other little shit out at the yard. not much was saveable off the 620 though that was out there. kinda sad. :( OH does anyone know if the 4th switch will work as a reverse light switch? i have a good 4th switch but the reverse is bad. both mine and the one from the yard. Quote Link to comment
moparvwfreak Posted November 19, 2008 Author Report Share Posted November 19, 2008 i got some neat goodies from a buddy of mine. he sprung to get me some parts for the Datsun so i owe him bigtime. BUT on to the list of goodies.... all of which came off a 79 620. Weber carb with manifold and adapter plate Matchbox EI dizzy electric fuel pump adjustable FPR dual filter oil filter setup with bracket and adapter plate and last but not least..... factory radio blockoff plate. now to get the rebuild kit, some new nuts for the carb base, and mounting gaskets and i'll have a SWEET carb setup on my little L-16 :D Quote Link to comment
moparvwfreak Posted November 22, 2008 Author Report Share Posted November 22, 2008 OMFG!!!!!! i just put in the matchbox dizzy, an EASY upgrade, although i did run it through the points coil and resistor, it runs so much smoother! i also did a LONG overdue tune up and valve cover gasket. i drove her all over hells half acre today and she drove nice but liked to sputter and just be a royal PITA. now its nice and smooth. plus i added a QUART of GL to the trans. oops.....:unsure: oh well shes runnin like a top now. thank god. tomorrow i get the gaskets for the Weber and can get that installed as well. :) Quote Link to comment
Cuts metal like mad Posted November 22, 2008 Report Share Posted November 22, 2008 Trade you an EI coil for your old carb! :D Quote Link to comment
Llittle_Llama Posted November 22, 2008 Report Share Posted November 22, 2008 where is that motor auction post? i cannot find it, lol. link please? Quote Link to comment
moparvwfreak Posted November 22, 2008 Author Report Share Posted November 22, 2008 Trade you an EI coil for your old carb! :D which one ya want? i have 2 hitachis sitting here. actually i am gonna rebuild the one on the truck so my spare is up for grabs if ya want it. Quote Link to comment
Cuts metal like mad Posted November 22, 2008 Report Share Posted November 22, 2008 A working one preferably, got 3 non working ones now... :lol: Quote Link to comment
moparvwfreak Posted November 22, 2008 Author Report Share Posted November 22, 2008 dunno if it works. i know the one on my truck is not the best. and the spare i got with it and have no idea if it works. Quote Link to comment
moparvwfreak Posted December 5, 2008 Author Report Share Posted December 5, 2008 well update time. i got the weber working but its in need of more repair. the main throttle shaft bushings are DONE. but what ever. i need the truck to run. the other day the throttle kept sticking on me. so tonight i adjusted the order of the peices for the throttle lever and bent my cable bracket to wline up properly. i also added another spring to the mix and now it seems to work beautifully. idles at 850 RPM give or take 50 RPM, and seems to get GREAT mileage, i'll know saturday how well it actually is. also i amy ahve figured out HOW to wire in those "euro" tail lights off ebay. if someone has a 620 tail light i can get a pic of? with the wiring and connectors? the only spare i have i clipped the ends off to wire into mine. Quote Link to comment
]2eDeYe Posted December 5, 2008 Report Share Posted December 5, 2008 I'll see if I can dig mine out. Get rid of that resistor and your truck will run even better ;) Quote Link to comment
moparvwfreak Posted December 8, 2008 Author Report Share Posted December 8, 2008 well i found out in roughly 200 miles it eats through a tank of gas with the weber. roughly 20mpg. that sucks ass!!!! but i have a nasty fealing my little L16 isn't going to last much longer. she started knockin a little louder on my way back from tdaaj's place on saturday. i wish i had been there sooner and may be picked up a good motor but oh well. thats life. i also have a feeling the carb is screwed up. i think the main throttle shaft bushings are gone. i really DONT want to have to put my old craptastic Hitachi back on but if i have to i will. i am thinking for now though an oil change with straight 30w will help and a bottle of Lucas. i jsut need the truck to last me till i get my jetta going again then i can start gutting it for repairs. my plans for the truck ahve changed a bit since i got it. i will NOT be running my wagon wheels but a set of chrome steel slotted mags, Empi mirrors (already installed), a subaru justy rear veiw mirror, a modded center console with CD player (if it will fit after cutting it up), still want a 5spd but i REALLY need one that will bolt in place of my short tail 4spd, 74+ front clip, L18 or L20b (whichever i can find for cheap or free), full flairs and front spoiler (yes they will be Steroids peices), new floor pans and a full repaint. since i have a core support sitting i might have to see if i can install a set of fog lights behind the grille. if not then i really need to find a place to mount them. its hard enough seeing with the moon beams we call headlights. and the fog its even worse. Quote Link to comment
moparvwfreak Posted December 9, 2008 Author Report Share Posted December 9, 2008 i lost the clutch today and the trans is leaking BAD. its definatley transmission time. this sucks ass. i need wheels quickly so my halfassed caddy is gonna be hitting the road hopefuly tomorrow. shift linkage rebuild AGAIN. what fun. Quote Link to comment
moparvwfreak Posted January 22, 2009 Author Report Share Posted January 22, 2009 i jsut ordered my clutch today. total cost of $89. my wife got a bigger check than expected so..... my datsun should be on the road soon. YAY!!!!! now i just need to get teh input shaft seal, my new clutch slave and i think we will be in business! hell im ight even ahve a nice warm shop to work on it in, if i get dude cabriolet running right between today and tomorrow. Quote Link to comment
lynchfourtwenty Posted January 22, 2009 Report Share Posted January 22, 2009 what clutch did u get?? Quote Link to comment
moparvwfreak Posted January 22, 2009 Author Report Share Posted January 22, 2009 what clutch did u get?? just an OE replacement. its not gonna be a hotrod so OE type will work. got it from IRP (import replacement parts) so hopefully it will be good. Quote Link to comment
lynchfourtwenty Posted January 23, 2009 Report Share Posted January 23, 2009 my exedy oe replacement was about the same price shipped, so far im pretty happy with it Quote Link to comment
moparvwfreak Posted January 24, 2009 Author Report Share Posted January 24, 2009 my exedy oe replacement was about the same price shipped, so far im pretty happy with it thats teh one i got. with a new pilot bearing and alignment tool. made in japan parts are ALWAYS a good thing. Quote Link to comment
lynchfourtwenty Posted January 24, 2009 Report Share Posted January 24, 2009 its a daikin right? http://forum.ratsun.net/showthread.php?t=6574&highlight=yay+clutch im sure u remember this thread.. i think you'll be happy with it Quote Link to comment
moparvwfreak Posted January 24, 2009 Author Report Share Posted January 24, 2009 yup. thats almost exactly like mine. but my PP has more "fingers" i think. shouldn't take me more than a few hours to install it either. but this will be #1 trans of 3 i have to pull this week. after mine i have 2 others, in rabbits, i have to pull and do clutch repairs on. Quote Link to comment
moparvwfreak Posted February 15, 2009 Author Report Share Posted February 15, 2009 got my new( read used) wheels installed. and damn they look good! Quote Link to comment
