moparvwfreak Posted May 15, 2010 Author Report Share Posted May 15, 2010 2eDeYe' date='14 May 2010 - 02:50 PM' timestamp='1273873828' post='303222']Who does this? I wouldn't mind getting soem red :) Heck yeah - I'm thinking that OEM avacado would be very cool on mine. Westco auto body supply can mix em. That's where I got my paint for the mercury. Quote Link to comment
moparvwfreak Posted May 16, 2010 Author Report Share Posted May 16, 2010 done but no pics till tomorrow. ;) :P Quote Link to comment
moparvwfreak Posted November 2, 2010 Author Report Share Posted November 2, 2010 sorry forgot to post the pics. well i have been having a BIG issue with this thing running at night so i swapped in a new alt (stock replacement), and went to change out my cheesy pos batt cable. well snapped the lug off the starter, so i swapped the starter out as well... now the battery is dead... gotta jump it with the caprice which i broke today hence why i am working on this bucket of shit in the rain. what fun...... hopefully though my alt was just shot. Quote Link to comment
]2eDeYe Posted November 2, 2010 Report Share Posted November 2, 2010 When it rains it pours :unsure: Quote Link to comment
moparvwfreak Posted November 4, 2010 Author Report Share Posted November 4, 2010 oh you dont even know.... so yesterday i took it into work. on my FIRST run, charge light came on. had it tested, alts putting out 12.5v.... great, so not only did the alt fry, or the regulator, or both, the starter out of my 78 is shot too. takes forever to get it to actually urn over. can i burn it now???? Quote Link to comment
]2eDeYe Posted November 5, 2010 Report Share Posted November 5, 2010 You should do the Saturn swap...so simple. So RELIABLE. ;) Quote Link to comment
moparvwfreak Posted November 5, 2010 Author Report Share Posted November 5, 2010 need $$ to do that..... $390~ish check and $800 needs to go out.... i am hoping to pick up parts for the Passat saturday so i have at least one OTHER running car.... Quote Link to comment
]2eDeYe Posted November 5, 2010 Report Share Posted November 5, 2010 I'll check my parts stash this weekend. Quote Link to comment
moparvwfreak Posted November 7, 2010 Author Report Share Posted November 7, 2010 that would be awesome! i REALLY need a starter though. i am still looking for the alt off the 78. so hopefully that will be good. doubt it but who knows. Quote Link to comment
]2eDeYe Posted November 7, 2010 Report Share Posted November 7, 2010 I have a spare starter. No spare alt though. Quote Link to comment
moparvwfreak Posted November 7, 2010 Author Report Share Posted November 7, 2010 what ya want for it??? i can always figure the alt issue but my spare starter was craptastic. Quote Link to comment
]2eDeYe Posted November 8, 2010 Report Share Posted November 8, 2010 Come n get it :P Spend your $ at PAP for a Saturn salt...$15 there. Quote Link to comment
moparvwfreak Posted November 9, 2010 Author Report Share Posted November 9, 2010 if i had $15 to spare i would go up to pap and get one. Quote Link to comment
]2eDeYe Posted November 9, 2010 Report Share Posted November 9, 2010 Come get the starter anyways lol Quote Link to comment
moparvwfreak Posted November 9, 2010 Author Report Share Posted November 9, 2010 when? i have today and tomorrow off Quote Link to comment
]2eDeYe Posted November 9, 2010 Report Share Posted November 9, 2010 I should be around today...home around 530-6 Quote Link to comment
moparvwfreak Posted November 9, 2010 Author Report Share Posted November 9, 2010 Sweet! I can do that. And ya can see the Jeep. Quote Link to comment
moparvwfreak Posted November 12, 2010 Author Report Share Posted November 12, 2010 YES!!!!! it runs! still have to do the saturn swap but i found an 81 ZX turbo with a good alt. so i swapped that in for now. so that is in and seems to do ok with the exception of when i hit the turns the chg light comes on about 1\2 brightness. and flashes with the signals. lights dim a LITTLE but no where near as bad as before. barely noticeable. and its not cutting out my ignition. hopefully it was just a matter of a loose clamp leaking coolant onto the alt. once dry, hopefully it will work better. Quote Link to comment
moparvwfreak Posted November 13, 2010 Author Report Share Posted November 13, 2010 Running like a swiss watch. Even sounds like one! So far 4 deliveries and no issues Quote Link to comment
]2eDeYe Posted November 13, 2010 Report Share Posted November 13, 2010 :thumbup: Quote Link to comment
moparvwfreak Posted November 13, 2010 Author Report Share Posted November 13, 2010 all night, headlight AND fogs on with heat and no problems at all. but i think i have a bad ground for the cluster. Quote Link to comment
moparvwfreak Posted November 14, 2010 Author Report Share Posted November 14, 2010 spent the last hour or so building a relay harness for my truck. its not pretty as i made some of the wires too long but it works. 13.7v at teh HL at IDLE!!!! also installed my H4s again. now it WILL be daylight as i drive. oh and so far 3 days no issues at all. and the system is my usual redundancy system. if i loose a relay i can go back to stock wiring just by swapping the plugs. i used the OE plug as the switch so i got backup. Quote Link to comment
moparvwfreak Posted July 10, 2011 Author Report Share Posted July 10, 2011 well i lost the brakes in december. i was able to get most of the parts but i am still in need of a few. the brake lines are trashed, want to go braded BUT i also want to swap to disk eventually so i will most likely go with rubber for now. we'll see what happens. i also need to come up with new studs as i trashed mine while pulling my drums. a sledge works wonders for that. i replaced the RF wheel cylinder, which by the way is a weird setup, when i found a trashed brke line. kinda sucks when your broke. Quote Link to comment
moparvwfreak Posted August 5, 2011 Author Report Share Posted August 5, 2011 well i got it up in the air after finding the drivers REAR brake was locked up. everything seemed ok so i took it apart and lubed it. the a shoe came apart on me. what fun. now time to redo the REAR brakes so i can drive the damn thing. if its not one thing its half a dozen others. Quote Link to comment
moparvwfreak Posted August 13, 2011 Author Report Share Posted August 13, 2011 so got new shoes for the rear, got it all abck together, and was missing springs. new hardware kit to the rescue..... can i had disk brakes yet???? oh yeah, broke from fixing BRAKES.... yay................ :( :( Quote Link to comment
