DAT510 Posted August 16, 2011 Author Report Share Posted August 16, 2011 ALRIGHT! got my tranny! i'm going to drop the engine in on sunday! i can finally start piecing this car together! so excited Quote Link to comment
DAT510 Posted September 4, 2011 Author Report Share Posted September 4, 2011 its amazing how easy something is with the right tools. Yes, i am going to be running a auto tranny. Quote Link to comment
bonvo Posted September 4, 2011 Report Share Posted September 4, 2011 why are you going auto? Quote Link to comment
DAT510 Posted September 5, 2011 Author Report Share Posted September 5, 2011 why are you going auto? i haven't got a 5 speed tranny. i figured i'd swallow my pride and get this car finished rather that watching it sit. im going to collect all the parts while i'm driving it. Quote Link to comment
DAT510 Posted September 5, 2011 Author Report Share Posted September 5, 2011 going off topic... but i think its well worth it, once somebody guess close i'll give another clue? Quote Link to comment
johny5 Posted September 5, 2011 Report Share Posted September 5, 2011 turbo 4.3 ? Quote Link to comment
DAT510 Posted September 5, 2011 Author Report Share Posted September 5, 2011 Yeah, but i kinda fail cause it says Syclone there.... but i got a Typhoon Quote Link to comment
DAT510 Posted September 5, 2011 Author Report Share Posted September 5, 2011 I'm in! im such a tight fit! 1 Quote Link to comment
bananahamuck Posted September 5, 2011 Report Share Posted September 5, 2011 i haven't got a 5 speed tranny. i figured i'd swallow my pride and get this car finished rather that watching it sit. im going to collect all the parts while i'm driving it. This statement shows that your car is in very good hands..... Quote Link to comment
DAT510 Posted September 5, 2011 Author Report Share Posted September 5, 2011 This statement shows that your car is in very good hands..... My car is a part of me, if it dies i die with it. :P Quote Link to comment
DAT510 Posted September 8, 2011 Author Report Share Posted September 8, 2011 Since i'm ALMOST done with my car, i think i should have list of my goals and cross them off as i go. i think the toughest thing im going to have to do right now is put the gas tank in without cracking that plastic piece. Note that i include long term goals i intend to do within 2 years 1. Moar lower 2. Carpet + interior 3. Convert to stick 4. get a good sound system without cutting holes or annihilating the interior, NO 15 inch subs for me, ok maybe one lol 5. Rebuild L16 bore to L18, and Turbo + EFI (Yes, i have the block) i'll add more goals as they come. right now i have a basic understanding of what to do with the engine to make it L18ET Oh and the L20b BARELY cleared the hood like maybe a eighth of an inch Quote Link to comment
datsunfreak Posted September 9, 2011 Report Share Posted September 9, 2011 i'll add more goals as they come. right now i have a basic understanding of what to do with the engine to make it L18ET Oh and the L20b BARELY cleared the hood like maybe a eighth of an inch Did you put a 510 oil pan on it before installing it? That (and occasionally slotting the engine bracket mounting holes) is usually what you need to get it lower. ;) Quote Link to comment
DAT510 Posted September 10, 2011 Author Report Share Posted September 10, 2011 Did you put a 510 oil pan on it before installing it? That (and occasionally slotting the engine bracket mounting holes) is usually what you need to get it lower. yeah i switched the oilpan, but i didnt have to slot the bracket holes at all, the carbs air cleaner even clears! Yeah!!! Quote Link to comment
DAT510 Posted September 18, 2011 Author Report Share Posted September 18, 2011 bump im sure some of the wires on the bottom of the tranny are for the back up lights,but which one is which? and does it matter which wire they connect too? as you can see the wires are connected to the same colors 1 Quote Link to comment
DAT510 Posted September 18, 2011 Author Report Share Posted September 18, 2011 light bulb that lights up P N D 1 2 broke Quote Link to comment
DAT510 Posted September 22, 2011 Author Report Share Posted September 22, 2011 :cool: Quote Link to comment
DAT510 Posted September 24, 2011 Author Report Share Posted September 24, 2011 This week has been my worst so far. Quote Link to comment
banzai510(hainz) Posted September 24, 2011 Report Share Posted September 24, 2011 this thing run yet? If you have point distributor I dont see a Ballast resistor dor the POINT coil. If you have a Matchbox then make sure you have a EI coil. I dont see the PVC hose hooked up to the crankcase also the other hole below carb needs to be plugged. Fuel pump is from a 620 which will work but the 510 ones have the inlet /outlet in the correct spot. to make it a cleaner run from the corner by the lights to the inlet of fuel pump. Quote Link to comment
DAT510 Posted September 24, 2011 Author Report Share Posted September 24, 2011 this thing run yet? If you have point distributor I dont see a Ballast resistor dor the POINT coil. If you have a Matchbox then make sure you have a EI coil. I dont see the PVC hose hooked up to the crankcase also the other hole below carb needs to be plugged. Fuel pump is from a 620 which will work but the 510 ones have the inlet /outlet in the correct spot. to make it a cleaner run from the corner by the lights to the inlet of fuel pump. not yet i have the ballast resistor just haven't put it on i cut the L20B tube and just need to get a hose for the the hole you mean the only other one on the manifold besides the PCV valve? yeah i was meaning to switch the fuel pumps out. i might as well get a new one though Quote Link to comment
DAT510 Posted September 27, 2011 Author Report Share Posted September 27, 2011 uh Houston... im not sure about the following.. bunch of wires that are supposed to go to ballast, dizzy, and coil and also that dizzy pic is of what i think is supposed to be TDC and those tubes on the intake, i know the one pointing to the firewall is PCV, and the rest idk lol Quote Link to comment
jalen Posted September 27, 2011 Report Share Posted September 27, 2011 that hose goes to that do hicky and that dohicky connects to that and BAM! it works <---- only if it were that simple Quote Link to comment
DAT510 Posted September 27, 2011 Author Report Share Posted September 27, 2011 that hose goes to that do hicky and that dohicky connects to that and BAM! it works <---- only if it were that simple lol dont we all. i lost my Haynes manual, so im lost for a couple weeks Quote Link to comment
jalen Posted September 27, 2011 Report Share Posted September 27, 2011 haynes manual? whats that haha...have you checked the 510 realm? Quote Link to comment
