DAT510 Posted September 27, 2011 Author Report Share Posted September 27, 2011 haynes manual? whats that haha...have you checked the 510 realm? doooooooooooooood Quote Link to comment
DAT510 Posted September 28, 2011 Author Report Share Posted September 28, 2011 I NEED WIRING HELP! ok so think i got most of the wiring black white goes to one side of ballast resistor, then green goes to positive side of coil, yellow goes to the brakes, black and red goes to the base of the dizzy but i dont know where a plain black wire goes.. and the wire that goes from ballast to coil and i think thats it Quote Link to comment
DAT510 Posted October 5, 2011 Author Report Share Posted October 5, 2011 No real progress today. I found more problems i have to address before even starting up. putting the thermostat on today i realized that the thread closest to the front of the car is stripped. cool. the fuel line is also too long for the Weber location so i have to bend some tubing. took off the steering wheel today after ripping the foam piece off. wasn't too happy about that. oh and put the radiator on i did more work on my G20 in hour than i did on my Dime in a day. waiting sucks. Quote Link to comment
DAT510 Posted October 15, 2011 Author Report Share Posted October 15, 2011 Hey guys sorry i haven't updated in a while, i almost got this thing started the dizzy wasn't firing so i have to figure that out. but i got a 84 turbo 300zx that i'm using for parts, what else can i use from it? i got the Tranny, diff and rear spoiler. :) i've been cleaning up my dads Z, and learning body work from this guy lately. im back to school Monday from my two week break so i wont be having too much time to work.. fuck too many things get in the way. look at this beautiful hood Quote Link to comment
mike Posted October 16, 2011 Report Share Posted October 16, 2011 Z's are cool buuttt... Get back to work on the dime :lol: For that hole that is stripped on your thermostat housing... If it is the one that is the farthest forward hole that holds the t-stat housing to the block there is a semi easy fix. Ive noticed that a lot of these are stripped by people running too long of a bolt into the timing chain and stripping the threads before the t-stat is secure/tight. You will need a bolt about 3/8" longer than the original that was used to bolt the t-stat to the head, a lockwasher and a nut. (The bolts that are used to secure the cam towers on a z20/22/24 just so happen to be the perfect length) Secure your timing chain with a block or rubber hose and pull your cam gear and move the chain out of the way. Put the bolt in from the inside of the head so the threads are going out to the t-stat... its basically a stud now that isnt threaded into the head and just rotates semi freely. Put your timing gear and chain back on and tighten it down. remove whatever it was you used to hold the chain in place. Attach your thermostat and use a box end wrench to hold the bolthead from inside the engine when tightening the nut on the outside of the t-stat. Install rocker cover and fill with fluid... done :) Shouldnt take you more than 1/2 hour if youve got the tools and hardware. Quote Link to comment
DAT510 Posted October 16, 2011 Author Report Share Posted October 16, 2011 Z's are cool buuttt... Get back to work on the dime :lol: For that hole that is stripped on your thermostat housing... If it is the one that is the farthest forward hole that holds the t-stat housing to the block there is a semi easy fix. Ive noticed that a lot of these are stripped by people running too long of a bolt into the timing chain and stripping the threads before the t-stat is secure/tight. You will need a bolt about 3/8" longer than the original that was used to bolt the t-stat to the head, a lockwasher and a nut. (The bolts that are used to secure the cam towers on a z20/22/24 just so happen to be the perfect length) Secure your timing chain with a block or rubber hose and pull your cam gear and move the chain out of the way. Put the bolt in from the inside of the head so the threads are going out to the t-stat... its basically a stud now that isnt threaded into the head and just rotates semi freely. Put your timing gear and chain back on and tighten it down. remove whatever it was you used to hold the chain in place. Attach your thermostat and use a box end wrench to hold the bolthead from inside the engine when tightening the nut on the outside of the t-stat. Install rocker cover and fill with fluid... done :) Shouldnt take you more than 1/2 hour if youve got the tools and hardware. Why didn't i think of that! i already tapped it though, one bolt size bigger. if this fails, i'm definitely doing this, ill weld a nut to one side of the stud though Quote Link to comment
DAT510 Posted November 12, 2011 Author Report Share Posted November 12, 2011 My dad painted his Z!!!!! it's like a Ford Fiesta color <_<, but it looks good Quote Link to comment
Skib Posted November 12, 2011 Report Share Posted November 12, 2011 My dad painted his Z!!!!! it's like a Ford Fiesta color <_<, but it looks good thats the same green I was going to paint my Z. its the 07-ish fiesta/mustang/focous green Quote Link to comment
Laecaon Posted November 12, 2011 Report Share Posted November 12, 2011 I want that color on a 521. Roof painted white. Well the color in the picture, it looks darker there than in real life... Quote Link to comment
DAT510 Posted November 12, 2011 Author Report Share Posted November 12, 2011 thats the same green I was going to paint my Z. its the 07-ish fiesta/mustang/focous green I'll take better oics when i see it. Idk at first i was like green is shitty, but it's growing on me. He was originally going to paint it Metallic Blue... He surprised me. Ollz, wouldn't be surprised if he buys a RB26 next Quote Link to comment
jalen Posted November 12, 2011 Report Share Posted November 12, 2011 all these updates but none on the 510? :( Quote Link to comment
DAT510 Posted November 12, 2011 Author Report Share Posted November 12, 2011 Too be very honest, i depended on my parents to give me rides to the auto parts store to get the last bit of shit i need to get this damn thing running. well that and i had no money. I just got my license on Wednesday, and my mom is trying to pull some shit to not let me drive by myself (Very overprotective... i think). Tomorrow i'm planning on heading over to Autozone to pick up some 5/16in tubing and 2 1/4in gas tank........................Rubber piece. (words escaping me, very tired...) Everyday I think about this car. even if its Autotragic, all i want to do is drive this thing. I've been in a bad mood every day i don't get this thing running, lets hope tomorrow i get to fire up. Quote Link to comment
DAT510 Posted November 13, 2011 Author Report Share Posted November 13, 2011 Made make shift fuel line... Applied sticker YO!! My stickers match! Lastly, i want to check if these wires are correct... I doubt they are. Quote Link to comment
Laecaon Posted November 13, 2011 Report Share Posted November 13, 2011 Wiring looks fine to me... BG and B/Blue are technically reversed but it doesnt matter. Quote Link to comment
DAT510 Posted November 13, 2011 Author Report Share Posted November 13, 2011 Alright thanks, now i'll hook up the Alt and try to start her up tomorrow! Quote Link to comment
DAT510 Posted November 14, 2011 Author Report Share Posted November 14, 2011 (edited) Do you guys have any pointers on how to install the metal piece that goes in between gas tank and fuel tank filler? I'm having trouble connecting it to the rubber piece that is uber hard to find... no oics right now.. ill try to find some on the web. Lol guess not Edited November 14, 2011 by DAT510 Quote Link to comment
DAT510 Posted December 4, 2011 Author Report Share Posted December 4, 2011 ultra shitty oics.. Bought the 200sx, K5 Blazer (dad) and the 240z behind it! Found my 4 speed tranny!!! :hyper: Can't i use some things off the 200sx? brakes? struts? it haz 8 plug dizzy, i can't use that can i? Quote Link to comment
DISLEXICDIME Posted December 5, 2011 Report Share Posted December 5, 2011 is it fuel injected? Quote Link to comment
DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 Yeah Quote Link to comment
datzenmike Posted December 6, 2011 Report Share Posted December 6, 2011 What year S110??? '81-'83 had the 8 plug heads but the '82-'83 had the Z22 motor. All had rear disc brakes. Quote Link to comment
DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 8/81, so 82 but 81 model year. it has a 8 plug Z22E Quote Link to comment
DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 I think this might be my Z Quote Link to comment
datzenmike Posted December 6, 2011 Report Share Posted December 6, 2011 Nice! The '82 and '83 also switched to the H-190 diff from the H-165-B so hang on to that as it will swap right onto a 210... should anyone decide to put a KA in it. Automatic? Quote Link to comment
DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 The more i look at it, the more i wanna keep it and slam it. mmmmmmm it's growing on me.... The S110 yeah, Z nice and tight 4 speed tranny... i love tight trannies Quote Link to comment
datzenmike Posted December 6, 2011 Report Share Posted December 6, 2011 Automatic? Is the 200sx an auto?? Looks like 3.70 rear end hard to see. Quote Link to comment
