DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 Is the 200sx an auto?? Looks like 3.70 rear end hard to see. Yes Quote Link to comment
Guest 510kamikazifreak Posted December 6, 2011 Report Share Posted December 6, 2011 My wife has a 2hundy she loves it :lol: myself :unsure: :lol: Quote Link to comment
Laecaon Posted December 6, 2011 Report Share Posted December 6, 2011 I like those 200sx's! Quote Link to comment
DAT510 Posted December 6, 2011 Author Report Share Posted December 6, 2011 I'm thinking slammed, Diamond racing wheels, KA24DE, 5 speed ohhhh yeaahhhhh Quote Link to comment
DAT510 Posted December 13, 2011 Author Report Share Posted December 13, 2011 Ok so i need to start this thing, it turns over fine, spark is kinda weak though. tried starting all the way advanced, still no combustion. not sure enough fuel is getting to cylinders. brand new DGEV Weber carb. Help? i'm gonna pick up some NGKs later any suggestions? I'm dead set on copper ones, i'll get iridium ones later. Oh i should mention the choke solenoid isn't hooked up, i still have to crimp on the terminal. and also one more thing, My dad says something needs to be connected next to the fusebox, i don't remember anything being plugged. Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 Bumpeth Quote Link to comment
TENDRIL Posted December 14, 2011 Report Share Posted December 14, 2011 on my l20 in my goon i was foolin around with the dash and i tried to start it, turned over but nothing i disconnected the tachomeotor i found out... put it back together and bam started right away... dont know how your tryin to start it but if your sure your getting spark im not to sure... looking at the oics makesure you have fuel in your fuel filter, and there isnt any leaks on the way to the carb because the fule pump should be building pressure to the float in the carb i believe do you know if your carb came factory adjusted maybe the jets are closed?.. Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 I poured gas down the carb lol. the spark is orangeish and weak. it has dual points, and i'm certain i wired it right. ill try advancing the shit out of it. anything i can gauge the spark with? Quote Link to comment
Laecaon Posted December 14, 2011 Report Share Posted December 14, 2011 Sure your jetting is good? Or close enough? Is it cold? If yes, you probably need that choke... Spark plugs, I have always gotten the cheapy NGK's, $1.25 a piece last time I bought them. But you must gap them!!! Make sure your dizzy isnt 180 degrees out, if it is simply swap the wires at the dizzy. Quote Link to comment
TENDRIL Posted December 14, 2011 Report Share Posted December 14, 2011 also little bit of starter fluid goes along way if thers any spark it should fire and you should start to get an idea of where your dizzy needs to be Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 Meh 50ish degrees.... lol yeah choke is good idea. I never messed with the jetting......infact i just bolted the carb to the intake and called it good. I forgot about tuning it Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 Is there a sure fire way of seeing if fuel is getting to the cylinders? maybe take a off a spark plug and see the fuel spray shoot out on compression stroke? if of course there is any fuel. I replaced the fuel filter and i know the fuel pump is working because there was a tiny leak on because i didn't clamp a fuel hose tight enough. Quote Link to comment
TENDRIL Posted December 14, 2011 Report Share Posted December 14, 2011 hmmm :poke: push the throttle down and see if theres any gas coming out of the jets Quote Link to comment
Laecaon Posted December 14, 2011 Report Share Posted December 14, 2011 hmmm :poke: push the throttle down and see if theres any gas coming out of the jets off you can see fuel out of the accelerator nozzle by moving the throttle. What color are your plugs? If they are black at all you probably have fuel going in. But again, make sure your dizzy is not 180 degrees out. Or in that matter, check to see if you have the correct firing order at all. Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 The plugs are sooty, like black. they're old like when the engine was running 3 years ago that's why i need to replace them. firing order is 1342 correct? i put #1 piston on TDC, saw where the put the rotor in relation to cap and made that #1. it's also 1342 counter clockwise. Quote Link to comment
Laecaon Posted December 14, 2011 Report Share Posted December 14, 2011 The plugs are sooty, like black. they're old like when the engine was running 3 years ago that's why i need to replace them. firing order is 1342 correct? i put #1 piston on TDC, saw where the put the rotor in relation to cap and made that #1. it's also 1342 counter clockwise. You say TDC... I say it could have been BDC... Did you just go by the mark on the pulley? Or did you pull your valve cover off and see the cam lobes in the proper location. The crank spins 2 revolutions every time the cam spins once. Quote Link to comment
I'm BLUE Posted December 14, 2011 Report Share Posted December 14, 2011 On my phone typing slow ... New weber dgev ... Bolted on ... Weak spark ... Not sure of fuel getting to cylinders ... Was engine running before ? If so how well ? If accelerator pump is working and discharging ... 1 pump to the floor should catch it ... If you have points and condensor.... Replace condensor and points or regap...check all ignition related compenents and clean them ... Fuel pumps can fail from just sitting ... They can also barely work ... Errrrr Any other relevant important history ? Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 You say TDC... I say it could have been BDC... Did you just go by the mark on the pulley? Or did you pull your valve cover off and see the cam lobes in the proper location. The crank spins 2 revolutions every time the cam spins once. Took off spark plug on #1 and stuck my finger in there while my dad cranked it......no just kidding, i spun the crank by hand then with my finger in there felt the piston be TDC. On my phone typing slow ... New weber dgev ... Bolted on ... Weak spark ... Not sure of fuel getting to cylinders ... Was engine running before ? If so how well ? If accelerator pump is working and discharging ... 1 pump to the floor should catch it ... If you have points and condensor.... Replace condensor and points or regap...check all ignition related compenents and clean them ... Fuel pumps can fail from just sitting ... They can also barely work ... Errrrr Any other relevant important history ? It was in my uncles 620 and he used it to get to work two blocks away. it ran great Quote Link to comment
Laecaon Posted December 14, 2011 Report Share Posted December 14, 2011 Took off spark plug on #1 and stuck my finger in there while my dad cranked it......no just kidding, i spun the crank by hand then with my finger in there felt the piston be TDC. THAT COULD STILL BE BDC!!! You have to see the cam. The piston goes to the top twice in a 4 stroke motor... Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 THAT COULD STILL BE BDC!!! You have to see the cam. The piston goes to the top twice in a 4 stroke motor... thinking about it more.....you're right. i thought the rotor on the dizzy spindle would be anywhere else but #1 on the exhaust stroke.... i will report back tomorrow Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 say the piston is at BDC, the rotor lines up to #1 on the cap, and ignition timing is spot on, would that mean that my dizzy is 180? thus #4 being #1? Quote Link to comment
Laecaon Posted December 14, 2011 Report Share Posted December 14, 2011 say the piston is at BDC, the rotor lines up to #1 on the cap, and ignition timing is spot on, would that mean that my dizzy is 180? thus #4 being #1? yes. Quote Link to comment
DAT510 Posted December 14, 2011 Author Report Share Posted December 14, 2011 I understand the universe noaw! :D Thangu Quote Link to comment
DAT510 Posted December 21, 2011 Author Report Share Posted December 21, 2011 :rolleyes: Quote Link to comment
DAT510 Posted December 21, 2011 Author Report Share Posted December 21, 2011 I also got my 240SX running, just needed a new battery, after sitting for 4 years, it fired right up first try Quote Link to comment
