nismo dr Posted February 19, 2011 Report Share Posted February 19, 2011 I chuckle every time I hear someone complaining about having to do a head gasket or timing chain on a L motor, thought I'd show you a head gasket job on 2009 Murano. once you get the cowl and all the plastic covers off - you can see that, yes, there is an engine in there let me get this piece of metal out of the way Quote Link to comment
nismo dr Posted February 19, 2011 Author Report Share Posted February 19, 2011 just a couple more bolts Quote Link to comment
Jassifrass Posted February 19, 2011 Report Share Posted February 19, 2011 looks like a big ol stinky pile of fun Quote Link to comment
nismo dr Posted February 19, 2011 Author Report Share Posted February 19, 2011 normally I'd be flat rating it and not even think about taking pics, but my parts won't be here till tuesday, so I went very leisurely at it Quote Link to comment
izzo Posted February 19, 2011 Report Share Posted February 19, 2011 09 and already blew a head gasket eh? Worse then the Z24 :\ Quote Link to comment
FoxyRoadster Posted February 19, 2011 Report Share Posted February 19, 2011 that is exactly why I like old cars! Quote Link to comment
Burabuda Posted February 19, 2011 Report Share Posted February 19, 2011 warranty work is my guess? otherwise the thing would be salvaged :lol: Quote Link to comment
ariascarlos1990 Posted February 19, 2011 Report Share Posted February 19, 2011 eff all that. Quote Link to comment
jefe de jefes Posted February 19, 2011 Report Share Posted February 19, 2011 Ouch Quote Link to comment
nismo dr Posted February 19, 2011 Author Report Share Posted February 19, 2011 09 and already blew a head gasket eh? Worse then the Z24 :\ not blown per se, external coolant leak very common on 09-10 Murano, doing a ton of them, so are my friends at beaverton and rustom Quote Link to comment
ggzilla Posted February 19, 2011 Report Share Posted February 19, 2011 My 1972 has never had the head gasket changed, do I need to do it now before it becomes unreliable? I'ts my daily driver so I don't wanna get stranded. Quote Link to comment
FoxyRoadster Posted February 19, 2011 Report Share Posted February 19, 2011 My 1972 has never had the head gasket changed, do I need to do it now before it becomes unreliable? I'ts my daily driver so I don't wanna get stranded. If you are worried about it I'd follow the nissan's maintenance guide, they have a marked down suggested mileage for most replacement and checks. Quote Link to comment
ggzilla Posted February 19, 2011 Report Share Posted February 19, 2011 The guide is in my owner's manual,but it doesn't give a schedule for replacing the head gasket. I see that the newer Nissans are not neccesarily more reliable... Quote Link to comment
Nissan_Boy85 Posted February 20, 2011 Report Share Posted February 20, 2011 Holy shit man! What's that job payin hour wise? With it being warrentee, it can't be all that good.... Quote Link to comment
nismo dr Posted February 20, 2011 Author Report Share Posted February 20, 2011 well the heads are warped so with cylinder head replacement/overhaul, plus a couple broken studs that had to be extracted, I will get around 17-19hrs standard/customer pay book time is 28.8 Quote Link to comment
d510addict Posted February 20, 2011 Report Share Posted February 20, 2011 That looks pretty rough, but try my subaru gl-10 turbo. Had to pull entire motor, then seperate all the turbo pieces and heat sheilds, pulled front half of motor off (timing pulleys/covers). Its ludecris that a 1987 should take soo much work to replace head gasket.....................and then find out that subaru cut major corners and made the heads soo fragile that it is just about impossible to find non cracked heads to replace my 2 un-repairable heads. But seriously I'm glad I'm no mechanic that would drive me nuts. Quote Link to comment
datsunaholic Posted February 20, 2011 Report Share Posted February 20, 2011 It's crazy. But the easiest head gasket I've ever done was on my brother's '91 Corsica. I can't explain it, but it was super simple even though it LOOKS complicated. Quote Link to comment
DanielC Posted February 20, 2011 Report Share Posted February 20, 2011 Last spring I had to replace the head gaskets on my Ford Aerostar, with the 4.0 L engine. It was about 40 steps, with notes, of stuff moved out of the way, until I could get to valve covers, and lower intake manifold. And this was a pushrod engine. Quote Link to comment
Wide14u Posted February 20, 2011 Report Share Posted February 20, 2011 looks like a big ol stinky pile of fun thats what i was thinking Quote Link to comment
Farmer Joe Posted February 20, 2011 Report Share Posted February 20, 2011 wow man... eff that noise... just put a new motor in it if you have to go that far into it... geez.. i hate new vehicles... my buddy just had to do the alternator on an ford escape with the v6... you have to pull the passenger side drive axle out to get the alternator out... whos bright idea was that.. im glad i didnt pursue my mechanic career.. well kinda.. Quote Link to comment
nismo dr Posted February 20, 2011 Author Report Share Posted February 20, 2011 just put a new motor in it if you have to go that far into it... geez.. bare heads $675 each pile of gaskets, thermostat, hardware,fluids, etc probably around $300-500 when all said and done long engine assy - $8,000 you could have a quite a career as a warranty clerk if you could talk a claims administrator into buying the motor Quote Link to comment
Dirk Diggler Posted February 20, 2011 Report Share Posted February 20, 2011 To change the headlight bulbs on my 09 altima I had to remove the entire front bumper and grill, then each headlight. Ridiculous. Side note, my altima coupe doesn't have the headlight adjustment screws where the sedans have them, any idea where these are? Quote Link to comment
bub510 Posted February 20, 2011 Report Share Posted February 20, 2011 ramathorn! lol Quote Link to comment
HRH Posted February 20, 2011 Report Share Posted February 20, 2011 Step 1: Collect underpants. Step 2: ? Step 3: Profit! I think that works just about as well as that stinky Murano mess as far as what they were thinking when they built it. ;) http://www.youtube.com/watch?v=TBiSI6OdqvA Quote Link to comment
