rustrocket Posted November 15, 2010 Report Share Posted November 15, 2010 So here it is. I just spent $16 having the thing washed and detailed, and thought i would share my story and some pics with you guys. Specs: 1987 Nissan Vanette - GC22 Chassis Engine: Z24 with funky dual ignition/plug system. Transmission: 5 speed stick Mileage - 196,000 Owner: 2nd (me) I picked this thing up for $500 from a local gas station owner. He was the original owner of the car, and stopped driving it for whatever reason. When i went to look at it, it was missing the exhaust downpipe and wasn't running. However, i was willing to overlook that in favor of the bitchin' Enkei 92 wheels that the orginal owner had put on it. As luck would have it, the same week i towed it home, a '88 van appeared at the local Pick n Pull, so i was able to nab the exhaust pipe i needed. After installing the exhaust pipe, i put in a battery and some fresh gas, and it fired right up! However, it would'nt rev above 2k, and under load would die. I did some searching on the forums and found that somebody had a similar problem, which turned out to be the ecu. So, another trip to the pick n pull and came back with a fresh looking ecu. It didn't really fix the problem, maybe allowed it to rev to 2200 rpm, but that's it. Then i started looking at the ignition system. I noticed it had this goofy twin plug system..unfortunately, it wasn't as cool as the system on the same vintage porsches :-) I tried unplugging the 2nd coil, and the van came to life. It would freely rev as high as i would let it...however, it still hesitated and bucked under load a little. I went to the junkyard again, and came back with another coil, and some new plug to distributor wires. Installed them, fired it up, and it ran like a champ. I drove it around town for a bit with a goofy grin on my face for a solid 20 mins. I've since put 250 miles on it. It does have a little hesitation between 2600-3000 rpm, but runs great besides that. Unfortunately, it is geared for 1987, so going CA freeway speeds of 65-70 mph, the poor engine is doing 3200-3600rpm, and gas mileage is high teens on the freeway. Regardless, i still need to get it smogged. But with the cost of the van, a used tire (one was flat), exhaust pipe, ecu, coils, and registration/transfer/tax/title fees, i'm sitting right arounf $750. What a deal for a rare and unique machine! Upcoming plans: ka24de/5 speed swap for better economy/more power (Note the clever and convenient placement of the van in front of the nissan flag. The car wash place just happened to be next to a nissan dealership.) Quote Link to comment
datzenmike Posted November 15, 2010 Report Share Posted November 15, 2010 Absolutely great find. Very rare as Nissan bought them all back form owners and crushed them. Very few around. Still have the throttle body injection? That looks like a Z22 motor. Could it have been swapped? The engine ID is stamped on the block just below the exhaust side #2 plug. If it has the throttle body injection I doubt it will give better mileage with a KA. The reason they were scrapped was because it was designed for a smaller CA motor and the Z24i was too big and ran to hot in there. A KA would be worse, but triple cool! See if you can get a picture of the differential. maybe an H-190 . Perhaps a lower gear ratio to lower the revs on the highway. . Quote Link to comment
Bleach Posted November 15, 2010 Report Share Posted November 15, 2010 Yes, those were all to be destroyed by the order of The Queen You're in the hot seat driving a Vanette Quote Link to comment
FoxyRoadster Posted November 15, 2010 Report Share Posted November 15, 2010 I've always wanted to see one of these with an sr swap Quote Link to comment
Sealik Posted November 15, 2010 Report Share Posted November 15, 2010 I like. For this locale....It would be converted to a 4x4 :frantics: Quote Link to comment
datzenmike Posted November 15, 2010 Report Share Posted November 15, 2010 Right after the Vanette was the Axxess and it had an AWD option with R-180 VLSD in it. Likely the KA was FWD mounted. Quote Link to comment
rustrocket Posted November 15, 2010 Author Report Share Posted November 15, 2010 Pretty sure it was the z24 but now i need to check. The z22 had the dual plug system too? Definitely a goofy TPI system. The ka might not give mbtter gas mileage, but a little more power if nothing else. IT does have 3 recall stickers :-) The temp never gets above halfway on the gauge. I do have a couple spare SR's sitting around. 1 NA and one Turbo...hmmmmm... Quote Link to comment
Sealik Posted November 15, 2010 Report Share Posted November 15, 2010 Pretty sure it was the z24 but now i need to check. The z22 had the dual plug system too? Definitely a goofy TPI system. The ka might not give mbtter gas mileage, but a little more power if nothing else. IT does have 3 recall stickers :-) The temp never gets above halfway on the gauge. I do have a couple spare SR's sitting around. 1 NA and one Turbo...hmmmmm... That valve cover is typical of the Z22...aluminum, with longer mounting bolts. The stock Z24 cover is painted black metal. The Z22 is also a 8 plug engine. Quote Link to comment
Dave7 Posted November 15, 2010 Report Share Posted November 15, 2010 Very cool - I've never seen one as they where not sold here in Canada. Quote Link to comment
motavated Posted November 15, 2010 Report Share Posted November 15, 2010 All I can say is this... You better start looking for new front brake disk and pads. THEY are really hard to find... I was talking to this van owner and he had hard time trying to find them... Quote Link to comment
Bleach Posted November 15, 2010 Report Share Posted November 15, 2010 DORiFTO! :huh: Quote Link to comment
datzenmike Posted November 15, 2010 Report Share Posted November 15, 2010 What rear end is in it? Quote Link to comment
FoxyRoadster Posted November 15, 2010 Report Share Posted November 15, 2010 DORiFTO! :huh: Nah, needs a Ratsun Racing sticker on it and to haul loads of wheels tires, and the fuel drums. :lol: Quote Link to comment
datsun723 Posted November 16, 2010 Report Share Posted November 16, 2010 SO COOL!!! :lol: Quote Link to comment
burrito213 Posted November 16, 2010 Report Share Posted November 16, 2010 nice find Quote Link to comment
rustrocket Posted November 16, 2010 Author Report Share Posted November 16, 2010 I'm surprised nobody has mentioned slamming it on airbags yet. Quote Link to comment
greengoon Posted November 16, 2010 Report Share Posted November 16, 2010 That was my first thought! I can photoshop it for you if you want :D . That thing is awesome and a stick shift van. I would drive that in a heartbeat. Great find. Quote Link to comment
gokiburix Posted November 16, 2010 Report Share Posted November 16, 2010 I've wanted one so bad but most of them went to the crusher :crying: AWESOME FIND! -goki Quote Link to comment
sinner720st Posted November 17, 2010 Report Share Posted November 17, 2010 PHOTOSHOP IT!!!!! Quote Link to comment
AZhitman Posted November 17, 2010 Report Share Posted November 17, 2010 Cool as hell. I wouldn't be surprised if the REAL reason for the "recall" was that it's damn near a carbon copy of the Toyota van. Nice stuff, Cameron. :) Quote Link to comment
rustrocket Posted November 17, 2010 Author Report Share Posted November 17, 2010 That was my first thought! I can photoshop it for you if you want :D . That thing is awesome and a stick shift van. I would drive that in a heartbeat. Great find. I'd love to see a photoshop of it slammed and maybe tinted windows too! Thanks man, post it up! Cool as hell.I wouldn't be surprised if the REAL reason for the "recall" was that it's damn near a carbon copy of the Toyota van.Nice stuff, Cameron. :) Hey Greg! Long time buddy. It's pretty damn close to the Mitsu Starwagon too...but i think a little closer to the Previa :-) This will be the daily driver soon. Quote Link to comment
gokiburix Posted November 17, 2010 Report Share Posted November 17, 2010 Ask and you shall receive... Before: After: (lowered and tinted windows) btw, I'm jealous :angry: :lol: -goki Quote Link to comment
bueiz Posted November 18, 2010 Report Share Posted November 18, 2010 My parents had one of these things. It was recalled due to fire issues. We never had any problems with it, we even had a LeBra for it; I remember having to put in on and take it off as a kid. In the end my parents took Nissan up on their offer. And yea; we had some family friends with the Toyota version, it was almost an exact duplicate. They kept the Toyota long after we got rid of the Nissan. I loved it and it's drink cooling capabilities. I remember feeling so luxurious riding in that thing with that cooler; great on road trips. Quote Link to comment
dedrick Posted November 19, 2010 Report Share Posted November 19, 2010 That is one beautiful machine. Quote Link to comment
rustrocket Posted November 19, 2010 Author Report Share Posted November 19, 2010 Man, I'm glad you guys like this thing so much. My girlfriend won't even set foot in it... Maybe i need to get that ice maker working and entice her with some chilled chardonnay or something. Quote Link to comment
