My New 510 Project....
Docsis510
  • Replies 24
thanks guys. the car needs carb and clutch work. the carb was rebuild but runs like crap. when i bought the car the owner said it was recently stolen so the ignition was missing. when i got the car home i tried starting it with an ignition i bought from the yard but the starter would turn and the motor wouldnt. i took the starter out and noticed pieces of metal all over the place. so i decided to take the tranny out. when i pulled the tranny everything came out with it. clutch, flywheel, and bolts. the last pic shows how the tranny came out. anyways im thinking of painting the tripes black and putting some 14x7 black rimsss.
  • 2 months later...
Must be a l20 motor because the flywheel has 6 bolt holes, the carb probably just needs to be tuned, if the teeth on the fly are in ok shape you can just get it re surfaced pretty cheap hope the tranny and stuff didn't get eaten up to much but over all this car is in WAY better shap than mine is in.
Good luck dude
  • 4 months later...
well i decided to keep my 510 and do a ka24de motor swap. today i started to clear up the engine bay to sand it a paint it. not sure if i want to paint it the same color as the car or just black.
