Sealik Posted January 4, 2011 Author Report Share Posted January 4, 2011 I'm assuming clamping force is different than torque capacity....? The one I linked is rated at 319 ft-lbs. And you know...it is Full Organic......'Grown' in Japan.... :P Quote Link to comment
Sealik Posted January 4, 2011 Author Report Share Posted January 4, 2011 Hmmmmmm....I don't think ever posted which truck the LZ23 was going in...... This one..... Quote Link to comment
datzenmike Posted January 4, 2011 Report Share Posted January 4, 2011 Even with the clutch fully engaged if enough torque is forced through a PP it will slip. The higher clamp force the better. If 319 ft lbs is engine torque that's lots probably twice what you need. Quote Link to comment
Sealik Posted January 6, 2011 Author Report Share Posted January 6, 2011 Even with the clutch fully engaged if enough torque is forced through a PP it will slip. The higher clamp force the better. If 319 ft lbs is engine torque that's lots probably twice what you need. Ya....a little excessive for the application....but the next one (cheaper) from Exedy is 94 bucks.....200 bucks cheaper. http://cgi.ebay.ca/EXEDY-CLUTCH-KIT-NISSAN-PATHFINDER-PICKUP-D21-2-0-2-4-/150050383427?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ANissan&hash=item22efb32643 Says for stock or slightly modified engine.....That should hold I think.....?????? No specs on that clutch....Roll the dice I guess if I get it. On another note.....got the 89 mill NPR pistons......mmmmmmm.....shiny... :) Quote Link to comment
Sealik Posted January 7, 2011 Author Report Share Posted January 7, 2011 LZ23 parts list/Canadian prices....so far. NPR 89 mill pistons/rings...............100 Beck Arnley L20B TC assembly....115 L20B IM/EM gasket L20B/Z22...#202-6001 ARP studs Z22 Frost plugs L20B (U67) Valve seals...................112 Felpro Z24 HG....................35 Felpro L20B Valve cover gasket........17 Z22 Crank oil seal...................15 Top Line Z22 rod bearings............29 Top Line Z22 main bearings...........50 Shadbolt regrind #449 with .180 lash pads....$214...plus shipping.....$35 Exedy stage 1 clutch kit (319 ft/lb torque capacity).....$340 Ka....ching Quote Link to comment
Sealik Posted January 11, 2011 Author Report Share Posted January 11, 2011 Made the 200+ km trek to the 'big city'.......dropped off the block,head,crank, flywheel and the new parts. Guess there's no turning back now......LZ23...here we come :thumbup: Was 500 bucks for the block...until he looked at the wear on the connecting rod bearings. Have to re-size.....17 bucks a pop. That included hot tanking, boring, magnaflux testing, polishing the crank, pressing the connecting rods onto the new pistons and assemble the bottom end. The head is about 275....that included....pressure testing and a 3 angle valve job. Can't remember how they clean the head.....something-peaning.....??? Probably around..........1000 bucks.....by the time everything is said and done. If he calls within a day....something is amuk.....and the cost will definitely be going up. Valve guides.....springs...etc...etc could be due for upgrading......crank looked good, but.... who knows. :blink: :) Should be ready on Friday.... Ka......ching. Quote Link to comment
merlin Posted January 11, 2011 Report Share Posted January 11, 2011 Guess there's no turning back now......LZ23...here we come :thumbup: Probably around..........1000 bucks.....by the time everything is said and done. If he calls within a day....something is amuk.....and the cost will definitely be going up. Valve guides.....springs...etc...etc could be due for upgrading......crank looked good, but.... who knows. :blink: :) Should be ready on Friday.... Ka......ching. :rofl: Rremember, it's only money... :rofl: :rofl: :rofl: :rofl: Quote Link to comment
merlin Posted January 11, 2011 Report Share Posted January 11, 2011 checked that tranny... it is the 1980 720/l20b truck one.., Datzenmike..... drumroll..... gear ratios please..... http://www.youtube.com/watch?v=obKLdou0LH0 Quote Link to comment
Sealik Posted January 11, 2011 Author Report Share Posted January 11, 2011 :rofl: Rremember, it's only money... :rofl: :rofl: :rofl: :rofl: Ya.....well.....that is starting to lack....somewhat... :unsure: ... :) On another 'note'.....the owner asked about the cam/lift (.491) and is going to check on 'spring integrity'.....yada....yada. Knows of Shadbolt...seems rather knowledgeable .......and his name is Doug... :) :) Quote Link to comment
datzenmike Posted January 11, 2011 Report Share Posted January 11, 2011 '80 2wd 720. The 4 speed has the same lower 1-4 ratios. 1st..... 3.592 2nd.... 2.248 3rd..... 1.415 4th......1.000 5th..... 0.882 For the L20B and for use with factory 3.889 and 4.11 rear end ratios. Quote Link to comment
merlin Posted January 11, 2011 Report Share Posted January 11, 2011 '80 2wd 720. The 4 speed has the same lower 1-4 ratios. 1st..... 3.592 2nd.... 2.248 3rd..... 1.415 4th......1.000 5th..... 0.882 For the L20B and for use with factory 3.889 and 4.11 rear end ratios. right the 0.882 fifth was what i couldn't remember... it looks the same as the 280zx 5 speed, but that has a 0.75 5th gear Quote Link to comment
Sealik Posted January 11, 2011 Author Report Share Posted January 11, 2011 '80 2wd 720. The 4 speed has the same lower 1-4 ratios. 1st..... 3.592 2nd.... 2.248 3rd..... 1.415 4th......1.000 5th..... 0.882 For the L20B and for use with factory 3.889 and 4.11 rear end ratios. I'm thinking just a bell housing swap???? Then I don't have to deal with a long tail tannie install Would have to change the console...propeller shaft..etc...etc...just keep the 26.5 inch length. The L20B will have the smaller counter shaft bearing opening.....of course.....to utilize in the pre (?) 85 trannie. Which I have....also :) I think..... :blink: .... :lol: Quote Link to comment
Sealik Posted January 12, 2011 Author Report Share Posted January 12, 2011 Guides are shot.....Ka Ching. Quote Link to comment
datzenmike Posted January 12, 2011 Report Share Posted January 12, 2011 '80 2wd 720. The 4 speed has the same lower 1-4 ratios. 1st..... 3.592 2nd.... 2.248 3rd..... 1.415 4th......1.000 5th..... 0.882 For the L20B and for use with factory 3.889 and 4.11 rear end ratios. '80 4X4 720 4 and 5 speed are the same ratios as above but the 5th (overdrive) is 0.813 The 4X4 has no provision for a speedometer cable. Quote Link to comment
Sealik Posted January 12, 2011 Author Report Share Posted January 12, 2011 Started cleaning up all the parts. Came out okay....good enough.....form over fashion. :D Will paint the brackets and tensioner. Need to make a plate for the right hand side of IM....and 'fit' the heat shield Used Loctite on all 8 bolts holding the Weber adapter plates Cam and lash pads was shipped from Shadbolt yesterday. Quote Link to comment
Sealik Posted January 13, 2011 Author Report Share Posted January 13, 2011 Cleaned the dizzy up and got the advance working. Also set the air gap. After I cleaned the TC cover... I noticed the previous...previous pump had started to wear the inside of the cover. There was a new 620 pump on it.....shall replace with the larger pump (tines) from the Z22 Hmmmmm......grinded the sharp edges off. Thinking it should be okay....? The difference in length. Quote Link to comment
datzenmike Posted January 13, 2011 Report Share Posted January 13, 2011 Pretty sure Doug that the impellers are the same depth into the timing cover cavity. The pump cavity is deeper on the Z pumps allowing a larger impeller to be fitted. If there is wear in the timing cover then a pump with a wobbly bearing was likely the cause. L20B Z22/24 Do not get these cheap re-built POS blenders. . Quote Link to comment
Sealik Posted January 14, 2011 Author Report Share Posted January 14, 2011 You are correct....Mike..........as always.... :D Anywho.....got the cam from Shadbolt today. The 'infamous' #449 grind.....Jaun Valdez is happy.....as I.... :) Specs on receipt are... *205 degrees duration @ .050" (256 degrees advertised) .327" cam lift .491" valve lift on 109 degree lobe C/L ....use with "New" or "As New" Rocker Arms. Lash pads are .150" Well....I do Know 1 of my rockers is NFG.....but Hmmmmm..all new rockers....???? Ka Ching? Quote Link to comment
Sealik Posted January 14, 2011 Author Report Share Posted January 14, 2011 I'm gonna assume that the .150 lash pads are for new rockers....obviously Whereas worn rockers would increase lash pad size. I'll throw it together and see the 'wipe' pattern on the old rockers....??? Quote Link to comment
datzenmike Posted January 14, 2011 Report Share Posted January 14, 2011 Get a sheet of glass that will fit in the sink for a smooth surface and some wet 1000/1500 sand paper and rock those stroke to remove the old 'wear' pattern. Machine shops charge big money to do the same with a belt sander.me Quote Link to comment
Sealik Posted January 14, 2011 Author Report Share Posted January 14, 2011 Get a sheet of glass that will fit in the sink for a smooth surface and some wet 1000/1500 sand paper and rock those stroke to remove the old 'wear' pattern. Machine shops charge big money to do the same with a belt sander.me Ya....I can see/feel the ridge...wear pattern. Actually I'm rather handy with a 'sander'.... :lol: But......Sure as shit... :) ....after I'm done.....probably need a thicker lash pads? I'll take the rockers and cam in when I go to pick up the block and head....pick their brains....and not my wallet ;) http://cgi.ebay.ca/Datsun-L-Series-510-620-240Z-280Z-New-NOS-Rocker-Arms-/160529317461?pt=Motors_Car_Truck_Parts_Accessories&hash=item25604afe55 Quote Link to comment
Sealik Posted January 16, 2011 Author Report Share Posted January 16, 2011 Paid a visit to Merlin this morn.....he gave me a valve cover with the DATSUN OHC on it.....mmmmmmm Thanks! Couple hours of cleaning.....Voila Quote Link to comment
merlin Posted January 16, 2011 Report Share Posted January 16, 2011 looks Good! Quote Link to comment
Sealik Posted January 17, 2011 Author Report Share Posted January 17, 2011 looks Good! Yes....thanks....purdy :P My block is ready.....BUT...the head needed new exhaust valves..... seats and guides... :( They got Z24 valves instead of Ls....tomorrow...hopefully, they should have the proper valves. Pick it up Wednesday.....maybe. Quote Link to comment
merlin Posted January 17, 2011 Report Share Posted January 17, 2011 Yes....thanks....purdy :P My block is ready.....BUT...the head needed new exhaust valves..... seats and guides... :( They got Z24 valves instead of Ls....tomorrow...hopefully, they should have the proper valves. Pick it up Wednesday.....maybe. FFFFFUUUUUUUUUUUUUUUcccccccc.......... :sick: remember. its only money.... Quote Link to comment
