Jacob's Goon Build - Now L19 powered.
Laecaon
And more pictures of tonight!
Step one, figure out the charge light, oops I had the wires reversed.
Hey looky, thats not an Lseries alt!
Wires! The spade connectors I used are of the "F crimp" style, where it crimps onto the wire, and the housing.
A pic of the wiring from when I did my ZX Alt, this still works. One day I will delete this...
Ew greasy mess!
Yuck!
Shiny new bolt! Needed since the old one was too short.
Too address the leak I had going on, I figured it was the timing chain inspection plate. I think I see something!
Front side
Ah yes, you can see where the oil was escaping!
So I decided some RTV was in order since the seal didnt want to play nice. Ill have a day time install picture tomorrow.
Pulled my dizzy, I think the seal was leaking... Wait, this doesnt look like the proper gasket... But I did notice the top half came off easily and the bottom half needed to be scraped off.
Trying to do some cleaning
Sentra Dizzy!
Super cool internal module!
Anyways, Ill get some more pictures tomorrow. Im hoping I solved the dirty motor issues.
I need to go to the JY and get a new Alt Pulley. My pulley is off center due to the shaft being smaller in diameter...
  • Replies 895
Yay a collection of parts for my car!
What you are seeing:
2X Moog Ball joints
All the Moog Tie Rod ends
2X Tie Rod center pieces (Moog...)
Raybestos Idler Arm bushings/rebuild kit.
Duralast Centerlink
All the Moog stuff is stamped with the Three Five badge, which makes me feel better, all of it made in Japan.
I was also at the JY, and grabbed a few pulleys to try on my Alt.
Wow.  I think we bought all of the same stuff on the same day.  Odd.  I spent I think $200 total for Ball joints, tie rod ends and shaft, bushings, crosslink, plus all the other rubber parts behind the tire.  Fun stuff.  I just got done POR15'in it all.
Ok, to wrap up a few things.
Alternator back out, and looking ready!
I had to make a sleeve to take up the slop when using a D21 pulley (KAe pulley)
All better!
RTV section of inspection plate, not much oozing happening, so I was I happy. I probably only needed to apply the RTV to the bottom half....
And the new dizzy gasket!
Ok, why the new suspension/steering stuff? well because...
I only manage to get the tie rods and centerlink done today. I stopped taking pictures at some point, hands got really dirty.
Start with removing the cotterpin. Then remove the nut.
On most cars I work on at work this trick works. I usually smack the steering knuckle with a 4lb hammer 3-4 times, and pop! But that didnt work on this car. So I threaded the nut back on a bit, and then hit the top.
And its out.
But Mr Sawzall had to make an appearance, I just could not get the centerlink off the pitman arm.
So I removed the steering box, and the remains of the center link pivot came out in 1 swing.
Basically I put everything back together, and greased it. More pictures when I do the ball joints, which really need replacing.
The odd thing is, my steering really doesn't feel much different. What has really prompted me to do this, well the left tie rod end has been progressively digging more and more into my wheel weight on right turns. Also I had a minor front end clunk.
Now I just need to get an alignment...
  • 4 weeks later...
  • 2 months later...
