inline4 Posted April 5, 2010 Report Share Posted April 5, 2010 but these are +15 offset wheels. can they be made to fit with 280zx struts? Quote Link to comment
JDM510 Posted April 5, 2010 Report Share Posted April 5, 2010 yes they will fit with at least a 8mm spacer other wise the rim will hit the strut.... Quote Link to comment
inline4 Posted April 5, 2010 Author Report Share Posted April 5, 2010 how safe are spacers. Quote Link to comment
JDM510 Posted April 5, 2010 Report Share Posted April 5, 2010 my uncle got extended nismo hardend studs with 8mm (witch is not that thick) "slip on spacers" safest spacer you can run in my book... not like those type you bolt on the hub, then bolt the wheel to it.. those suck and your wheels can fall off.. Quote Link to comment
Guest DatsuNoob Posted April 5, 2010 Report Share Posted April 5, 2010 Damn that overrider looks like :poop: on that dime. Sry, no pollution intended here. I know very little about offsets myself Quote Link to comment
banzai510(hainz) Posted April 5, 2010 Report Share Posted April 5, 2010 +15 should be OK on ZX struts. Ichiba makes 5mm spacers also.good quality might not need longer studs. Quote Link to comment
Jesse C. Posted April 5, 2010 Report Share Posted April 5, 2010 Don't know, look it up! Yes, the computer is just not for porn anymore! http://www.1010tires.com/WheelOffsetCalculator.asp http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101 1 Quote Link to comment
SSS510 Posted April 5, 2010 Report Share Posted April 5, 2010 how safe are spacers. I you use Spacers just make sure the wheel studs are long! If they are short replace with long studs! Other than that you are safe!! Quote Link to comment
dayton100 Posted April 5, 2010 Report Share Posted April 5, 2010 i 'm not sure if it's been posted on the forum but give this a peek i thought it was pretty neat will they fit dot com Quote Link to comment
bonvo Posted April 5, 2010 Report Share Posted April 5, 2010 i 'm not sure if it's been posted on the forum but give this a peek i thought it was pretty neat will they fit dot com this thing is epic!!! i now know what tire size i want to run out back :P Quote Link to comment
71DIMER Posted April 5, 2010 Report Share Posted April 5, 2010 my uncle got extended nismo hardend studs with 8mm (witch is not that thick) "slip on spacers" safest spacer you can run in my book... not like those type you bolt on the hub, then bolt the wheel to it.. those suck and your wheels can fall off.. I've had those bolt to the hub then bolt the wheel to the spacer-spacers and never felt in danger. I ran them for years and nothing ever happened. I don't know of anyone personally that had anything bad happen to them if using these things normally. I think it's just a dislike of them that makes people assume they're dangerous. Damn that overrider looks like :poop: on that dime. Sry, no pollution intended here. I know very little about offsets myself Forget the overrider, what in the world is the function of only having 1 Yakima roof rack bars? Quote Link to comment
JDM510 Posted April 5, 2010 Report Share Posted April 5, 2010 cuz its JDM tight yo!!! lol hahahhahah Quote Link to comment
lardlungs Posted April 5, 2010 Report Share Posted April 5, 2010 mabye he also rides a unicycle Quote Link to comment
Gensaiken Posted April 6, 2010 Report Share Posted April 6, 2010 I run a +15 or so on 280ZX struts, no spacer, no rub or hit. Quote Link to comment
JDM510 Posted April 6, 2010 Report Share Posted April 6, 2010 thats weird my uncle bought sport max 15x7 +15 offset and he rubs without atleast a 5mm spacer..... heres a question for you what widith is your rim... yeah if you have a x6 +15 it wont rub also i heard zx struts have diff angles maybe that has something to do with why some people rub and some dont...... quit being a puss and go get the wheels and if they rub handle that shit!!!! Quote Link to comment
Gensaiken Posted April 6, 2010 Report Share Posted April 6, 2010 thats weird my uncle bought sport max 15x7 +15 offset and he rubs without atleast a 5mm spacer..... heres a question for you what widith is your rim... yeah if you have a x6 +15 it wont rub also i heard zx struts have diff angles maybe that has something to do with why some people rub and some dont...... quit being a puss and go get the wheels and if they rub handle that shit!!!! Hmm, yeah I think my wheels might be a 15x6 or 6.5? They are Enkei Compe-8's or I think the other name was Enkei 80? Quote Link to comment
Bleach Posted April 6, 2010 Report Share Posted April 6, 2010 you do know there are two different types of 280ZX struts, right? They have different hub angles so your camber would vary depending on what strut you have. Aside from knowing the offset, wheel width is important. Are we all just assuming the wheels are 7 inches wide? Quote Link to comment
philcas1987 Posted April 6, 2010 Report Share Posted April 6, 2010 Jdm rice? He's just a beginner driver. Quote Link to comment
JDM510 Posted April 6, 2010 Report Share Posted April 6, 2010 you do know there are two different types of 280ZX struts, right? They have different hub angles so your camber would vary depending on what strut you have. Aside from knowing the offset, wheel width is important. Are we all just assuming the wheels are 7 inches wide? yeah i pointed that out.... but the rims he posted are 7s.. Quote Link to comment
71DIMER Posted April 6, 2010 Report Share Posted April 6, 2010 Hmm, yeah I think my wheels might be a 15x6 or 6.5? They are Enkei Compe-8's or I think the other name was Enkei 80? Wow I didn't know Enkei Compe-8's came in 15's. From what I've seen online (scan of a Enkei catalog) they only came in 13" and 14". Quote Link to comment
inline4 Posted April 6, 2010 Author Report Share Posted April 6, 2010 you do know there are two different types of 280ZX struts, right? They have different hub angles so your camber would vary depending on what strut you have. Aside from knowing the offset, wheel width is important. Are we all just assuming the wheels are 7 inches wide? I did not know that. I forget which year I grabbed these struts from. Quote Link to comment
Gensaiken Posted April 7, 2010 Report Share Posted April 7, 2010 Wow I didn't know Enkei Compe-8's came in 15's. From what I've seen online (scan of a Enkei catalog) they only came in 13" and 14". Sorry all this "15" talk got me confused. They are 14's. :lol: I did not know that. I forget which year I grabbed these struts from. Does anyone want to share what years the differences occurred and the amount of the change? Doesn't sound like enough of a difference for people to choose one year over the other as this is the first I've ever heard of this difference. :unsure: Quote Link to comment
JDM510 Posted April 7, 2010 Report Share Posted April 7, 2010 i think i remeber their being so many diff. variations that it was hard to keep track.. i also heard of people getting mis-matched set causing uneven camber issues.... Quote Link to comment
datrod Posted April 7, 2010 Report Share Posted April 7, 2010 my uncle got extended nismo hardend studs with 8mm (witch is not that thick) "slip on spacers" safest spacer you can run in my book... not like those type you bolt on the hub, then bolt the wheel to it.. those suck and your wheels can fall off.. Don't be a hater playa. You have a bug up your ass for spacers. I've been making and using them longer than you have been driving. I've been running them on my wagon for over a year now and my wheels are still on the car. :o Quote Link to comment
Gensaiken Posted April 7, 2010 Report Share Posted April 7, 2010 i think i remeber their being so many diff. variations that it was hard to keep track.. i also heard of people getting mis-matched set causing uneven camber issues.... Yeah, when I was doing the swap I was dealing with several different years of ZX struts and came across almost as many variations on the rotors as well. Seems like they did some slight variations over the years to the rotor design. I assume beefing them up as they got to the turbo version. I wonder if anyone will figure out the most ideal combination of parts. :lol: Quote Link to comment
