L series valve adjustment
mklotz70
I hooked up a 2 piece switch for the starter....first piece is hard wired, second piece plugs in when I want to set valves, compression/leakdown test etc.
Speeds things up considerably, all intakes than all exhausts.
Usually...all the valves don't have to be set....so...under 5 mins
  • Replies 60
WOW, I was totally trying to put the feeler gauges in the wrong place, it goes unfer the lobes of the CAM!?!? no wnder why I thought my valves were all wrong. Looks like I am going back to check them again this week.... good thing I knew something was off and I decided to put the valve cover back on before changing anything.
  • 10 months later...
  • 4 months later...
  • 2 months later...
.010" intake/.012" exhaust for stock L...hot engine
1-2 thousands less for aftermarket cam
.006"-.008" cold...readjust to 'stock' specs when warmed up.
as in Inches
so for a cam that is 280/480 the above is true ?
because ive set my valves twice hot at .010 /.012
and with a make shift stethoscope all the valves seem to still be chattering  oil level is right
but im starting to think  what sealik said is becoming true for my situation ? any ideas
