freekwonder Posted August 31, 2012 Report Share Posted August 31, 2012 Got her dropped down on her garage coilovers. old longer struts next to shorter struts (1984 Toyota Celica with solid rear axle) Attempt at compressed height extended height Quote Link to comment
skyblue Posted August 31, 2012 Report Share Posted August 31, 2012 which beach? I love the beaches up there. now i just gotta get my dime out to the beaches down here! it was hot as f so i went to dillon beach to cool off a bit. awesome drive and clear skies. 1 Quote Link to comment
Tristin Posted August 31, 2012 Report Share Posted August 31, 2012 Fixed my engine rattle and installed the temporary valve cover and aircleaner so that my pieces can be powerdcoated. Quote Link to comment
FiveSeventyZee Posted September 1, 2012 Report Share Posted September 1, 2012 it was hot as f so i went to dillon beach to cool off a bit. awesome drive and clear skies. that's the one of the best drives around up there...never got a chance to take the dime out Quote Link to comment
freekwonder Posted September 1, 2012 Report Share Posted September 1, 2012 Well yesterday, got my VW radiator mounted, and the cheap/easy mod of turning the side markers into blinkers. Hopefully can get the ebrake setup today. Quote Link to comment
skyblue Posted September 1, 2012 Report Share Posted September 1, 2012 that's the one of the best drives around up there...never got a chance to take the dime out it is a nice drive. can't wait to take it when i get the suspension done up on the dime. Well yesterday, got my VW radiator mounted, and the cheap/easy mod of turning the side markers into blinkers. Hopefully can get the ebrake setup today. I read a how-to on the blinker mod years ago on 510 again i think. i didn't really search yet, but would you mind sharing the mod? I've always wanted to do that. Quote Link to comment
freekwonder Posted September 1, 2012 Report Share Posted September 1, 2012 it is a nice drive. can't wait to take it when i get the suspension done up on the dime. I read a how-to on the blinker mod years ago on 510 again i think. i didn't really search yet, but would you mind sharing the mod? I've always wanted to do that. Its in the first DQ issue, page 7 https://docs.google....DM1MjMwMzVjMDIz It doesn't tell you how to do the back, but it is the same concept. I took the ground from the side marker and tapped it into the Green/black (and Green/red for the other side) of the turn signal. Still lights up like a side marker, but blinks when you hit the turn signal. Just have to be careful with the screws, two of my lights were grounding through the screws to the body, so like the article mentions I may grab some nylon screws, or figure something else out. Tried to grab a video of it, shows the blinkers all blinking and then I turn them off with the blinkers still on to show that they aren't just screwed up lol. I did upgrade my flasher to do this. Click the picture and it will take you to the video. Quote Link to comment
Boaty Posted September 1, 2012 Report Share Posted September 1, 2012 My McKinney mounts came in. I bought a set of rubber isolators to try out on the KA. Put one in, half the vibes went away. I am going to swap out the other Poly mount and drive it for a bit and see if it allows too much movement (shouldn't). I just don't want the 2.25" exhaust to rattle in the stock rear 510 crossmember. We shall see =D Quote Link to comment
Duke Posted September 2, 2012 Report Share Posted September 2, 2012 Made a new gas pedal to aid in heel-toe down shifting. Quote Link to comment
Draynor Posted September 3, 2012 Report Share Posted September 3, 2012 Lowered the goon. Quote Link to comment
freetheoranges Posted September 3, 2012 Report Share Posted September 3, 2012 New drums and brake shoes, new rear shocks, sway bar bushings (that i got way back at Canby), and fuel filter. Fun stuff. Spent a good 7 hours getting dirty with my dime. Quote Link to comment
darc510 Posted September 4, 2012 Report Share Posted September 4, 2012 Began last night in beginning BMW headlight mod, have to squeeze time to do it when i can... Quote Link to comment
pl521sss Posted September 5, 2012 Report Share Posted September 5, 2012 Picked up a 68 wagon My addiction is back. 3 Quote Link to comment
Laecaon Posted September 5, 2012 Report Share Posted September 5, 2012 looks clean! Quote Link to comment
Tristin Posted September 5, 2012 Report Share Posted September 5, 2012 Broke my hood release cable. Now to fix it. Quote Link to comment
freekwonder Posted September 5, 2012 Report Share Posted September 5, 2012 Damn, I want a goon. Put in a cheesy center console I had sitting around, not sure what it is from, it was for an auto car. Just made some brackets, should be enough to put a cup holder on and hold my phone. Quote Link to comment
Laecaon Posted September 5, 2012 Report Share Posted September 5, 2012 Starting the door panel process again. This time doing things how I actually want to do. Picked up some ABS sheet, eh still trying to figure out how to best plan everything. I think I need a little more for the piece on the hatch. Glossy side: Textured side: And a piece of clear whatever, so that I can hold it up to the door and mark where the holes are exactly: Quote Link to comment
freekwonder Posted September 5, 2012 Report Share Posted September 5, 2012 Damn I need a template of the panels for a 2 door, mine are in pretty good shape and I don't want to take them apart. Quote Link to comment
Ratwagon1600 Posted September 6, 2012 Report Share Posted September 6, 2012 Finished customizing my air filter covers. 1 Quote Link to comment
Datzun510 Posted September 6, 2012 Report Share Posted September 6, 2012 Installed some hood pins! Quote Link to comment
darc510 Posted September 7, 2012 Report Share Posted September 7, 2012 Installed some hood pins! Love that roof scoop! how does it look from the inside? Quote Link to comment
Datzun510 Posted September 7, 2012 Report Share Posted September 7, 2012 Inside is still under construction. I had this bad boy sitting for almost 18 years. So finally decided to start working on it and getting it running. Took me about 3 months to replace some parts to get it running. But it runs now and even got it registered, FINALY! I still have a lot of work to do, but slowly its coming along. Hope you guys like the pictures :) and a picture of the motor :) Quote Link to comment
freekwonder Posted September 26, 2012 Report Share Posted September 26, 2012 Started messing with the new gauges. 2 Quote Link to comment
darc510 Posted September 26, 2012 Report Share Posted September 26, 2012 diggin those gauges...speedhut? what are you thinking about doing in the center hole (lol)? Quote Link to comment
freekwonder Posted September 26, 2012 Report Share Posted September 26, 2012 Yeah speedhut, eventually will be boost or fuel pressure, didn't have the money or need for them yet. Quote Link to comment
