datzenmike Posted May 30, 2015 Report Share Posted May 30, 2015 Probably you can change the knob with the thumb operated push button. Probably. My '74 710 had a less than pristine handle. I had one from a 620 or something... the difference was a small silver strip around the handle the other didn't have. I can't find any matching part numbers between z or zx shifters and the 710 but, like I say, some parts might swap. Quote Link to comment
JustRight Posted May 30, 2015 Report Share Posted May 30, 2015 Thanks for the reply. It looks close enough to give it a shot. I'll try the bushings, also. 39 years of handling made it the most noticeably worn part on the car. P.S. What does the "goon" reference mean? Quote Link to comment
datzenmike Posted May 30, 2015 Report Share Posted May 30, 2015 'Goon refers to any station wagon. Usually a Datsun wagoon. (it's a Datsun 'thing') My handle was not from use (only had about 20K miles on it) but from sun damage. It was all crumbly and you could gouge it with your thumb nail. Quote Link to comment
datsunfreak Posted May 31, 2015 Report Share Posted May 31, 2015 P.S. What does the "goon" reference mean? Quote Link to comment
JustRight Posted June 2, 2015 Report Share Posted June 2, 2015 Hi, I have another 710 question. I mounted the 6 spoke wheels with 195 tires and the car looks great. There is only about a 3/8" fender clearance when turning but clearance is clearance, so I'm good. My question is: There is noticeable positive camber in the front tires now. Is camber adjustable on the 710? Quote Link to comment
datzenmike Posted June 3, 2015 Report Share Posted June 3, 2015 Changing rims won't affect camber but with wider rims it might be more noticeable now. Take a look at your top hats. The 710 is designed differently and top hats are offset slightly to the center of the vehicle. Or should be, or can be if needed. Inward increases negative camber or decreases positive camber. Tilts the top of the tire in towards the car. Quote Link to comment
JustRight Posted June 3, 2015 Report Share Posted June 3, 2015 My eyeball gauge says it's about one degree pos. How would someone safely modify the assembly to increase negative camber? Thanks for the reply. P.S. I just noticed there are adjustable camber plates available for some popular Datsuns. Does anyone know which ones fit the 710? Quote Link to comment
datzenmike Posted June 3, 2015 Report Share Posted June 3, 2015 You can use a rat tail file and oval the holes so the strut mounts farther inward.... or camber plates. Either are only as good as how far the spring can be moved inward before it rubs the side of the strut tower. Quote Link to comment
JustRight Posted June 3, 2015 Report Share Posted June 3, 2015 Good point. I hadn't thought about spring rub as of yet. Thanks for the advice. Quote Link to comment
datsunfreak Posted June 4, 2015 Report Share Posted June 4, 2015 just noticed there are adjustable camber plates available for some popular Datsuns. Does anyone know which ones fit the 710? Any for the Datsun 510, or 89-93 240SX (aka S13). Quote Link to comment
logiccreations Posted June 14, 2015 Report Share Posted June 14, 2015 If you guys care I uploaded a video of my 76 datsun 710 on YouTube.... Title-My 1976 datsun 710 Quote Link to comment
logiccreations Posted June 14, 2015 Report Share Posted June 14, 2015 It's white Quote Link to comment
datsunfreak Posted June 14, 2015 Report Share Posted June 14, 2015 You could post a link... ^_^ Quote Link to comment
logiccreations Posted June 14, 2015 Report Share Posted June 14, 2015 I did it on my phone Quote Link to comment
logiccreations Posted June 24, 2015 Report Share Posted June 24, 2015 My starter solenoid went out......again Quote Link to comment
studioceja Posted July 4, 2015 Report Share Posted July 4, 2015 Selling my 710. Anyone interested? Its a 1974 Datsun 710. I'm the 2nd owner, California car in Orange County. L18 automatic. 1 Quote Link to comment
datzenmike Posted July 4, 2015 Report Share Posted July 4, 2015 This is the forum for the discussion of the 710 .,. If looking to buy or sell it must be done in the Classifieds section.... http://community.ratsun.net/classifieds/category/2-datsun-vehicles/?sort_key=date_added&sort_order=desc Quote Link to comment
studioceja Posted July 4, 2015 Report Share Posted July 4, 2015 Sorry. Please feel free to delete admin. I tried but seems like I can't. I'll repost in the classifieds. Quote Link to comment
logiccreations Posted July 10, 2015 Report Share Posted July 10, 2015 Can anyone find me a list of parts for the 76 710 works cars? Quote Link to comment
logiccreations Posted July 10, 2015 Report Share Posted July 10, 2015 Make that 75 Not 76 Quote Link to comment
datzenmike Posted July 10, 2015 Report Share Posted July 10, 2015 Below every of your posts is an EDIT option. Press it and you can edit your own mistakes out or make corrections. Quote Link to comment
Haseo Posted July 26, 2015 Report Share Posted July 26, 2015 Hello. I'm new and I might as well add my datsun 710 / 140j / Violet '73 in the unite. Also, greetings from norway. I plan to try save up for a repaint to fix rust here and there with the dents. Does anyone else have rust problem around front and back windows for water leaks? And a simple solution for a temporary fix until I can repaint it? Some outdoor pictures I took of the view in the area I live. And here are some tlc picture of before and after treatment. Had the car for around 2 weeks now. Sorry if some of the pictures arent of the best quality. 2 Quote Link to comment
datzenmike Posted July 26, 2015 Report Share Posted July 26, 2015 Hi Haseo, and welcome to Ratsun. The 710 sedans are notorious for rotting away along the under side of the rear windows. Just open the trunk and fell up above the fuel tank. There was nothing supporting the window on mine. I had to have metal welded in to save it. The front windshield also had some rot. Possibly because the windows are 'glued' in place. Only way to get at it is to remove the front window and weld it up. Then paint to seal it and only then put the glass back in. Nice Violet. Is that a factory color? Quote Link to comment
Haseo Posted July 26, 2015 Report Share Posted July 26, 2015 Thank you. I have opened the trunk, and there is only slight bubbles underneat, not rotten completely away at all. So mostly for me I have to just grind it down and put rust preventant and repaint it. And I have heard at the local nissan dealer and they said the windows are glued in place. And I hope to fix the issue next year, or maybe possibly this winter. Thank you, and that is the factory color, the color id is sort of funny since its basicly just 123, chartreuse green. I plant to repaint it in the same color, just water based instead of akryl they used at the time, will preserve the color better as well if I do I believe. Quote Link to comment
