datsunfreak Posted October 30, 2020 Report Share Posted October 30, 2020 On 10/14/2020 at 6:04 AM, toadx8u said: Yup that’s the one I was looking for thank you💪🏼💪🏼 For what it's worth, a small block Ford and a T-5 are a much better fit... Quote Link to comment
toadx8u Posted October 30, 2020 Report Share Posted October 30, 2020 1 hour ago, datsunfreak said: For what it's worth, a small block Ford and a T-5 are a much better fit... I’m assuming you’re saying this because of distributor placement... my LS G35 just got totaled out so I have been toying with the idea of moving the setup over(6.0/CD009 combo) Quote Link to comment
datsunfreak Posted October 30, 2020 Report Share Posted October 30, 2020 2 hours ago, toadx8u said: I’m assuming you’re saying this because of distributor placement... Actually, I was not. That does help, but I was saying due to size and weight. A Ford 302 is dimensionally smaller than a small block Chevy, and considerably lighter weight. And even though a T-5 is portly, it can be squeezed into most Datsuns. It's really not any bigger than a KA/SR trans. Now when it comes to an LS, if you can get the accessories, brackets, and water pump from a late model Impala SS (FWD 5.3 LS), it helps a ton with packaging dimensions. That would make it a much more ideal swap. I'd still go Ford, but I know a lot of people feel that because they already have it, is a good reason to do it. 😁 Quote Link to comment
Dguy210 Posted October 30, 2020 Report Share Posted October 30, 2020 1 hour ago, datsunfreak said: Actually, I was not. That does help, but I was saying due to size and weight. A Ford 302 is dimensionally smaller than a small block Chevy, and considerably lighter weight. And even though a T-5 is portly, it can be squeezed into most Datsuns. It's really not any bigger than a KA/SR trans. Now when it comes to an LS, if you can get the accessories, brackets, and water pump from a late model Impala SS (FWD 5.3 LS), it helps a ton with packaging dimensions. That would make it a much more ideal swap. I'd still go Ford, but I know a lot of people feel that because they already have it, is a good reason to do it. 😁 Exactly, I've got a pic somewhere of a B210 I found in a junkyard with a 302 without any major engine bay mods (aside from engine mounts). Quote Link to comment
datsunfreak Posted October 30, 2020 Report Share Posted October 30, 2020 1 hour ago, Dguy210 said: Exactly, I've got a pic somewhere of a B210 I found in a junkyard with a 302 without any major engine bay mods (aside from engine mounts). We built one at our shop and the only real body mod was trimming the radiator support to fit a thicker radiator. 👍 1 Quote Link to comment
