kansascity1 Posted September 17, 2007 Report Share Posted September 17, 2007 Haha, damn marines. We have um here at Edwards... I dont know that they do, but they are here. They are Rotor wing fags (helo guys) Quote Link to comment
drastic520 Posted September 17, 2007 Report Share Posted September 17, 2007 wow got a good point there. imma look into that. will be easier to swap it to a 720 box than locate the rhd for my 520. as far as column thats nothing a little welding and fab'n cant fix. anyone have some good pics of a 720 under hood? Quote Link to comment
dat521gatherer Posted September 18, 2007 Report Share Posted September 18, 2007 i love that horn ring! it looks bent though? pm me if you want to get rid of it or have a spare from you other truck. at this point i'd take a broken one. nice progress. Quote Link to comment
doord521 Posted September 18, 2007 Author Report Share Posted September 18, 2007 OK.. A little update... I got the dash back into the new cab. I still don't have the new rocker welded on.. I need to go and get argon for the welder... I did get the dash cleaned up and a bit of color put on it... I need to find some one to redo my seat now.... I know I jump around a lot but I am doing all of the free things first... Sure makes it interesting though.... Yeah, now I need to move the pedal over again... I also need to track down a radio delete plate... But all I need for the interior is carpet, make door panels and a head liner and it is mostly done on the inside.... Plain and simple... Quote Link to comment
Pacific coast Datsun Posted September 19, 2007 Report Share Posted September 19, 2007 Hey thats what i do...the free or cheap stuff 1st..:D. That dash cleaned up nice too. + you have to learn how to shift with your left hand..:cool: Quote Link to comment
OL YELLER Posted September 19, 2007 Report Share Posted September 19, 2007 both myself and doord521 are Sergeants in the Marine Corps (active duty) This OLD Army vet salutes you both....and thanx to you both Quote Link to comment
datsunfreak Posted September 19, 2007 Report Share Posted September 19, 2007 + you have to learn how to shift with your left hand... It's painfully easy in a slow car. Get on an autocross course in a fast car? Different story. :P Quote Link to comment
doord521 Posted September 19, 2007 Author Report Share Posted September 19, 2007 I have spent a lot of time in Japan and Austrailia so it should come back to me pretty quickly... I hope... We appreciate it OL YELLER... Thanks Mark. I am proud of how it turned out... Now I need to figure out what colors I am going to do for the seat and door panels... The truck is going to be close to the stock blue. I was thinking of doing a Black and dark Grey seat with blue stiching and the same for the door panels and head liner... Quote Link to comment
datzenmike Posted September 19, 2007 Report Share Posted September 19, 2007 ..hhmm..I like the 720 box idea Mike. You could still modify and use the 521 column, but the box is the real issue. I'd bet the 521 steering arm would swap between the two boxes too. I do remember in my first 280 box the 620 pitman arm did swap onto it. When I switched to the 720 box it wouldn't, so I put the 280 sector shaft in it and it fit and worked... that's an inside the frame box to and outside the frame box. You would certainly want to check the fit first eh? wow got a good point there. imma look into that. will be easier to swap it to a 720 box than locate the rhd for my 520. as far as column thats nothing a little welding and fab'n cant fix. anyone have some good pics of a 720 under hood? http://i138.photobucket.com/albums/q251/datzenmike/PSbox87hardbody.jpg[/img]"] Long story short... this is a 720 frame with what I think was the next gen truck (hard body?) after the 720, P/S steering box. The original 720 box was leaking and it was easier to swap this one in. Sorry I don't have a standard box but it's smaller in size but the same height and bolt pattern I think. Quote Link to comment
LeDevil Posted September 19, 2007 Report Share Posted September 19, 2007 Nice progress and good work. Quote Link to comment
drastic520 Posted September 19, 2007 Report Share Posted September 19, 2007 so if i understand this, i can use the 720 box because its an outside the frame box and use it on the inside of the frame and swap the sector shaft to the 280 shaft and it should work with my 520 column or do i need to use the 720 column as well? the hb idea sound good too. column and all. need to see if i can still use my original steering wheel.... damn what did i just ask????... Quote Link to comment
datsunfreak Posted September 19, 2007 Report Share Posted September 19, 2007 need to see if i can still use my original steering wheel.... Doubtful without modification. Pretty sure the HB shaft is a larger diameter than the 520. Quote Link to comment
datzenmike Posted September 19, 2007 Report Share Posted September 19, 2007 so if i understand this, i can use the 720 box because its an outside the frame box and use it on the inside of the frame and swap the sector shaft to the 280 shaft and it should work with my 520 column or do i need to use the 720 column as well? the hb idea sound good too. column and all. need to see if i can still use my original steering wheel.... damn what did i just ask????... Hmmm... First... the boxes I used were for power steering, the std steering will/may be different in size. I think what I needed to say was that the 720 box, if mounted on the passenger side, would be positioned inside the frame. My pitman arm (620) did not fit the 720 P/S arm. Now the standard steering box arm might fit the standard 720 arm... I don't know about that. Quote Link to comment
drastic520 Posted September 19, 2007 Report Share Posted September 19, 2007 i have my work cut out... ill try all the combos till i hit it. keep u posted.... Quote Link to comment
kansascity1 Posted September 19, 2007 Report Share Posted September 19, 2007 Steven, Dash does look a ton better. Keep up the progress. It must be nice to be able to work on your Dat whenever. If I touch mine it has to be back together to drive to work. That and you know my wife. This OLD Army vet salutes you both....and thanx to you both Like Steve said, we appreciate it. Quote Link to comment
doord521 Posted September 20, 2007 Author Report Share Posted September 20, 2007 Not a whole lot new to report today. I got the rocker off of the other truck and matched up the cuts from the old one. Now I still need to go and pick up a bottle of argon and weld it up... Quote Link to comment
drastic520 Posted September 20, 2007 Report Share Posted September 20, 2007 looking forward to the finished product doord! Quote Link to comment
doord521 Posted September 25, 2007 Author Report Share Posted September 25, 2007 Ok Well I planned on doing some welding and grinding this weekend but that didn't happen. Good old Sears decided I needed a 3/8 air wratchet instead of the angle grinder I ordered... Been doing alot of thinking about where this truck is going and what order it needs to go in. I am leaving for Iraq in March so I want to have something major done while I am gone... So this is what I have come up with... I am going to get enough of the air ride done to be able to atleast be able to push the truck around..Then I am going to do all of the major body mods that I have planned- shave doors,raise the bed floor and a few others... I am going to pull out the motor and trans... I am gonna gut the interior again... remove all of the trim, bumpers, and lights... Then while I am deployed I am gong to send it to the body shop to get all of the finish work done and have it painted... I am going to have them go ahead and paint the inside too while they are at it...I like the black but it just wont go with the rest of the truck when it gets painted... I know I want to go back with the factory blue, but I haven't decided if I am going to leave it at that or give it a twist... Not sure yet... Quote Link to comment
doord521 Posted September 30, 2007 Author Report Share Posted September 30, 2007 Ok. Here we go. Got a little bit done finally. The bed floor is cut and raised.I still need to get argon to weld it all up... I also got the front end all taken appart so I can build the front setup and shave the fire wall.... I am hoping to maybe go get some gas tomorrow so I can finally get to welding.... Quote Link to comment
kansascity1 Posted October 1, 2007 Report Share Posted October 1, 2007 bed looks good bro, and can't wait to see some hoops mocked up on that frontend Quote Link to comment
Pacific coast Datsun Posted October 1, 2007 Report Share Posted October 1, 2007 Good work Steven. Liking the new bed floor...Do you have any close up pics of how the alternator is wired into the J 13 harness ? Quote Link to comment
doord521 Posted October 1, 2007 Author Report Share Posted October 1, 2007 Thanks on the bed.. I need to get the inside walls sheet metaled now... I don't have a pic of the alternator but The only wire that was still hooked to it when I got it was a single hot wire running to the battery...It is a delco alternator. Haven't looked at it closely to see witch one.... Quote Link to comment
drastic520 Posted October 1, 2007 Report Share Posted October 1, 2007 nice work there doord... i finally got mine on the road this weekend. got a lot of props from the locals. even had a few 240 guys pull up and compliment on it. tell u one thing. i was wondering what to do first on mine n now i kno its the motor. god this thing is slow. im so used to my 02 se altima that it seems like it takes forever to get going. plus it revs so high on the highway. anyone out there has wiring tips to throw in a ka24 in it? gotta do it until i can save to get an sr20. ill be posting pics tonite.... Quote Link to comment
]2eDeYe Posted October 1, 2007 Report Share Posted October 1, 2007 There's a 'how to' for the KA in 'how to' ;) Quote Link to comment
tnip Posted October 1, 2007 Report Share Posted October 1, 2007 we're supposed to actually look in there for info? Quote Link to comment
