doord521 Posted August 25, 2007 Report Share Posted August 25, 2007 O.K. This is gonna be my build thread so tell me what you think.. I am starting with a 1967 Datsun 520. It is pretty straight with only 1 real cancer spot. The rest you see is actually just lite surface rust that will sand off easily when I get to that point.. Basically my plans for it are to rebuild it to bone stock but be bagged with a real clean setup.. Oh yeah JDM STOCK!!! Here is how it sat when I got it home. Here is a shot of the interior Quote Link to comment
doord521 Posted August 25, 2007 Author Report Share Posted August 25, 2007 Now here are some progress pics from night #1!!!! I switched the guts in the spare steering box and got it mounted to the frame right frame rail. I got the column through the fire wall and into the cab. The dash isn't ready to mount the gauges on the right side yet, they are just mocked in place at the moment. Tomorrow I am going to pull the dash and start on moving the pedals and the clutch and brake cylinders. Quote Link to comment
kansascity1 Posted August 25, 2007 Report Share Posted August 25, 2007 you ain't messin around, huh PA? This isn't the progress I wanna see. I wanna see those fender wells cut out and some pipe being bent god damn it. Quote Link to comment
kansascity1 Posted August 25, 2007 Report Share Posted August 25, 2007 are you gonna be able to just swap the steering linkage around, and use the stock stuff? Let me know man, so maybe I can do it on the 521. You know how we do, gotta have 'em match. Quote Link to comment
Icehouse Posted August 25, 2007 Report Share Posted August 25, 2007 The body looks awesome!! I love rust though :D Quote Link to comment
Pacific coast Datsun Posted August 25, 2007 Report Share Posted August 25, 2007 Looking good. If the RHD swap is possible i may think about it...;) Thats after all my projects are done :D Quote Link to comment
RacnJsn95 Posted August 25, 2007 Report Share Posted August 25, 2007 Wow... You're tearing right into it, that's awesome! Don't run out of steam! Quote Link to comment
doord521 Posted August 25, 2007 Author Report Share Posted August 25, 2007 I won't run out of steam. Quote Link to comment
doord521 Posted August 26, 2007 Author Report Share Posted August 26, 2007 Got a little bit done this afternoon.. Moving the pedals over How the dash is going to look... More to come tonight!!! Quote Link to comment
Pacific coast Datsun Posted August 26, 2007 Report Share Posted August 26, 2007 So the pedal assembly simply bolted onto the right side? if so thats interesting. Dont forget to move the ignition over... :cool: Quote Link to comment
doord521 Posted August 26, 2007 Author Report Share Posted August 26, 2007 It kinda bolts in. You have to drill some holes for the studs and the resivoirs then tweek the top mount and drill some more holes then it bolts in. The gas pedal is another story. You have to make a bracket for it to mount to the firewall. The wipers have to go because of where the steering wheel mount is. There is some trimming involved to get everything to fit back into the dash. Not much just a little bit. I haven't started to run any wires or cables yet should not be to bad. Going to have to get a longer throttle cable Here is where the clutch and brake res will be. I have to get a hole saw still... Here it is with the dash, pedals, steering wheel back in, With the seat in. Yeah I need to pull the other column but it needs to stay in for a bit. You will see why lalter. Quote Link to comment
doord521 Posted August 26, 2007 Author Report Share Posted August 26, 2007 Ok I also had to take car of something this evening. It has been bugging me since I got it home. It just sat way too high... So I cranked the torsions and removed the leaves in the back. I just welded the rear to the frame with the old u bolts. Was going to have to do it down the road anyway for when I build my link for the rear... Quote Link to comment
kansascity1 Posted August 26, 2007 Report Share Posted August 26, 2007 lookin good bro. get to the damn frontend already. I need my shit layed out. Quote Link to comment
Pacific coast Datsun Posted August 26, 2007 Report Share Posted August 26, 2007 Nice progress! A long time ago i saw an S-10 w/ a rhd conversion. They left the stock steering shaft in place but cut it down so it wasnt visible...then welded a sprocket to it & the new shaft & connected them using a chain. Kinda ghetto bu t it worked. What are your plans for the motor? Will you rebuild the J or swap in a L? Quote Link to comment
Icehouse Posted August 26, 2007 Report Share Posted August 26, 2007 Dude I like the truck even more now!!!! Quote Link to comment
]2eDeYe Posted August 26, 2007 Report Share Posted August 26, 2007 To the rails :D Quote Link to comment
datsun dreamer Posted August 26, 2007 Report Share Posted August 26, 2007 Looking good!.....Every truck looks better lowered(IMO)!!!!!!!!!!!!! Quote Link to comment
doord521 Posted August 26, 2007 Author Report Share Posted August 26, 2007 Nice progress! A long time ago i saw an S-10 w/ a rhd conversion. They left the stock steering shaft in place but cut it down so it wasnt visible...then welded a sprocket to it & the new shaft & connected them using a chain. Kinda ghetto bu t it worked. What are your plans for the motor? Will you rebuild the J or swap in a L? Thanks for the compliments everyone...I am planning on rebuilding the j13. I haven't figured out yet if the next step is to bag it or to rebuild the drive train.. Quote Link to comment
fiveoneohray Posted August 26, 2007 Report Share Posted August 26, 2007 all I can say is GANGSTER!!! Quote Link to comment
datzenmike Posted August 26, 2007 Report Share Posted August 26, 2007 Try a throttle cable from a 720 truck it has to reach over to the pass side carb. Maybe one with cruise as it has to reach the pass fender. At first I thought the idea was good but the doing impossible, but I'm glad I was really wrong on that. Different is good. Do you have pictures of a left hand truck to give you ideas of what to do with the wiper? Quote Link to comment
Pacific coast Datsun Posted August 26, 2007 Report Share Posted August 26, 2007 Thanks for the compliments everyone...I am planning on rebuilding the j13. I haven't figured out yet if the next step is to bag it or to rebuild the drive train.. Ok let me know on the engine. I know of an excellent mechanic here in San diego who has been working on Datsuns for a very long time & his prices are reasonable. Quote Link to comment
0.C. Posted August 26, 2007 Report Share Posted August 26, 2007 I thought about making my 521 rhd, but the steering box won't let me. Quote Link to comment
Icehouse Posted August 27, 2007 Report Share Posted August 27, 2007 I thought about making my 521 rhd, but the steering box won't let me. A rack wouldn't fit? Quote Link to comment
doord521 Posted August 27, 2007 Author Report Share Posted August 27, 2007 The 520's and the 521's are the same as far a frame and steering. I think the only difference between the l 521 and the 520 is the front sheet metal. The motor is different for the pl 521. It went up to the 1600 from the 1300.. Quote Link to comment
doord521 Posted August 27, 2007 Author Report Share Posted August 27, 2007 Ok. I got a little done this morning. The brake cyl and the clutch cyl is mounted on the firewall and hooked back up to the pedals. Still need to run two new lines over to them but that is easy. Also I went and picked up some tubing for my front air ride set up. Still have to get ahold of my neighbors bender so I can get started on that. I know I am jumping around a bit but Kansascity1 is doing the same setup in the front on his 521 and he is waiting for me to build him one too. It is easier to just build them both at the same time as it is to build his then build mine in a month when I am ready to bag mine. We are going a little different route with it. The bags are going to be mounted on the upper a arm as to being on the lower. After seeing what airedout went through to bag the front of his we thought this would cure that and also give more lift in the front.. This is what we are going for. Gotta have some of that SoCal Prerunner infuence!! Quote Link to comment
