73 620 Disc Brake Swap
Well I'm gonna do it! Gots all the stuff and now I just need to go build a fire in the garage and tear it up!:D
Heres a list of all the stuff I needed to get and prices:
Custom Brackets (Beebani) $120 shipped
92 Nissan D21 4x4 p.u. Calipers $15 a piece from local junk yard (make sure you get the rubber brake lines too.) I opted to get new fully loaded ones from Autozone for $130 for both with the cores I got from jy -$95:eek: (worth the jy trip)
79 280zx Master Cylinder 15/16" bore. $50 Autozone $20 JunkYard
02 Isuzu Rodeo rotors $40 a piece @ Autozone
So with the new parts and brackets plus the jy core calipers I am into this swap $410. Or you can use the jy calipers maybe get jy rotors and do it 4 a lot cheeper(Ratsun-like):fu:
620goodies002.jpg[/img]
More pics on the install to come:D
  • Replies 87
get lots of pics. Guy that built my engine is going to be doing the swap on his early 70's 620. And link to give him this link.
Larry
Just curious, the parts and pieces will fit a 521 also, right? Any other mods like the bearing issue apply?
Not sure about the 521 swap. Beebani is the one to ask.
I know the person who is behind these brackets knows his stuff and has done this before and maybe I look like a dick for saying so yada yada but...
I really don't like the lack of meat around the caliper mount holes, shockingly thin for no reason.
yea mine arent that thin, an i dont think the second gens were that thin either.. but this is the 3rd gen from what i can tell so im sure he has a reason for it.. maybe aligment with rotor an caliper..
Guest DatsuNoob
Curious why Rodeo rotors and not D21 2wd rotors? I'll be doing mine someday :rolleyes: (too many irons in the fire), keep us posted.
Looks good Doug, damn newspaper stuck to the paint (wasn't cured enough I guess) I see. They looked really good before they went in the box.
Yes, these do fit the 521, 520, and 320. They all use the same spindle casting. The only things that change between them is the inner bearings and the 320 has shorter control arms.
There's still plenty of meat around the caliper bolt holes, 3/16" or so. I like to keep the holes a little oversized (John Deere fit) because of the variances in castings. That way it's a one size fits all. I have seen a few differences between calipers over the years, between brands and years.
For further clarification...
This is the setup that keeps torsion bars and the upper control arms that Beebani also offers are used with mid 80'2 720 parts and eliminate torsions..correct?
for the 521?
should be the same ive noticed when it comes to truck companies dont change things very often my buddy has a 66 chevy pickup and the frame and drivetrain are identical to my 56
Got to the swap today. Didnt even have to start a fire!:D I needed to buy bolts to mount the calipers to the brackets. 12 x 33mm x 1.25 The stock ones of the Hardbody were too long. I was able to re-use the stock 620 bolts to mount the brackets to the hub. It all went pretty smooth except for the clip that holds the brake line to the frame would not work so back to the JY to see if the stock Hardbody ones will fit on the 620 frame. Heres the pics:fu:
DRUM AND HUB OFF READY TO PULL BRAKE ASSEMBLY
READY 4 THE BRACKET:D
BRACKET ON RE-USING STOCK BOLTS
HUB ON
OOOHHHH SHINY:D ROTORS ON (TITE FIT ON ONE SIDE AND SLID RITE ON ON OTHER
BRAKE LINE @ FRAME. STOCK 620 CLIP IS DIFFERENT. COULD GRIND OUT CLIP TO MAKE WORK IF THE D21 CLIP WONT WORK
D21 BRAKE LINE AND STOCK 620 CLIP DONT MESH
STOCK D21 BOLT TOO LONG HAD TO BUY NEW ONES 12 X 33MM X 1.25
ALL BOLTED UP AND PRETTY:D
NOW THATS MORE LIKE IT:cool:
So tomoro its off to the JY to get the D21 brake line clips and then bench bleed the Z master cyl. New stock 620 booster and put it all together, bleed and then take for a test drive. One other concern of mine was the stock 620 studs were kind of short cuz I had to use spacers to get my 15" Frontiers away from the Calipers. About a 1/2" of thread. Is this enuff? Should i get longer studs?
Nice work Doug :D
Those old brakes look good... You should send them to me haha :D
Nice work Doug :D
They are Brand New Jeffery. If you need them I can bring them to GoldenGardens later this month. I want to keep the drums tho:fu:
haha :D
I did the reverse, now I have drums on my truck :( On top of it they don't work!! :( I don't think the datto ones will fit though :(
Yeah Golden gardens!!! I can't wait!
