KELMO Posted January 8, 2024 Report Share Posted January 8, 2024 To which Missus Kelmo responded; that is what happens when you put something on your trailer, dumbass. Anywho...acquired this over the weekend. She needs some help but I may be able to get it running and driving sooner rather than later. Which, historically, for me means sometime in the next 10 years. Needs that it has for the sooner; Windshield and weatherstrip Back glass weatherstrip Battery and battery hold down There are some wiring issues in the cab that someone along the line started to "fix" but didn't understand the meaning of the word fix 8 Quote Link to comment
iceman510 Posted January 8, 2024 Report Share Posted January 8, 2024 Nice. I still lust after 521s occasionally, but have to get my 620 going first. Quote Link to comment
Stoffregen Motorsports Posted January 8, 2024 Report Share Posted January 8, 2024 Love the Escalade wheels. Quote Link to comment
datzenmike Posted January 8, 2024 Report Share Posted January 8, 2024 Amazon has 521 battery hold downs for $9... https://www.amazon.ca=1 1 1 Quote Link to comment
KELMO Posted January 8, 2024 Author Report Share Posted January 8, 2024 1 hour ago, Stoffregen Motorsports said: Love the Escalade wheels. I had nothing to do with that.😜 1 Quote Link to comment
KELMO Posted January 8, 2024 Author Report Share Posted January 8, 2024 59 minutes ago, datzenmike said: Amazon has 521 battery hold downs for $9... https://www.amazon.ca=1 Bro, I got plenty of those ppppffffttttt. 1 Quote Link to comment
pidge Posted January 9, 2024 Report Share Posted January 9, 2024 Looks pretty straight. Not bad looking at all. -Pidge Quote Link to comment
KELMO Posted January 9, 2024 Author Report Share Posted January 9, 2024 1 hour ago, pidge said: Looks pretty straight. Until you get up close, but I got a couple like that. 1 Quote Link to comment
bilzbobaggins Posted January 9, 2024 Report Share Posted January 9, 2024 On 1/8/2024 at 9:54 AM, KELMO said: To which Missus Kelmo responded; that is what happens when you put something on your trailer, dumbass. Anywho...acquired this over the weekend. She needs some help but I may be able to get it running and driving sooner rather than later. Which, historically, for me means sometime in the next 10 years. Needs that it has for the sooner; Windshield and weatherstrip Back glass weatherstrip Battery and battery hold down There are some wiring issues in the cab that someone along the line started to "fix" but didn't understand the meaning of the word fix Whats up with the strap around the doors and roof? Doors do not latch? Looks like fun tho. 1 Quote Link to comment
KELMO Posted January 10, 2024 Author Report Share Posted January 10, 2024 16 hours ago, bilzbobaggins said: Whats up with the strap around the doors and roof? Doors do not latch? Looks like fun tho. I wasn't comfortable with the way it closed before I loaded it on the trailer. I put the strap on as a precautionary measure. I really did not want to add 1 more thing to do to this truck. Quote Link to comment
KELMO Posted January 11, 2024 Author Report Share Posted January 11, 2024 So, the first thing to fix (or break) is the hood latch. I did a little bending and the release tab was still interfering with the lip on the hood, so hey, let's take it off. Used a bunch of PB blaster and got one of them off after a bit of futzing. Seems I should have futzed with the other one a little more...snapped the bolt head off. Easy outs, drill bits, here I come. 2 Quote Link to comment
Slow Loris Posted January 13, 2024 Report Share Posted January 13, 2024 I did the same thing to my 521 about 33 seconds after getting it home. So I can say from experience the latch stays on real tight with only the one bolt in there… Quote Link to comment
KELMO Posted January 20, 2024 Author Report Share Posted January 20, 2024 (edited) So, the hood latch is fixed...for now. Next up, I tried to push it out of the shop and it would go about 4 feet then stop. What the French, toast(or WTF). So up on the jack stands and all of the wheels move freely with the exception of the right front. Now that it has no load on it, it doesn't move at all. Read through some of the brake threads and learned a thing or two. For starters, the adjuster on the right front won't adjust. I have PB blasted it and will continue tomorrow. Some of the threads I read seemed to indicate if you take off the axle nut you can pull the whole assembly off. I will attempt that as a last resort but would prefer not doing that because I am not sure how well that will end for me. On an up side, it did start and run...briefly so I got that going for me. I'll drain the gas tank tomorrow and maybe some other stuff I should do while it is up on stands. I would post some pics but am fairly sure all ya'll know what brake drums look like. Edited January 21, 2024 by KELMO Quote Link to comment
KELMO Posted January 26, 2024 Author Report Share Posted January 26, 2024 After a couple days of PB blaster and a whole bunch of love taps, the right front wheel now moves freely. Now since the weather is going to get a little better next week, I can push it out and power wash the engine bay. Then it's time to look at the wiring for the ignition switch. It has an aftermarket 4 pin switch, and I am not sure that is going to work. From what I have been able to find it should be a 5 pin. 2 Quote Link to comment
KELMO Posted February 11, 2024 Author Report Share Posted February 11, 2024 (edited) Ended up pulling the Rt Front hub, cleaned, regreased etc. this was done by my cousin. The engine bay and bed of the truck have been power sprayed. Finally got to drive it. Decided on just a quick shot around the block and almost made it. 3 houses down from mine it crapped out on me. Possibly lack of fuel. Didn't futz with it much more that day as the brakes needed to be bled. Missus Kelmo helped me with that that on Friday. The left front will not engage so that will have to be investigated. The electric fuel pump sounded like it was beating itself to death, so a new mechanical one has been installed. I took pics but am having issues moving them from the phone to the computer so maybe later. Edited February 19, 2024 by KELMO 1 Quote Link to comment
KELMO Posted February 19, 2024 Author Report Share Posted February 19, 2024 The aforementioned mechanical fuel pump. Imgr changed up some stuff and I have yet to figure out how to resize pics. 3 Quote Link to comment
KELMO Posted February 22, 2024 Author Report Share Posted February 22, 2024 Drove it again and this time it made it all the way around the block. Took off the L/F drum and it appears the wheel cylinder is done for. My cousin spent a fair amount of time unravelling the dash harness. I don't have a pic just now but it looked like they wadded it up and stuffed it where the glove box should be. 1 Quote Link to comment
KELMO Posted March 8, 2024 Author Report Share Posted March 8, 2024 Replaced the L/F wheel cylinder and now all 4 corners brake. Replaced the rear glass weatherstrip. Got one from vintage rubber and it worked out quite well. Checked compression and I think we are between 100 and 120 psi. I also think I need a new gauge. Seems like the previous owner may have thought TDC meant the crankshaft pulley should be in the center of the motor. Yes, it was advanced just about 3 inches give or take. We retimed it but did not get to give her a rip around the block because it started snowing this afternoon...it was 55 degrees and sunny around noon today. The windshield has arrived and just waiting on the weatherstrip. I should take some pictures and maybe post 'em. 2 Quote Link to comment
KELMO Posted April 1, 2024 Author Report Share Posted April 1, 2024 (edited) Test image since Imgur went and changed the way their site works. Edit: Dammit, still gotta figure out the sizing bit. Edited April 1, 2024 by KELMO Quote Link to comment
EDM620 Posted April 1, 2024 Report Share Posted April 1, 2024 On 1/8/2024 at 7:54 AM, KELMO said: Windshield and weatherstrip What's your source for the windshield? I had a bit of a challenge finding a new one for my 620 Quote Link to comment
KELMO Posted April 1, 2024 Author Report Share Posted April 1, 2024 Vintageglass.com Fairly certain it was in a warehouse local to me ( +/- 50 miles). I picked it up just a couple days after I placed the order. The plan is to install it later this week. The weatherstrip came from Vintage Rubber. I ordered the windshield, back glass, and the vent weatherstrips. So far have only installed the back glass and the fit was very good. Quote Link to comment
EDM620 Posted April 1, 2024 Report Share Posted April 1, 2024 5 hours ago, KELMO said: Vintageglass.com Thanks checking it out. I pick up my 620 glass Friday so at least I'll have a comparison price Quote Link to comment
KELMO Posted February 16, 2025 Author Report Share Posted February 16, 2025 So, I have come back around to this thing again. The doors have been mostly disassembled and since it has been a good minute, I'm not sure what process I should follow to put all of the guts back together. Window regulator inside, then the glass and attach to the regulator, and then put the vent glass in. The regulator will need to be as close to the bottom of the door shell as possible in order to get the glass in and then manipulate the vent glass assembly around all that. All I can really remember is it being a bitch kitty to get it all out. Thoughts? Quote Link to comment
EDM620 Posted February 16, 2025 Report Share Posted February 16, 2025 It has been too long for me to remember the order and I'm not at that point ATM, but soon I hope. I'm waiting for my body guy to have the time to swap the door skins then I'll be ready to do the same reassembly. New aftermarket skins don't have the reinforcing bars attached so that needs doing. Kinda thinking to put the glass in first for the available space, but the damn window regulator is a challenge. Quote Link to comment
KELMO Posted February 16, 2025 Author Report Share Posted February 16, 2025 Yes, I recall the regulator being less than fun. Quote Link to comment
