frankendat Posted June 14, 2023 Report Share Posted June 14, 2023 (edited) I purchased a set of Toyota wheels for my 84 kc this winter and am preparing to Cerakote them black. The center caps are bringing questions that I cannot answer and I am hopeful these bridges have been crossed by a fellow Ratsuner. First pic is wheel with center piece Second pic is wheel with center piece removed and I am pointing to "extensions" that help hold the center piece. These extensions appear to be part of the wheel. Third pic the distance between extensions is 3.57 (90mm) Fourth pic center bore of wheel is just over 4in Fifth pic the plastic center (with the Toyota logo) to be removed and replaced needs to be between 63mm and 80mm Edited June 14, 2023 by frankendat 3.57 not 3.75 Quote Link to comment
frankendat Posted June 14, 2023 Author Report Share Posted June 14, 2023 One of the pics posted out of order. My questions concern what I call the extensions. Will the extensions clear the front hubs? If not, do the extensions pop off, hammer off or do they need to be ground down? For the rear, the plan is to bore the Toyota centers out of the center pieces and replace/epoxy Nissan centers. This is me asking before just grabbing a BFH Quote Link to comment
thisismatt Posted June 14, 2023 Report Share Posted June 14, 2023 They...look like part of the casting? 1 Quote Link to comment
NC85ST Posted June 14, 2023 Report Share Posted June 14, 2023 11 hours ago, frankendat said: Will the extensions clear the front hubs? Best way to know is to pull your front wheel off and see if you have any issues mounting the Toyota wheel on the hub. If there are problems with clearance then you can determine what the best course would be. I personally would not be taking a hammer to my wheels. 1 Quote Link to comment
frankendat Posted June 14, 2023 Author Report Share Posted June 14, 2023 5 hours ago, thisismatt said: They...look like part of the casting? That is my dilemma. The "extensions" look like part of the casing, but they are the same color as the plastic centerpiece and the plastic centerpiece snaps over them. I looked and attempted to remove them with a flat head screwdriver, but quickly realized the force necessary to move them would damage the wheel, if they are part of the casing. Quote Link to comment
frankendat Posted June 14, 2023 Author Report Share Posted June 14, 2023 5 hours ago, NC85ST said: Best way to know is to pull your front wheel off and see if you have any issues mounting the Toyota wheel on the hub. If there are problems with clearance then you can determine what the best course would be. I personally would not be taking a hammer to my wheels. As is often the case, I am working on a particular part while my truck is a couple hundred miles away. As for a hammer, I use it as a general term. I have a talent for deconstruction and enough tools/machines to destroy nice things, but your point is well taken. Quote Link to comment
thisismatt Posted June 14, 2023 Report Share Posted June 14, 2023 You could machine them yourself with a router if necessary 1 Quote Link to comment
frankendat Posted June 14, 2023 Author Report Share Posted June 14, 2023 48 minutes ago, thisismatt said: You could machine them yourself with a router if necessary We are of like mind. You wouldn't happen to have the diameter measurement of the hole needed to clear the front manual locking hub on a 84KC? Quote Link to comment
thisismatt Posted June 14, 2023 Report Share Posted June 14, 2023 4 hours ago, frankendat said: We are of like mind. You wouldn't happen to have the diameter measurement of the hole needed to clear the front manual locking hub on a 84KC? No sir 1 Quote Link to comment
Stoffregen Motorsports Posted June 14, 2023 Report Share Posted June 14, 2023 Toyota 6 lug truck wheels almost always have the large center bore, which will fit over any hub out there. I think it's 4.125", or maybe 4.250" 1 Quote Link to comment
620slodat Posted June 14, 2023 Report Share Posted June 14, 2023 In the pic it looks like 4 inches, plus the curvature of the hole, is the diameter of the hole dimension. I don't know Toyota wheels, or Datsun wheels for that matter, but 4 plus inches, with the "extensions" making that less than 4 inches is what it looks like to me. If 4 1/32 is the dimension of the hole then it is 102.4 millimeter. Don 2 Quote Link to comment
frankendat Posted June 15, 2023 Author Report Share Posted June 15, 2023 2 hours ago, thisismatt said: No sir Rats Quote Link to comment
frankendat Posted June 15, 2023 Author Report Share Posted June 15, 2023 2 hours ago, Stoffregen Motorsports said: Toyota 6 lug truck wheels almost always have the large center bore, which will fit over any hub out there. I think it's 4.125", or maybe 4.250" You speak truth, it was a bit over 4" on my tape, my caliper wouldn't fit inside the wheel. But... 1 hour ago, 620slodat said: In the pic it looks like 4 inches, plus the curvature of the hole, is the diameter of the hole dimension. I don't know Toyota wheels, or Datsun wheels for that matter, but 4 plus inches, with the "extensions" making that less than 4 inches is what it looks like to me. If 4 1/32 is the dimension of the hole then it is 102.4 millimeter. Don Yes that is my concern. In the picture with the calipers, the narrowest parts measure roughly 3.57" a smidge over 90mm. The reduction only appears at the outside of the center hole at the "extensions". It was my hope someone had dealt with rims like these and would tell the secrets. 1 Quote Link to comment
frankendat Posted June 15, 2023 Author Report Share Posted June 15, 2023 (edited) In other wheel news, went to the pick and pull and scored some late model Nissan center caps, for the rear wheels-No charge. Plan to drill out the Yota logo, on the rear wheel caps, and replace with the fake chrome Nissan center caps. The combo should pop when the center piece and wheel are coated matching black. I picked up three center caps because of my habit of screwing up the first attempt. Edited June 15, 2023 by frankendat extra words 1 Quote Link to comment
Thomas Perkins Posted June 15, 2023 Report Share Posted June 15, 2023 (edited) I put Toyota rims on my 85 4x4 back in 2000,and the center caps was a hair to thick on the front cause of the 4x4 hubs. I got my Drexel tool and grinded it out in the center.They just popped in,you could pull them out.I sold them a few years ago and bought brand new ones made by American Racing,you can see my old Toyota Rims on my page.The rims I bought only came with 2 center caps cause Toyota 4x4's are manual locking hubs and front don't have any on them.They also came on the 4 runners, you can see them on my page.They had 31 tires on them that scrubbed real bad so I sold the tires and put 235-75-15 on them rims.That is what is on my American Racing rims now.They fit perfect.I bought 5 tires and rims.They were aluminum and they needed cleaning and the plastic hubs were not looking good.A guy with a 95 Nissan bought them from me.Nissan and Toyota lug nuts won't swap out.Different thread pattern. Edited June 15, 2023 by Thomas Perkins 2 Quote Link to comment
Stoffregen Motorsports Posted June 16, 2023 Report Share Posted June 16, 2023 Right. Nissan generally uses a 1.25 thread pitch and Toyota uses 1.5. 1 Quote Link to comment
frankendat Posted June 19, 2023 Author Report Share Posted June 19, 2023 On 6/16/2023 at 9:25 AM, Stoffregen Motorsports said: Right. Nissan generally uses a 1.25 thread pitch and Toyota uses 1.5. I found that out. What a bummer, the guy I bought the Toy rims from, threw in a box of lugs. 1 Quote Link to comment
Thomas Perkins Posted June 19, 2023 Report Share Posted June 19, 2023 If you need Acorn lug nuts ,Ebay has 24 for 19.95.I bought a extra set awhile back from them.My new rims came with them.I have a extra set. 1 Quote Link to comment
frankendat Posted June 19, 2023 Author Report Share Posted June 19, 2023 Mighty kind Mr. Perkins, but shipping would likely cost more than a set. Shipping has really taken the "bargain" out of bargain shopping 1 Quote Link to comment
frankendat Posted June 19, 2023 Author Report Share Posted June 19, 2023 Not much but progress nonetheless. Quick question to help talk me out of something I really want to do. Anyone have first hand or direct experience with heat on plastic wheel caps? The bake on Cerakote is stronger than the air cure and it has a slightly different hue. I think 250 degrees for 2 hours will turn the plastic center caps into modern art, but I am on the fence; it gets plenty hot next to black asphalt on a summer day and caps survive, even in AZ. What do you think? Quote Link to comment
Thomas Perkins Posted June 20, 2023 Report Share Posted June 20, 2023 There are some some on Ebay for 23.49,plus free shipping,just like I have.12x 1.25Chrome.I think I paid 19.95 for mine but prices have went up.Here is what it is listed under.24pc OE Mag Style with washer 12x1.25 for Infiniti Silver .The Toyota rims I had were enkei. 1 Quote Link to comment
Stoffregen Motorsports Posted June 20, 2023 Report Share Posted June 20, 2023 I just googled "plastic melting temp" and found this - https://www.plastikcity.co.uk/useful-stuff/material-melt-mould-temperatures 1 Quote Link to comment
frankendat Posted June 20, 2023 Author Report Share Posted June 20, 2023 14 hours ago, Thomas Perkins said: There are some some on Ebay for 23.49,plus free shipping,just like I have.12x 1.25Chrome.I think I paid 19.95 for mine but prices have went up.Here is what it is listed under.24pc OE Mag Style with washer 12x1.25 for Infiniti Silver .The Toyota rims I had were enkei. Thank you for taking the time to look. Besides, everybody, including me liking new shiny things, is there a benefit to new lugs over old? At the Pick and Pull they are a dollar per. 1 Quote Link to comment
frankendat Posted June 20, 2023 Author Report Share Posted June 20, 2023 3 hours ago, Stoffregen Motorsports said: I just googled "plastic melting temp" and found this - https://www.plastikcity.co.uk/useful-stuff/material-melt-mould-temperatures I'm SOLD. I wanted to try baking the parts, just needed a little nudge. Time to get the plastic bits media blasted, sprayed and baked. Thank you for looking into it. 1 Quote Link to comment
thisismatt Posted June 20, 2023 Report Share Posted June 20, 2023 Wheels can get quite hot with heavy braking also 1 Quote Link to comment
