DARIN 510 Posted December 20, 2022 Author Report Share Posted December 20, 2022 On 12/18/2022 at 6:54 AM, datzenmike said: I would remove and totally rust proof the cowl drain holes. I did paint Por15 in the cowl drain area as much as I could reach. Quote Link to comment
DARIN 510 Posted December 20, 2022 Author Report Share Posted December 20, 2022 14 hours ago, datzenmike said: Por15? one of those rust converters? Oh that stuff. I’m trying to make this build budget friendly. Quote Link to comment
Stoffregen Motorsports Posted December 22, 2022 Report Share Posted December 22, 2022 Do a google search for generic POR15 or something similar. I know other paint products utilize the same properties as name brand POR 15 and are a lot less costly. I can't remember any brand names, but I looked into this years ago and found a few other products that do the same thing. Quote Link to comment
jagman Posted December 22, 2022 Report Share Posted December 22, 2022 I use Zero-Rust. You can paint over it after 30 days cure time just like any other primer. 2 Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 Picked up a dogleg 5 speed a few weeks ago. did some deep cleaning. Changed the front and rear seal with factory Nissan seals. Painted the front cover. 3 Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 Also got some parts back from powder coating. Made some custom t/c rods. Fresh poly bushings for the control arms from suspension techniques. Cleaned up the ball joints and installed factory boots. The original boots were hard as a rock. Previous owner also swapped for 14mm ball joints score! I should’ve taken before pics but you guys know how old suspension looks lol. 1 Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 Welded up this haggard garbage that somebody used sheet metal shears for a 280 ZX trans sense a dog leg is going in. 3 Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 Came across this item at Harbor freight. My brain started getting creative. So I thought I would give this a try for the throttle cable conversion. Turns out it is the exact same size as the whole for the hole in the firewall. 7 Quote Link to comment
iceman510 Posted March 7, 2023 Report Share Posted March 7, 2023 Hmmm, interesting. Quote Link to comment
Stoffregen Motorsports Posted March 7, 2023 Report Share Posted March 7, 2023 12 hours ago, DARIN 510 said: Be careful of the dowel pin stuck in the top of the bellhousing. It is supposed to stay with the block. 1 Quote Link to comment
Stoffregen Motorsports Posted March 7, 2023 Report Share Posted March 7, 2023 Parts look great. Did you powder coat the balljoint too? Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 5 hours ago, Stoffregen Motorsports said: Be careful of the dowel pin stuck in the top of the bellhousing. It is supposed to stay with the block. Good eye. Thank you for the heads up 1 Quote Link to comment
DARIN 510 Posted March 7, 2023 Author Report Share Posted March 7, 2023 5 hours ago, Stoffregen Motorsports said: Parts look great. Did you powder coat the balljoint too? No. That I used VHT epoxy paint. 1 Quote Link to comment
Stoffregen Motorsports Posted March 8, 2023 Report Share Posted March 8, 2023 17 hours ago, DARIN 510 said: No. That I used VHT epoxy paint. Looks perfect. Quote Link to comment
DARIN 510 Posted March 17, 2023 Author Report Share Posted March 17, 2023 Made this little guy today. Took an old 240z shift knob and lathed down the center part of the shift pattern. It was horribly cracked. Found a guy on eBay that makes 3D gel stickers. Here is the expired link of the item if any of you are interested. https://www.ebay.com/itm/394472781683?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=botATqInRc-&sssrc=2349624&ssuid=BS1r6XtJR9S&var=&widget_ver=artemis&media=COPY 5 Quote Link to comment
DARIN 510 Posted March 30, 2023 Author Report Share Posted March 30, 2023 Worked on the seat upholstery the past couple days since it’s been raining. Mrfiveoneoh was nice enough to give me his old ones. Still working on the upper half. Quote Link to comment
iceman510 Posted March 30, 2023 Report Share Posted March 30, 2023 Lots of wrinkles. Maybe try pulling the cover tighter at the rear metal rail when hog ringing it. Quote Link to comment
DARIN 510 Posted March 30, 2023 Author Report Share Posted March 30, 2023 7 hours ago, iceman510 said: Lots of wrinkles. Maybe try pulling the cover tighter at the rear metal rail when hog ringing it. Yah I got out some of the wrinkles with a heat gun. But some of it the vinyl is really stiff. It is used so I can only get it so good. It’s good enough for this car. Quote Link to comment
DARIN 510 Posted March 30, 2023 Author Report Share Posted March 30, 2023 Finished the upper half today. A lot better than what it had. The very top is separating at the stitching. I might throw some random stitches at it to kind of keep it together. 2 Quote Link to comment
DARIN 510 Posted March 30, 2023 Author Report Share Posted March 30, 2023 The first two pictures are supposed to be swapped. The car came with the blanket on it. And the blue upholstery was what was underneath it. 1 Quote Link to comment
five1oh Posted April 18, 2023 Report Share Posted April 18, 2023 so much better! Glad you wanted to repurpose my old seat covers 🙂 Looking good drive it to Datslocos 😂 1 Quote Link to comment
DARIN 510 Posted April 20, 2023 Author Report Share Posted April 20, 2023 On 4/18/2023 at 7:55 AM, five1oh said: so much better! Glad you wanted to repurpose my old seat covers 🙂 Looking good drive it to Datslocos 😂 I’m not there yet lol. Still gotta get the the bay painted 1 Quote Link to comment
DARIN 510 Posted May 23, 2023 Author Report Share Posted May 23, 2023 Well guys. Today the engine bay is going to get painted. So here is the before pics for now. Took care of all the rusted areas. I will report back once it’s painted. Enjoy 2 Quote Link to comment
DARIN 510 Posted May 26, 2023 Author Report Share Posted May 26, 2023 And now we have paint !!! 4 Quote Link to comment
DARIN 510 Posted May 26, 2023 Author Report Share Posted May 26, 2023 And with black out. 6 Quote Link to comment
