datzenmike Posted July 4, 2022 Report Share Posted July 4, 2022 1 minute ago, Markimusprime56 said: Where is a reputable company to buy a timing kit from? I plan on replacing everything it’s what I do. I don't know but anything from or made in Japan is quality. Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 1 minute ago, datzenmike said: I don't know but anything from or made in Japan is quality. Thank you for all the replies Mike Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 This is the color I bought for it. But added .5g of copper, gold, and bronze flake to the 2nd stage. 2 Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 Anyone used this kit before? 1 Quote Link to comment
datzenmike Posted July 4, 2022 Report Share Posted July 4, 2022 You already have the Weber. This is only part of the equation.... no turbo or turbo manifold or waste gate, or way to regulate boost pressure, or ignition retard or half a dozen other things to make this work and stay together. Some other things to think about are an oil cooler and O ringing the block. The ring end gap needs to be wider if boosting. It's endless really the stuff you have to do to keep from blowing up your engine with a turbo. If you want 150 hp the easy way, and cheaper and will last forever, is a KA24DE swap. 2 Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 24 minutes ago, datzenmike said: You already have the Weber. This is only part of the equation.... no turbo or turbo manifold or waste gate, or way to regulate boost pressure, or ignition retard or half a dozen other things to make this work and stay together. Some other things to think about are an oil cooler and O ringing the block. The ring end gap needs to be wider if boosting. It's endless really the stuff you have to do to keep from blowing up your engine with a turbo. If you want 150 hp the easy way, and cheaper and will last forever, is a KA24DE swap. I do have quite a bit of turbo parts from my foxbody making it NA again and a few projects from the past so I really only need a manifold or a blank flange and make one. I’m very good with a Tig with any material. I’m really just asking if anyone has had experience with that kit.. as far as ignition goes if I have to I’ll pull the crank trigger I have off the shelf and put all my msd boost crap on it. I’m just curious tbh. the only real thing I know about a Datsun is what I’ve read I know no one that does so if I ask random off the wall question about parts or part companies that’s just for info.. also I drove a 93 300z to HS still have my prom pics in it 😁 1 Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 13 hours ago, ]2eDeYe said: Welcome, you should be able to upload pics directly after a few more posts. 🙂 Don’t know how I missed this. Thank you! 1 Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 53 minutes ago, datzenmike said: I don't. Could I use the auto I have with a KA? Quote Link to comment
datzenmike Posted July 4, 2022 Report Share Posted July 4, 2022 As is? no. KAs also have automatics. Quote Link to comment
Markimusprime56 Posted July 4, 2022 Author Report Share Posted July 4, 2022 7 hours ago, datzenmike said: As is? no. KAs also have automatics. I’ll keep her stock for now then lol. I’d like to find a 2door 510 to hotrod. Quote Link to comment
rosso Posted July 4, 2022 Report Share Posted July 4, 2022 Our cars are almost twins - Paint code 906 Safari Brown? New hatch vents - metal repros VG33 with carb I took the bumper overiders off and sold them at Powerland this year and bought the hatch vents. 🙂 You can see more info and pics on my project thread: '72 510 Goon - Prova - because it will be a test. I love the car, lots of other upgrades - you will love yours too. I look forward to seeing your progress and welcome to the forum. 4 Quote Link to comment
Crashtd420 Posted July 4, 2022 Report Share Posted July 4, 2022 12 hours ago, Markimusprime56 said: Rods are Same as stock so this will work? Be aware the rods your going to use float the wrist pin and uses clips to retain them in the piston. The stock presses the pin into the rod and floats the piston.. so you'll need a floating piston that has retainers. 2 Quote Link to comment
datzenmike Posted July 4, 2022 Report Share Posted July 4, 2022 Boner-licious!!!! 3 Quote Link to comment
Markimusprime56 Posted July 5, 2022 Author Report Share Posted July 5, 2022 On 7/4/2022 at 2:47 AM, rosso said: Our cars are almost twins - Paint code 906 Safari Brown? New hatch vents - metal repros VG33 with carb I took the bumper overiders off and sold them at Powerland this year and bought the hatch vents. 🙂 You can see more info and pics on my project thread: '72 510 Goon - Prova - because it will be a test. I love the car, lots of other upgrades - you will love yours too. I look forward to seeing your progress and welcome to the forum. This absolutely made my day! Beautiful car man! I do believe I’m gonna throw out the idea of the pearl paint and go back to stock. I had no clue that was the color I’ve been trying every orange in the book to find out it’s brown 😂😂 1 Quote Link to comment
Markimusprime56 Posted July 5, 2022 Author Report Share Posted July 5, 2022 On 7/4/2022 at 8:36 AM, Crashtd420 said: Be aware the rods your going to use float the wrist pin and uses clips to retain them in the piston. The stock presses the pin into the rod and floats the piston.. so you'll need a floating piston that has retainers. Noted! Thank you very much! Quote Link to comment
Crashtd420 Posted July 5, 2022 Report Share Posted July 5, 2022 (edited) 44 minutes ago, Markimusprime56 said: Noted! Thank you very much! Another little side note.... be careful using a dome piston.... flat tops would be best for what your doing... This is for the L16 right? I actually built my l16 up and have similar rods with wiseco 9cc dome pistons on them and they actually hit the head. I did switch to a w53 peanut head but I had to do alot of clearancing to make it work and ended up opening the chambers up 2cc.. If you're increasing compression with the piston a peanut head would be alot better than the stock 210 head. Bigger valves, runners and combustion area and with flat tops you get a nice quench area.. A peanut head is 41cc and the stock 210 is 38.5.... Edited July 5, 2022 by Crashtd420 1 Quote Link to comment
banzai510(hainz) Posted July 5, 2022 Report Share Posted July 5, 2022 (edited) it your motor dont have alot of miles I would just get a slack side guide and the tensioner. alot of the kits out there are not the greatist. .The Tsubaki(Camllia is something like that) kit is the best. OSK was good soem better than others. Do NOT buy the Cloyes or Mellig versions. If you only got 70k I would not worry about this!!!!!!!!!!!take my advice dont chainge it, here is a good Japan water pump get these not the CHINESE ones out there https://www.ebay.com/itm/372989962803?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true https://www.summitracing.com/parts/asn-wpn-032?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+A&utm_term=4582214710515809&utm_content=GSAPI+5ba100b6d97ba Edited July 5, 2022 by banzai510(hainz) 3 Quote Link to comment
Markimusprime56 Posted July 7, 2022 Author Report Share Posted July 7, 2022 On 7/5/2022 at 2:59 PM, Crashtd420 said: Another little side note.... be careful using a dome piston.... flat tops would be best for what your doing... This is for the L16 right? I actually built my l16 up and have similar rods with wiseco 9cc dome pistons on them and they actually hit the head. I did switch to a w53 peanut head but I had to do alot of clearancing to make it work and ended up opening the chambers up 2cc.. If you're increasing compression with the piston a peanut head would be alot better than the stock 210 head. Bigger valves, runners and combustion area and with flat tops you get a nice quench area.. A peanut head is 41cc and the stock 210 is 38.5.... I’m probably just gonna bring her back stock. I’ve enjoyed how these things run as is and I’m sure it gets great mpgs these days. I’m more less on the line of getting it completed then go from there. I’ve been on a hunt for a header lately since the manifold I have is pretty pretty much crap and might as well since I’m there 🤘🤘 thanks for all the tips I’ll definitely keep them for the future wherever it leads to! Quote Link to comment
Markimusprime56 Posted July 7, 2022 Author Report Share Posted July 7, 2022 (edited) On 7/5/2022 at 4:27 PM, banzai510(hainz) said: it your motor dont have alot of miles I would just get a slack side guide and the tensioner. alot of the kits out there are not the greatist. .The Tsubaki(Camllia is something like that) kit is the best. OSK was good soem better than others. Do NOT buy the Cloyes or Mellig versions. If you only got 70k I would not worry about this!!!!!!!!!!!take my advice dont chainge it, here is a good Japan water pump get these not the CHINESE ones out there https://www.ebay.com/itm/372989962803?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true https://www.summitracing.com/parts/asn-wpn-032?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+A&utm_term=4582214710515809&utm_content=GSAPI+5ba100b6d97ba Eh, I’m not going to run bearings/rings and gasket in a motor that’s been sitting since 96. I’ll keep the stuff as a spare since it’s still new looking and looks good with bore gauges.. under torque.Some may but I’m not that guy. I’ve got a new water pump for it not a reman. If it craps on me I appreciate it! I just picked up a oem 89 oil pump off a ka. It’s getting there I’ll have the motor assembled in a few weeks. Edited July 7, 2022 by Markimusprime56 Quote Link to comment
Markimusprime56 Posted July 7, 2022 Author Report Share Posted July 7, 2022 (edited) I’m not new at turning wrenches 👌I promise you all will like 😁 Edited July 7, 2022 by Markimusprime56 2 Quote Link to comment
datzenmike Posted July 7, 2022 Report Share Posted July 7, 2022 48 minutes ago, Markimusprime56 said: I’m probably just gonna bring her back stock. I’ve enjoyed how these things run as is and I’m sure it gets great mpgs these days. I’m more less on the line of getting it completed then go from there. I’ve been on a hunt for a header lately since the manifold I have is pretty pretty much crap and might as well since I’m there 🤘🤘 thanks for all the tips I’ll definitely keep them for the future wherever it leads to! Don't waste your time and money on a header. The stock manifold is good to 150 hp before a header has any significant advantage. Header... Noisy Expensive Leak at collector or gasket Hotter under hood temperatures Always rust in a few weeks and rust out in a few years. Say they fit but never do perfectly. Even on a mildly worked engine don't do anything because the stock manifold is good enough. Only good thing about a header is they are lighter. KA oil pump the best thing for an old engine. I always run them on my Datsuns. 2 Quote Link to comment
banzai510(hainz) Posted July 7, 2022 Report Share Posted July 7, 2022 9 hours ago, Markimusprime56 said: Eh, I’m not going to run bearings/rings and gasket in a motor that’s been sitting since 96. OK I had a 200k motor and it just need a polish and std size bearings. Im sure a 70k motor will be fine. I can see a regasket. personally I would just do a L20 then if your going to waist time opening up a L16 1 Quote Link to comment
datzenmike Posted July 7, 2022 Report Share Posted July 7, 2022 If 70k.... and just 'rebuilt' it should be running tip top. Looking at the condition of the deposits on the cam towers and the rods and inside of the crank case either 170k or never had an oil change, or both. Quote Link to comment
Markimusprime56 Posted July 8, 2022 Author Report Share Posted July 8, 2022 (edited) Fixing to dip the base plate and get everything with the carburetor back together Edited July 8, 2022 by Markimusprime56 2 Quote Link to comment
