edekalil Posted November 23, 2020 Report Share Posted November 23, 2020 (edited) Before I go any further, Got the cam towers seated on head and cam in lubed up with oil and the cam can be turned by hand, it feels snug. Now for the tower bolts, should they get some anti seaz or oil before inserting and torking. Any suggestions on how to tork the cams towers. The book says 25-33 ft pounds. Soon as I get past this part the head will go on the motor and any suggestions on torking it is welcomed then the rest of the parts put on and all get lined up and pull the timing gear and install it back on with the chain and hopefully off to the races. Please forgive the mess on my guitar fixing bench, the head and it's parth are all safe and clean. Edited November 23, 2020 by edekalil Quote Link to comment
banzai510(hainz) Posted November 23, 2020 Report Share Posted November 23, 2020 cam tower bolts are like 10-13pounds if that and they strip out EZ BE CAREFULL. You sure that isn't inch pounds not foot pounds???????????? Im going by memory but Im sure it isn't 30 ft pounds 1 Quote Link to comment
edekalil Posted November 23, 2020 Author Report Share Posted November 23, 2020 27 minutes ago, banzai510(hainz) said: cam tower bolts are like 10-13pounds if that and they strip out EZ BE CAREFULL. You sure that isn't inch pounds not foot pounds???????????? Im going by memory but Im sure it isn't 30 ft pounds Gotcha Quote Link to comment
edekalil Posted November 23, 2020 Author Report Share Posted November 23, 2020 (edited) Here is the info from how to rebuild your nissan Datsun ohc engine I didn't see about putting anything on the threads when installing. I guess the 25-33ft-lb might not be right well see. I sure don't want to mess up at this point. Edited November 23, 2020 by edekalil Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 Well I read on a forum somewhere around 05 people talking about what your saying about 10-13 lb I think they where saying go no more than 15 lb but I for sure do not want to screw it up. Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 Check the cam turns only after tightening it down. I'd go on the low side 10-12. It's not going anywhere with a head bolt through each tower. 1 Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 Will do how about the bolt threads no oil or anti seize? Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 I guess anti seize wouldn't hurt. In the future try to avoid ever taking the towers off the head. 1 Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 (edited) The last head I had a valve fixed the people didn't, I didn't know this fella was going to take them off so from know on I know to tell them not to take them off. So tomorrow the journey begins. Let's see how far I get and thanks again for the experienced know how I can use it. Edited November 24, 2020 by edekalil Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 If the head were to be planed you might have to. 1 Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 I'll post a pic of the cam tower he broke, not sure how he did it. I would have preferred he left them on and not mess with them but too late now. Y'all cross your fingers for me. Quote Link to comment
iceman510 Posted November 24, 2020 Report Share Posted November 24, 2020 I have success with aligning the towers using a rubber mallet and the technique mentioned in the snippet posted above. Quote Link to comment
banzai510(hainz) Posted November 24, 2020 Report Share Posted November 24, 2020 I just put the cam in there then lightly torq to spec gping inside out like doing a head see if cam turns (lube of coarse) BAM YOUR DONE Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 Got the cam towers done as suggested and the cam turns not being as strong I have to grip it with Tow hands to rotates all the way around. So I guess next now that all is cleaned up on the block is to get the head installed. I see 40 ft lbs as max torque. Any suggestions. I know the order to torque the head bolts Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 L16/18 are 43 but you can torque to 60 on an L20B and they are basically the same head with the same head bolts. 1 Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 I thought way back I saw something about 60 ft- lbs but I do see 40 ft- lbs in the how to rebuild you ohc engine book, so what would you suggest for final ft-lbs Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 Follow the book. Maybe it came into print before the L20B when 43 was the norm. The first L20B was the '74 610 so it may have taken a couple of years for this to be common knowledge. Quote Link to comment
edekalil Posted November 24, 2020 Author Report Share Posted November 24, 2020 Cool I'm going down stairs and putting it on, thanks again. Quote Link to comment
Duncan Posted November 24, 2020 Report Share Posted November 24, 2020 The "How to rebuild your Datsun OHC engine" book lists the head bolt torque on an L20b at 61 ft/lbs. I did mine at 60 lbs. and didn't worry about the 1 lb discrepancy too much.. 1 Quote Link to comment
datzenmike Posted November 24, 2020 Report Share Posted November 24, 2020 So many variables. The largest is how accurate is your torque wrench, how accurate is the device that tests the torque wrench? Temperature. Dry or oil on threads. 1 Quote Link to comment
420n620 Posted November 25, 2020 Report Share Posted November 25, 2020 I've used 3 in 1 oil to avoid hydro locking bolt holes when I rebuilt engines. It's thin enough to allow air to escape and gives the threads enough lube to cut down the friction on the threads so you get the proper torque needed , just a couple of drops is good. Just make sure all threads are chased and clean of debris / dirt. 1 Quote Link to comment
KELMO Posted November 26, 2020 Report Share Posted November 26, 2020 Geez, and I thought the can of 3 in one I had was old 1 Quote Link to comment
datzenmike Posted November 26, 2020 Report Share Posted November 26, 2020 Its 20w weight oil. I just clean the threads with an oily rag. Quote Link to comment
KELMO Posted November 26, 2020 Report Share Posted November 26, 2020 The last "A" motor I took apart had a fair amount of crud on the bolts so I chased the threads and holes to clean them up. On the head bolts, I cut a groove in the end and put axle grease on it to help drive debris out of the hole (may have even picked this up from you DM, but not really sure) then clean out with brake cleaner. Quote Link to comment
