witchespellmichelle Posted April 21, 2021 Author Report Share Posted April 21, 2021 The way I guessed it worked perfectly. After my baby had been sitting for 6 months...about 10 seconds of cranking it fired right up and purred like a kitten. I explained it REALLY well! Snapchat-637997895.mp4 1 Quote Link to comment
datzenmike Posted April 21, 2021 Report Share Posted April 21, 2021 Looks like the fuel inlet grommet was left off the large hose. It keeps exhaust smell out of the trunk. Fuel gauge wires are usually Yellow and a Black for ground. 1 Quote Link to comment
witchespellmichelle Posted April 21, 2021 Author Report Share Posted April 21, 2021 after i got the filler neck on the thing...i was like o.O oh noes. DEFINATELY smelt fuel without it 🤢 Quote Link to comment
ShutterMeShort Posted April 22, 2021 Report Share Posted April 22, 2021 Video of it running, or it's not! 😂 1 Quote Link to comment
witchespellmichelle Posted April 22, 2021 Author Report Share Posted April 22, 2021 @ShutterMeShort 20210420_185451_1_1_1_1_1_1_1.mp4 5 Quote Link to comment
ShutterMeShort Posted April 25, 2021 Report Share Posted April 25, 2021 On 4/22/2021 at 8:48 AM, witchespellmichelle said: @ShutterMeShort 20210420_185451_1_1_1_1_1_1_1.mp4 YUS!!!!!!! 1 Quote Link to comment
Motorvated Posted May 7, 2021 Report Share Posted May 7, 2021 Loving this thread! Thank you @witchespellmichelle I feel so overwhelmed with my build but seeing you tackle yours one step at a time really helps. Great responses by the followers here. Keep up the great work! Dom 2 Quote Link to comment
witchespellmichelle Posted May 7, 2021 Author Report Share Posted May 7, 2021 I'm glad you enjoyed the thread. next pics i'll post will be of it completed, for the most part. Everyone here had been UH-MAZING! SUPER sweet and helpful. Pretty funny too...I'm so thankful. It's a great place to be. Everyone is so supportive and provides guidance. I was SOOOOO overwhelmed at soo many times. But I just did one little thing, once a day a week, over time. I had a goal to shoot for...I knew that I wouldn't be at the level I wanted due to time and money, but I am happy with what I have and where it sits and how I did the things I wanted to do, my way. A true car enthusiast will understand and accept that. My car before looked like I was trying to drive around trying to get drugs...a real magnet for the po-po-ho and anyone else who wanted to steal it. Now It's more clean...at least now I can get the good shit! 😜 Before you start your project...I would suggest LOTS of pictures before/during/after. If I can do it...you can easily do it! lol! Start a thread...I look forward to seeing your progress as well! 2 1 Quote Link to comment
Motorvated Posted May 10, 2021 Report Share Posted May 10, 2021 Thanks for the tips Michelle. I did my first post! haha yep, I feel my car has the same 'dodgy' look to it I'll try to film and take photos. I tend to forget and just roar ahead out of excitement haha 1 Quote Link to comment
witchespellmichelle Posted June 4, 2021 Author Report Share Posted June 4, 2021 3 Quote Link to comment
datzenmike Posted June 4, 2021 Report Share Posted June 4, 2021 Not bad Michelle!!!! Now it only needs to be at least an inch lower, not much more than that. What size are those tires??? 1 Quote Link to comment
Draker Posted June 4, 2021 Report Share Posted June 4, 2021 dang this thing looks great! Agree it needs to be a bit lower now. 🙂 Also interested in the tire size. I'm shopping for tires right now and those look good. 1 Quote Link to comment
Lockleaf Posted June 4, 2021 Report Share Posted June 4, 2021 Hell that thing is nicer looking than any of the garbage I own. Very nicely done. 1 Quote Link to comment
datzenmike Posted June 4, 2021 Report Share Posted June 4, 2021 I know, right? I cannot just make the leap and start any body work. To me it's voodoo. 1 Quote Link to comment
witchespellmichelle Posted June 6, 2021 Author Report Share Posted June 6, 2021 On 6/4/2021 at 11:24 AM, datzenmike said: Not bad Michelle!!!! Now it only needs to be at least an inch lower, not much more than that. What size are those tires??? Thank you so much! 15x8 with a stretched 195 45 r15 Toyo tire. A little bit lower would be amazing! 1 Quote Link to comment
witchespellmichelle Posted June 6, 2021 Author Report Share Posted June 6, 2021 I also did use a 1" spacer to keep the front wheels from rubbing on the shocks. But now my passenger side turn signals don't work. Also, all I can smell is gasoline when I drive it, like it's running way too rich. When I drive it a little while, it dies when I don't give it gas. Quote Link to comment
Draker Posted June 6, 2021 Report Share Posted June 6, 2021 9 hours ago, witchespellmichelle said: I also did use a 1" spacer to keep the front wheels from rubbing on the shocks. But now my passenger side turn signals don't work. Also, all I can smell is gasoline when I drive it, like it's running way too rich. When I drive it a little while, it dies when I don't give it gas. Pull the plugs and have a look. That should give ya an idea if it’s rich. Might have a leak somewhere? 1 Quote Link to comment
datzenmike Posted June 6, 2021 Report Share Posted June 6, 2021 EFI rarely run anything but close to perfect... or they refuse to run at all. Carburetor engines often smell of gas when starting off cold. This is because of the choke being on to force an over rich fuel mixture. If you have holes in the trunk the smell might get in. Over all you may have a small blockage in your idle circuit and gas is not available for idling. The choke being on will mask this problem until the engine warms and the choke shuts off. Then it won't idle by itself. 1 Quote Link to comment
witchespellmichelle Posted June 8, 2021 Author Report Share Posted June 8, 2021 On 6/6/2021 at 1:53 PM, datzenmike said: EFI rarely run anything but close to perfect... or they refuse to run at all. Carburetor engines often smell of gas when starting off cold. This is because of the choke being on to force an over rich fuel mixture. If you have holes in the trunk the smell might get in. Over all you may have a small blockage in your idle circuit and gas is not available for idling. The choke being on will mask this problem until the engine warms and the choke shuts off. Then it won't idle by itself. On 6/4/2021 at 11:24 AM, datzenmike said: Thank you for your help. Your comment really pointed out exactly how I would have meant to describe the problem. I will have to dive into this thing once more. lol! Dammit! 🤢🙃 Quote Link to comment
banzai510(hainz) Posted June 8, 2021 Report Share Posted June 8, 2021 newer datsun had a ilde selinoud that can get plugged . when you shut the key off a litlle plunger plugs the idle jet. If a dirty tank then it may plug up. But 210 tank is inside so maybe its not that. also check the carb. I hd this happen on my weber DGV the accel pump diaprame on the side was leaky. everytime I cycled the gas pedal the side of carb would squirt out gas. also a bad carb float might cause flooding but I rememer you were working on the tank hoses in back so maybe something hooked up wrong 1 Quote Link to comment
ShutterMeShort Posted June 20, 2021 Report Share Posted June 20, 2021 I applaud you on your efforts an results, Michelle! This is coming along so nicely! Quote Link to comment
