ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 9 hours ago, datzenmike said: You have a cable speedometer now? The early D21 truck '87-'93 used a mechanical speedometer and the pinion sleeve fits your 71C transmission. After that an electric sensor was used. You will have to get the correct plastic gear to keep your speedometer accurate. If you have your old transmission take the pinion out and count the teeth. If your differential was changed this will change everything. Love the Laurel. Roof line is similar to the 510 SSS Coupe Yes. I have a cable (mechanical) speedometer now but transmission is S14 Silvia. I can not use electric sensor with my gauge. I have found a pinion sleeve from S13 Silvia which is fits to S14 transmission. After install i will need to figure out how to get a correct speed measuring. Quote Link to comment
datzenmike Posted May 27, 2019 Report Share Posted May 27, 2019 Well if you haven't changed the differential... and have the old transmission.... count the teeth on the plastic gear in the old transmission. Quote Link to comment
ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 7 minutes ago, datzenmike said: Well if you haven't changed the differential... and have the old transmission.... count the teeth on the plastic gear in the old transmission. I will. Thanks ) Quote Link to comment
Rat-a-tat-Dat Posted May 27, 2019 Report Share Posted May 27, 2019 Nice car and very good work. Can't wait for the finished product! Quote Link to comment
ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 1 hour ago, Rat-a-tat-Dat said: Nice car and very good work. Can't wait for the finished product! Thanks. Me too. But its long-time project. Soon we will make this car running the streets (maybe this week). Then it will be totally repainted (about 2 months). And I need to change the rear part of chassis for new one (about 2 weeks maybe less). Quote Link to comment
Eric Posted May 27, 2019 Report Share Posted May 27, 2019 Nice to see another C30, i have a 4 door myself, undergoing an sr20(non turbo) swap as well. Used 240z and 280ZX front suspension parts to get vented brakes etc. You should introduce yourself in the C30 register on Facebook: https://www.facebook.com/groups/1033716266700542/ Quote Link to comment
ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 26 minutes ago, Eric said: Nice to see another C30, i have a 4 door myself, undergoing an sr20(non turbo) swap as well. Used 240z and 280ZX front suspension parts to get vented brakes etc. You should introduce yourself in the C30 register on Facebook: https://www.facebook.com/groups/1033716266700542/ Nice to meet you Eric. Where I can see your project ? I have made a request on Facebook group. Quote Link to comment
Eric Posted May 27, 2019 Report Share Posted May 27, 2019 3 hours ago, ZeroSports said: Nice to meet you Eric. Where I can see your project ? I have made a request on Facebook group. My 'project' is here started in 2010 and still not ready, to many other Datsun that need my attention. 1 Quote Link to comment
ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 Day 50. Today we have a stormy weather. Strong wind with the heavy rain. But we need to continue our project. Finished work with radiator and a fan. Putting all the sensors and controllers. Fan sensor is for 86C degrees. And now we can start en engine and check everything proprely. 1 Quote Link to comment
ZeroSports Posted May 27, 2019 Author Report Share Posted May 27, 2019 The second engine start. There is some noise in steering booster. Checking the tank ... there is a froth. So we have a leak somewhere. Checking everything. The leak was found in one of the hosepipes. We will have to make another one. But we still need to warm up engine and check the fan cooler, oil leakage, transmission and many more. So we put away the steering booster belt and start engine for the third time. 4 Quote Link to comment
Eric Posted May 28, 2019 Report Share Posted May 28, 2019 On 5/26/2019 at 6:52 AM, ZeroSports said: Fuel filter and a new radiator. What radiator did u use? Quote Link to comment
carterb Posted May 28, 2019 Report Share Posted May 28, 2019 The paint looks beautiful in that first photo. Great project. Thanks for sharing. --carter Quote Link to comment
ZeroSports Posted May 28, 2019 Author Report Share Posted May 28, 2019 (edited) 18 hours ago, Eric said: What radiator did u use? I used not OEM Suzuki Swift ZC11S/ZD11S 40мм MT turbo version radiator. And we changed every hole location. But 2-speed fan was OEM. Edited May 29, 2019 by ZeroSports 2 Quote Link to comment
ZeroSports Posted May 28, 2019 Author Report Share Posted May 28, 2019 1 hour ago, carterb said: The paint looks beautiful in that first photo. Great project. Thanks for sharing. --carter The paint is very good when you look at the car with 5 meters distance ))) Because it was painted 5-6 years ago in a garage. So now I'm planning to repaint everything in a good service shop. 1 Quote Link to comment
ArchetypeDatsun Posted May 29, 2019 Report Share Posted May 29, 2019 Super cool another member here named goki has a blue one in the states. I really wanna import a C130 2000SGX coupe. 1 Quote Link to comment
ZeroSports Posted May 29, 2019 Author Report Share Posted May 29, 2019 5 hours ago, ArchetypeDatsun said: Super cool another member here named goki has a blue one in the states. I really wanna import a C130 2000SGX coupe. Cool. Where can I see his car ? Quote Link to comment
ZeroSports Posted May 30, 2019 Author Report Share Posted May 30, 2019 (edited) Day 53. Not so much was done during these 3 days. But there was one huge problem with the vacuum brake booster. It was broken. And the brakes were not as good as it must be. But we need brakes to test a car on the road soon. So we started searching the used one in our market. Because the new one will be delivered in 3 weeks after purchasing. Only one vacuum brake booster was fitted - from Nissan Starlet. And I've ordered the new one from Japan - https://page.auctions.yahoo.co.jp/jp/auction/q291846702 Then were some small adjustments like boost solenoid, horn signals Mitsuba and other things. We cleaned up all windshield motor and have made a new wiring on it. I was searching for a new water cooling tank. But there was no good in the market. Only Chinese one. But I don't like Chinese parts. That's why we decided to make a custom one. It is not finished yet. Edited May 30, 2019 by ZeroSports 1 Quote Link to comment
ZeroSports Posted May 31, 2019 Author Report Share Posted May 31, 2019 Day 54. We've made a custom water cooler tank. And place it near the radiator. Have made all pipes to main brake cylinder. Have bought exhaust. Tomorrow will make it. But we still searching for good muffler. It's hard to find in our market small one. And we have a problem. There was a small leak in water cooler temperature sensor which is switching on the fan. Were tried to solve this problem but the sensor was broken. So now we need to buy another one. 2 Quote Link to comment
ZeroSports Posted June 3, 2019 Author Report Share Posted June 3, 2019 Day 57. 1 Quote Link to comment
ZeroSports Posted June 4, 2019 Author Report Share Posted June 4, 2019 Day 58. Old spark plugs New spark plugs 2 Quote Link to comment
ZeroSports Posted June 5, 2019 Author Report Share Posted June 5, 2019 Day 59. We've made it ! First ride ... 4 Quote Link to comment
BrothersGarage Posted June 6, 2019 Report Share Posted June 6, 2019 (edited) BOV sounds great @ 1:39 and even better @ 2:23! Edited June 6, 2019 by BrothersGarage 1 Quote Link to comment
ZeroSports Posted June 6, 2019 Author Report Share Posted June 6, 2019 9 hours ago, BrothersGarage said: BOV sounds great @ 1:39 and even better @ 2:23! It's not a BOV. I don't have it. The intake sounds like this ) 1 Quote Link to comment
ZeroSports Posted June 6, 2019 Author Report Share Posted June 6, 2019 Just some pics while test riding. Quote Link to comment
ZeroSports Posted June 12, 2019 Author Report Share Posted June 12, 2019 Have found new labels on Yahoo auction and a magazine and a catalog 1 Quote Link to comment
