Flexplate bolt thread conundrum
Einbbx
You may have read my story..
Automatic Z24 ST manufactured date 6/84, Flexplate failed had to replace, during removal flexplate bolt snapped.
Now I am trying to re-thread the holes on crank, but have found issue.
I have 3 different flex bolt sets
Each have different signs on head
*Original bolts= upside-down T & 12
*Removed from a manual= MT
*Removed from D21?= upside-down T & 13
T12 shortest (tapered end)
MT slightly longer (no taper)
T13 longer still (tapered)
5 of 6 T12 bolts are UNUSABLE, trying to find suitable substitute.
ISSUE
Bolt is either
12mm with 1.25 thread or
1/2 with 20 thread.
Foreign... should be metric...
Used a thread checker and thread looks interchangeable
1/2-20 tap does not fit bolt hole, logic says it's 12mm tap.
PROBLEM
Bolt seems to fit 12mm-1.25 die but will NOT thread
Bolt fits 1/2-20 die loosely but threads nicely.
MY CONCLUSIÓN
After trying several dies and reading up on my measurements
BOLT:
Appears to be 12mm, 12 slightly smaller than 1/2 explains loose fit in 1/2 die and tap not fitting in crank.
THREAD:
Appears to have a standard 20 thread, if it can fit the 12mm die but wont thread with 1.25.. then it must be so?
.. is this possible? Is this a real thing?.. or am I crazy!?
I need to re-thread but don't want to damage crankshaft, ANY advice is welcomed wholeheartedly
Please and thank you all
-E.C.V.
  • Replies 22
Thanks for the speedy reply
I agree logic dictates it.. but the closest and ONLY die that should work is 12m 1.25 thread. I measured 1.5 and 1.75 thread and it's not even close. But it won't fit the 12mm die with correct thread. Bolt threads are beautiful so it makes absolutely no sense
Take a good bolt to a local Ace or True Value hardware store or any place that has metric bolts and taps.  Use the thread finding tool to determine the thread and the get your self 2 taps in that size. ! a tapered tap and 1 a botoming tap.
Run the tapered tap first with lots of thread cutting oil.  if you have never tapped a hole then search it out on the web.  You don not run a tap straight through you turn it in a little the back it out, then turn it in a litle past where you stop the last time, then back it out, add more cutting oil as you go.  Keep repeating this process until your tap comes out the backside.  Becarefull not to try to thread to much at a time or run the tap into the back of the engine block.  It is easy to break off a a tap but difficult to remove the tap.  after you finish with the tapered tap (when the tapered tap runs the entire depth off the threads then switch to the bottoming tap and repeat the process.
Go to an over size bolt in metric or standard, it doesn't matter. If you tap the same metric size there is a chance that you will slice the original threads off the crank. Go to a larger hole so your tap cuts new metal threads. Get the corresponding drill and tap for the bolt you pick.
The bolt thread is 12 x 1.25.  These flex plate bolts are shorter than the flywheel bolts.
I have torn down over the past 25 plus years 6 automatic cars and trucks.  This is how I know that all use the same hardware even the 3 and 4 speed auto matics.  The flex plates are different between the 3 and 4 pspeed automatics but they also use the same bolts for the torque converter.  The 2 speed automatics behind the torbo engines have the same hardware also.  When I say this I am talking only about the L engines 4 & 6 cylinder 6 hole cranks, the 4 cylinder Z20 Z22 Z24 engines and the 4 cylinder KA engins all take the sme spacers, flex plate to crank bolts, and flex plate to torque converter bolts.
You will have these soon.
If you have any questions on how the spacers go on or any thing please ask.
Einbbx I noticed in the picture above that there were 2 differen link shoulders.  So I unboxed and made sure all the T12 bolts had the shorter shoulder so you have a matched set of 6.
No I had the measurements covered, have a little nifty tool that has all metric and standard thread sizes to test bolts. Only issue was my m12 1.25 die had damaged thread and made me think the threading was different.
I'm really thankful @Charlie69 the local LKQ yards always have 720s & d21s, but recently they've all been manual.
I just remembered why I have 6 bolts with longer threads.  These came out of a 97 D21 Hardbody tha only uses the outer spacer plate and actually fit one of the 4 speed automatic Transmissions I have for a project.
I sorry about the confusion but I will send you the shorter threaded bolts that fit the dual spacer setup.  All these bolts have T12 on the tops of them.
