Identification of hardware (nuts and bolts) for 510 ??
  • Replies 24
Go to first post and select EDIT at the bottom. Then: Use Full Editor. This will access the title line for changes. (don't forget to hit Save Changes) Hardware could be anything, so be sure to put nuts and bolts in there somewhere for the search function.
Pretty sure 12mm wrench fits them and they are all metric and fine thread. Inch and a quarter long maybe. That would be enough to take to a fastener store. Take an example home and see if it's good enough.
M8 X 1.25 bolt and an M8 split washer. 12mm wrench size... JIS (Japanese Industrial Standards)
what vehicle? Im not gonna spoon feed you all the questions. I bet the info is already somewhere online (partial quote)
:sleep: couldn't of said it better myself
choosing to click on profiles to see what kind of car ratsun members have
when its clearly under your location
<<<<< right there
in every post or comment we make
yea I am the noob
:sleep:  :sleep:
M8X1.25 X 2cm (3/4")
By the way. That pic is not the same as your car. The hinges on your dime bolt from the inside:
The hinges are threaded.
The door side of the hinge is more conventional threading into the door itself.
Thanks for the descriptive title.
