Ponyboy Easley Posted March 22, 2016 Report Share Posted March 22, 2016 Im the one with that gasket issue. So i got that finished and did the head gasket, manifold gasket and few other gaskets. Also replaced fuel pump. 2 new problems. Coolant is rushing out under the intake and exhaust manifold. As soon as you turn the key and let it turn over ans stop. You here coolant just rushing to the ground. Right under the manifolds. Anyone have any know leaks? Anywhere its flowing. I really would hate to take the manifolds off again...unless I have to. Also i cant seem to get enough fuel to start half the time. If i dab some gas in the carb, boom, its ready to fire up. My gas carb work and lack of fuel pressure. Im running a webee carb. Could use as much help as i can get! Quote Link to comment
q-tip Posted March 22, 2016 Report Share Posted March 22, 2016 Well bad news, you have to take the manifolds off again. It could be the thermostat housing but that is on top of the manifold. 1 Quote Link to comment
Ponyboy Easley Posted March 22, 2016 Author Report Share Posted March 22, 2016 Thats what I thought. I swear its got to be a bolt or something that goes to the block thats just undee the manifold. And i check around the housing. Its not leaking from there....i tried to follow as best i could and its straight under the intake manifold just hidden to where i cant see it. Ill check the thermostat housing again though! Also worth a secone look. Thanks! Quote Link to comment
datzenmike Posted March 22, 2016 Report Share Posted March 22, 2016 The intake isn't seated tightly. The '78 has coolant openings in the head that match openings in the intake. Coolant exits the intake just below and in front of the carb... you probably wondered what that hose and metal pipe was that goes to the thermostat housing was for? If the intake is not on properly it will just dribble out. None of the bolts or studs go through and into the coolant jacket so no worries there. Lets see... no gas but replaced the fuel pump. Let me think... are these two things are related. :lol: Put the old pump back on and try it. You should have two gaskets sandwiching a plastic spacer under the pump. 2 Quote Link to comment
kelowg Posted March 22, 2016 Report Share Posted March 22, 2016 Try tightening those intake bolts. They r real bitch to get seated all the way. Very common issue for first timers. This is where toque wrench is nice to have. Maybe thats causing large vac leak,not drawing enough air thur carb? Quote Link to comment
Cheetahking Posted March 22, 2016 Report Share Posted March 22, 2016 If you take the intake off, retighten from the inside out (sometimes you can put a slight bend in the manifold if you start at the outside….) 1 Quote Link to comment
datzenmike Posted March 22, 2016 Report Share Posted March 22, 2016 The bottom bolts use a rounded 'cone' washer to bridge across the intake and the exhaust and hold both. I forget which way they sit. 1 Quote Link to comment
q-tip Posted March 22, 2016 Report Share Posted March 22, 2016 The bottom bolts use a rounded 'cone' washer to bridge across the intake and the exhaust and hold both. I forget which way they sit. Those damn washers are pretty important too. 1 Quote Link to comment
KoHeartsGPA Posted March 22, 2016 Report Share Posted March 22, 2016 Those damn washers are pretty important too. Extremely. Quote Link to comment
datsunaholic Posted March 22, 2016 Report Share Posted March 22, 2016 A '76 wouldn't have a water jacketed manifold, though. Unless the engine wasn't original. 1 Quote Link to comment
Doctor510 Posted March 23, 2016 Report Share Posted March 23, 2016 The bottom bolts use a rounded 'cone' washer to bridge across the intake and the exhaust and hold both. I forget which way they sit. Round side towards the fender 1 Quote Link to comment
Ponyboy Easley Posted March 23, 2016 Author Report Share Posted March 23, 2016 Anyone else having issue with not enough fuel? Like it wont turn over unless i dab some fuel in the carb. Im running a weber with electric choke. Maybe the choke? May have to tear down the weber. Prehaps really dirty Quote Link to comment
5t341tH Posted March 23, 2016 Report Share Posted March 23, 2016 Clogged fuel filter? Quote Link to comment
datzenmike Posted March 24, 2016 Report Share Posted March 24, 2016 The starter turns the engine over, it just does not start. Cranking is the same thing. Cold engine... Look down the carb with the air filter off. The choke plate should be closed OR when you pump the gas pedal it should snap shut. Closed... Open... Hold choke open and pump the gas. What you should see is a strong squirt of fuel into the primary barrel. If it does, pump 3-4 times and try starting it. (cranking) 1 Quote Link to comment
Ponyboy Easley Posted April 3, 2016 Author Report Share Posted April 3, 2016 So I beleive I have fixed the coolant issue. When I put it back together I guess I lost one of the bolt and washers that I needed to tighten both intake manifold and exhaust manifold. The missing one was also in the same spot I was leaking from. So after getting that fixed I realized I forgot to put in the intake plate between the intake and manifold. So fixed that, re did the timing so now the car wants to fire up and is in as close to perfect timing as you can get it. Now.....I cannot hold an idle AT ALL. My guess, carbs bad or I have a major vaccum leak. Oh and guess what, im going to have to take off all the manifolds again to do a gasket replacement on that. Yay. This will be the 4th time doing it. Love and hating this truck. But anyways.....anyone know of any good carbs or fuel conversions I can do that wont be too much? I need a running car for work mostly. Quote Link to comment
banzai510(hainz) Posted April 3, 2016 Report Share Posted April 3, 2016 stop and think and ask before you do. You adjust the mixture on the carb? if dont leak water then the manifold gasket is Ok untill you get it running to see if its good. bolt the carb down good. pump the gas and it shouls at leas fire off a little as pump the gas is like pouring gas in the carb the fumes should fire off if everything is right spark plugs might be wet with radiator water getting sucked in Quote Link to comment
datzenmike Posted April 3, 2016 Report Share Posted April 3, 2016 Your intake and exhaust and not bolted and sealed together. Here's mine. This is the intake looking up from underneath. Those two holes are for the carb. This is another drawback to this set up. Seal it up with RTV. Quote Link to comment
Ponyboy Easley Posted April 4, 2016 Author Report Share Posted April 4, 2016 Would it be worth it to get new spark plugs? And no I haven't touched the mixture, if I should what should do? And Mike. That plate how I have it set up is gasket touching the exhaust then plate then gasket again. Could I use gasket sealer? Quote Link to comment
datzenmike Posted April 4, 2016 Report Share Posted April 4, 2016 Anything that will take high temperature should do. If it was a vacuum leak you shouldn't need to adjust the carb now. Quote Link to comment
Ponyboy Easley Posted April 4, 2016 Author Report Share Posted April 4, 2016 Ill definetely try that. Lets say the carb is no good or something. Is there a better carb I could try using? In the long run I'm aiming for performance, so I kinda just want a different carb in general. Any suggestions? Quote Link to comment
