720driver97 Posted January 16, 2016 Report Share Posted January 16, 2016 Got my z24 put in my truck yesturday after I rebuilt it and now I'm having problems, first problem is it won't turn over properly it will turn for a bit then stop for no reason then turn again what would cause this? Then for some reason my tail lights stay on as long as the battery is hooked up not sure why, 1 Quote Link to comment
720driver97 Posted January 16, 2016 Author Report Share Posted January 16, 2016 Were are the degree marks on the z24 distributor I can't find them , any one have a pic? 1 Quote Link to comment
Draker Posted January 16, 2016 Report Share Posted January 16, 2016 When you rebuilt it, did you turn it over by hand 720 degree's while on the stand? No binding or anything? 1 Quote Link to comment
flatcat19 Posted January 16, 2016 Report Share Posted January 16, 2016 The marks are on the timing gun you should be using to dial it in. 2 Quote Link to comment
720driver97 Posted January 16, 2016 Author Report Share Posted January 16, 2016 It turned fine on the stand just turning It by hand, I don't have a timeing gun but I can't even get it to start were should the marks be? 1 Quote Link to comment
KoHeartsGPA Posted January 16, 2016 Report Share Posted January 16, 2016 I'm not sure your engine is the issue if it turned over with no issues on the stand....did you make sure the flywheel isn't being stopped by an obstruction? 2 Quote Link to comment
Doctor510 Posted January 16, 2016 Report Share Posted January 16, 2016 I'm not sure your engine is the issue if it turned over with no issues on the stand....did you make sure the flywheel isn't being stopped by an obstruction? I was ambushed by a bent engine plate once. 2 Quote Link to comment
720driver97 Posted January 16, 2016 Author Report Share Posted January 16, 2016 Every thing looked good when I put it in, I pulled the spark plugs out then it turned fine then I put them back in and it was good for awhile Quote Link to comment
Boxcar Posted January 16, 2016 Report Share Posted January 16, 2016 Timing....... It's off..... Try again.... 1 Quote Link to comment
datzenmike Posted January 16, 2016 Report Share Posted January 16, 2016 There are 8 plugs and easy to get them mixed up. Re-check every wire goes to the plug it's supposed to. Most distributor caps are marked. Turn the distributor counter clockwise to retard it. 2 Quote Link to comment
720driver97 Posted January 17, 2016 Author Report Share Posted January 17, 2016 Well I found the problem and fixed it as far as the timing go's I think because the spindle that drives the distributor was not in the right position 1 Quote Link to comment
720driver97 Posted January 17, 2016 Author Report Share Posted January 17, 2016 Now I'm having problems getting the carb adjusted properly it will run at high RPM but when I try to let it idle it will kind of spit and sputter gas out the top of the carb then kill quickly, any ideas on the problem here? Quote Link to comment
Draker Posted January 17, 2016 Report Share Posted January 17, 2016 That would do it.. but ya need a timing light. Get one for next time. 1 Quote Link to comment
DATSAN Posted January 19, 2016 Report Share Posted January 19, 2016 How long did the truck sit without an Engine? With enough time, your fuel can turn into a mucky goop of turpentine. If it sat for more than 8 months, replace; Fuel tank, fuel lines, and, if you can afford it, replace the carb with a weber. 1 Quote Link to comment
Lockleaf Posted January 19, 2016 Report Share Posted January 19, 2016 Replace fuel tank? For 8 months of sitting? Wtf? 2 Quote Link to comment
DATSAN Posted January 20, 2016 Report Share Posted January 20, 2016 Replace fuel tank? For 8 months of sitting? Wtf? lol I meant to put a "1" in there somewhere. 18 months. Of course mine sat for 4 years. By then, the gas was syrup. 1 Quote Link to comment
Charlie69 Posted January 20, 2016 Report Share Posted January 20, 2016 I am resurrecting a 1985 720 st that sat for over 20 years. I pulled the tank and had it hot tanked at the radiator shop I have used since the 70s. I replace the fuel pump and filters. I have started and ran the truck from a gas can. The tank came back looking new. 1 Quote Link to comment
Crazykidd9 Posted January 20, 2016 Report Share Posted January 20, 2016 Got my z24 put in my truck yesturday after I rebuilt it and now I'm having problems, first problem is it won't turn over properly it will turn for a bit then stop for no reason then turn again what would cause this? Then for some reason my tail lights stay on as long as the battery is hooked up not sure why, The tailights staying on is an easy fix if you havent done it yet. It should just be the brake light switch, it may have broken or is just too old to function now, theyre about $10 at napa. Quote Link to comment
datzenmike Posted January 20, 2016 Report Share Posted January 20, 2016 Now I'm having problems getting the carb adjusted properly it will run at high RPM but when I try to let it idle it will kind of spit and sputter gas out the top of the carb then kill quickly, any ideas on the problem here? You may just need to turn the idle speed screw up. Possibly the idle circuit is plugged or the idle cut solenoid is not connected. Listen near the carb while someone turns ignition on off on off... you should hear a soft click if the solenoid is working. Carefully remove the idle cut solenoid. It has a small spring and a loose part that can get away and be lost so be ready. Unscrew the idle mixture screw, counting the turns so it can be put back in the same setting. Same thing, it has loose parts that can get lost. Use a can of carb spray with the red straw and spray alternately into the idle cut solenoid and the idle mixture holes. Have a care, that spray will shoot out and can get in your eyes. This should disolve or flush out any clogs.. 2 Quote Link to comment
720driver97 Posted January 21, 2016 Author Report Share Posted January 21, 2016 I drained the gas but it only sat for a month or so without a engine. As for the carb I have a webber 32/36 the truck idols at around 800rpms now idols great. How would to lean of a mixture make the exhaust hot? Quote Link to comment
DATSAN Posted January 21, 2016 Report Share Posted January 21, 2016 720driver97, excess fuel always allows more cooling than a lean burn. Having a lean mixture will always give you better combustion, (and horsepower,) but your engine won't put up with it forever. You'll end up burning up the pistons or the top ring because of higher friction. Quote Link to comment
720driver97 Posted January 21, 2016 Author Report Share Posted January 21, 2016 Ok thanks Quote Link to comment
