Stoffregen Motorsports Posted January 29, 2015 Report Share Posted January 29, 2015 Im really digging the whole set up for $900. Will that get me a driver side drop axle as well or a right drive line? Probably just get a toyota rear and match gears. Is a 30 spline better than the 21 spline? The $900 is for a custom axle. You decide where it goes. 30 spline is better thatn 21, but where are you getting these numbers? Toyota transfer case inputs are 21 spline (or 23 for Turbo). Quote Link to comment
Thisolddatsun Posted January 29, 2015 Author Report Share Posted January 29, 2015 The divorced adapter allows the Toyota case to be used without it being attacthed to a transmission. You could use the divorced adapter then a stock Toyota reduction box followed by a Toyota transfer case (with stock gears or 4.7 gears). There is no provision to bolt a Nissan case to a Toyota case.Hmm well maybe Ill try doing a dual nissan tcase set up and see if itll get a passanger side drop from it. Quote Link to comment
Thisolddatsun Posted January 29, 2015 Author Report Share Posted January 29, 2015 The $900 is for a custom axle. You decide where it goes. 30 spline is better thatn 21, but where are you getting these numbers? Toyota transfer case inputs are 21 spline (or 23 for Turbo). I got it from the website for the custom axles for $900 Any Spline count, some common ones for us are: 27 spline Toyota 30 spline Toyota 32 spline Toyota 36 spline Toyota 31, 33, 35 spline Ford 30 spline 14b 35 spline Dana 60 37 spline Dana 80 40 spline 31, 33 spline Nissan Enless axle spline count is different from tcase Quote Link to comment
]2eDeYe Posted January 29, 2015 Report Share Posted January 29, 2015 Totally different :) Quote Link to comment
Thisolddatsun Posted January 29, 2015 Author Report Share Posted January 29, 2015 Totally different :) Hahah alright hahah thats what I was concluding haha. Quote Link to comment
Thisolddatsun Posted January 29, 2015 Author Report Share Posted January 29, 2015 Trying to dig up some info on the tx100 tcase that came in 86-87 and 88-89 Im thinking its the married tcase but I'm not sure if it is then I guess ill look into putting 2 t100s together. Everything iv read and my uncle says the t100 tcase is one tough SOB and dual ones of those would be sick. Cant find any build threads for t100 dual set ups with pictures. Lots of write ups about them but id like some pictures. Quote Link to comment
]2eDeYe Posted January 29, 2015 Report Share Posted January 29, 2015 It's too bad a lot of those picture links are gone in that pirate4x4 thread. Looks like you will need to take a bunch of pictures during your experimentation. :) Quote Link to comment
Thisolddatsun Posted January 29, 2015 Author Report Share Posted January 29, 2015 It's too bad a lot of those picture links are gone in that pirate4x4 thread. Looks like you will need to take a bunch of pictures during your experimentation. :) Deffinatly will have to. Post them to ratsun where they belong :) hahahaha. 1 Quote Link to comment
Lockleaf Posted January 30, 2015 Report Share Posted January 30, 2015 That tx100 is a married tcase, sadly. Quote Link to comment
Stoffregen Motorsports Posted January 30, 2015 Report Share Posted January 30, 2015 With all the adapters out there these days, I wonder if there's an adapter to bolt a Toyota trans (W56, R150) behind a Nissan motor. That would be the simplest solution. Or any other trans for that matter. Ooooh, wait a minute. I remember that the T5 was used in the 1983 280zx turbo. I wonder if that bellhousing is the ticket here. T5 to D300 ought to be a simple option, it just depends on finding the right T5. 1 Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 With all the adapters out there these days, I wonder if there's an adapter to bolt a Toyota trans (W56, R150) behind a Nissan motor. That would be the simplest solution. Or any other trans for that matter. Ooooh, wait a minute. I remember that the T5 was used in the 1983 280zx turbo. I wonder if that bellhousing is the ticket here. T5 to D300 ought to be a simple option, it just depends on finding the right T5. Totally feel like I just read a language iv never heard before. Haha :o Quote Link to comment
Lockleaf Posted January 30, 2015 Report Share Posted January 30, 2015 The z31 turbo also ran the T5 trans. That bellhousing will attach any t5 to any vg engine, but I don't know about there being an L28 bellhousing. Does L series six cylinder match Z series bolt patterns? Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 The z31 turbo also ran the T5 trans. That bellhousing will attach any t5 to any vg engine, but I don't know about there being an L28 bellhousing. Does L series six cylinder match Z series bolt patterns? I know I can do z series transmission mine has the lowest first gear ratio that I can find that doesnt need modifications to bolt up. Quote Link to comment
Stoffregen Motorsports Posted January 30, 2015 Report Share Posted January 30, 2015 I had a T5 in my 510 MANY years ago. I think I may still have the bellhousing laying around. If you could source a Borg Warner T5 out of a '82 to '86 Jeep CJ you could bolt a Dana 300 transfer case to it and be done. Lots of cool stuff is available for the Dana 300 like HD input and output shafts and gearsets. Unfortunately the T5 is not know for it's strength, but luckily it is possible to bolt a SM420 or SM465 (both GM 4 speeds with granny low) to a T5 bellhousing. SM420's have a 1st gear ratio of about 7:1 so it makes for a good crawling transmission. http://www.novak-adapt.com/knowledge/t4_t5.htmhttp://www.novak-adapt.com/knowledge/model_300.htm So we now have a good option for getting a strong t-case with a passenger side drop into your Nissan. The only caveat is that the T5 behind an L motor would be clocked differently than the NAPS Z bellhousing, but that also could play into our hands to get the t-case rotated up flat with the bottom of the frame rails. 1 Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 I had a T5 in my 510 MANY years ago. I think I may still have the bellhousing laying around. If you could source a Borg Warner T5 out of a '82 to '86 Jeep CJ you could bolt a Dana 300 transfer case to it and be done. Lots of cool stuff is available for the Dana 300 like HD input and output shafts and gearsets. Unfortunately the T5 is not know for it's strength, but luckily it is possible to bolt a SM420 or SM465 (both GM 4 speeds with granny low) to a T5 bellhousing. SM420's have a 1st gear ratio of about 7:1 so it makes for a good crawling transmission. http://www.novak-adapt.com/knowledge/t4_t5.htmhttp://www.novak-adapt.com/knowledge/model_300.htm So we now have a good option for getting a strong t-case with a passenger side drop into your Nissan. The only caveat is that the T5 behind an L motor would be clocked differently than the NAPS Z bellhousing, but that also could play into our hands to get the t-case rotated up flat with the bottom of the frame rails. I would LOVE a sm420 one of the reasons i would do a 4.3 v6. & also its a center drop on the nissan t100 tcase Quote Link to comment
]2eDeYe Posted January 30, 2015 Report Share Posted January 30, 2015 The z31 turbo also ran the T5 trans. That bellhousing will attach any t5 to any vg engine, but I don't know about there being an L28 bellhousing. Does L series six cylinder match Z series bolt patterns? The L series and Z series motors have the same bolt pattern but they clock the trans at a different position. I believe it's about an 11 deg difference, but haven't measured it. Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 The L series and Z series motors have the same bolt pattern but they clock the trans at a different position. I believe it's about an 11 deg difference, but haven't measured it. Did some talk about a z22 build thread maybe a lz23 build. mike posted this An L head and an L series front timing cover is all you really need... however the L engine is normally leaning about 20 degrees to the pass side and this gives room on the driver's side for the manifolds. Unles you use L series mounts and an L transmission this isn't going to workSuppose if I did the work and for tranny tcase combos itd be interesting. The t5 bell housing swap on a sm420 and do dual tcases would be awesome behind a lz build. Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 Dunno how much it'll help but this is the tcase I have blown apart. So could I take 2 t100s apart and bolt the 2 front transfer front cases together, a front cover, and a rear case and have a dual tcase? Quote Link to comment
Stoffregen Motorsports Posted January 30, 2015 Report Share Posted January 30, 2015 I don't know of any way to bolt two Nissan t-cases together. If you did dual cases, they would probably be Toyota cases. More accurately, one Toyota reduction box, then an adapter, then a Toyota t-case. The bellhousing clocking is important for the transfer case front output clocking. I'm not saying you should run an L motor. I'm saying that if you ran the L series T5 bellhousing, then a T5 (or SM420) the clocking difference between the L and Z motors would be beneficial. It would raise the front output of the transfer case so that it would not hang down below the frame. And I'm not saying it would fit in the truck either, not without plenty of mods, like a custom crossmember and possibly some work to the floor pan, plus probable exhaust and other work as well. If I were building the truck here in my shop, this is the avenue I would pursue. 1 Quote Link to comment
Thisolddatsun Posted January 30, 2015 Author Report Share Posted January 30, 2015 I don't know of any way to bolt two Nissan t-cases together. If you did dual cases, they would probably be Toyota cases. More accurately, one Toyota reduction box, then an adapter, then a Toyota t-case. The bellhousing clocking is important for the transfer case front output clocking. I'm not saying you should run an L motor. I'm saying that if you ran the L series T5 bellhousing, then a T5 (or SM420) the clocking difference between the L and Z motors would be beneficial. It would raise the front output of the transfer case so that it would not hang down below the frame. And I'm not saying it would fit in the truck either, not without plenty of mods, like a custom crossmember and possibly some work to the floor pan, plus probable exhaust and other work as well. If I were building the truck here in my shop, this is the avenue I would pursue. well all the work into the l bellhouseing and twist itd be worth the time to go with a lhead to get rid of the dual spark plugs and have 4 and they are better heads than the z performance wise or something like that. Quote Link to comment
Thisolddatsun Posted January 31, 2015 Author Report Share Posted January 31, 2015 Suppose if i have a double t case any tranny would work for crawling. Like a zcar tranny so in 4hi and 2wd itd haul ass. Along with the right gear ratios in the axles Quote Link to comment
datzenmike Posted February 1, 2015 Report Share Posted February 1, 2015 The z31 turbo also ran the T5 trans. That bellhousing will attach any t5 to any vg engine, but I don't know about there being an L28 bellhousing. Does L series six cylinder match Z series bolt patterns? The first L28 turbos 12/ '80 (half way through the '81 model year) only came with automatics. It was thought the FS5W71B couldn't handle a turbo engine and the FS5W71C wasn't ready yet so a year later Nissan got their ass in gear but settled on the crappy T-5 for half of '82 and all of '83. When the '84 300zx came out the T-5 was continued through '86 with the VG30ET. The normally aspirated VG30E did get the new FS5W71C. Quote Link to comment
Lockleaf Posted February 1, 2015 Report Share Posted February 1, 2015 Good to know. Thanks for the info Mike, that rocks. Old datsun, you're right about running two divorced tcases meaning you could run any trans. The only downside is that the 720 4x4 runs a shorter transmission. I believe that the tail shaft and tail housing are what is shortened, but I may not be correct on that. This matters because you either need to swap that portion of trans over, or else push the t cases farther back in the truck. Quote Link to comment
Thisolddatsun Posted February 1, 2015 Author Report Share Posted February 1, 2015 Good to know. Thanks for the info Mike, that rocks. Old datsun, you're right about running two divorced tcases meaning you could run any trans. The only downside is that the 720 4x4 runs a shorter transmission. I believe that the tail shaft and tail housing are what is shortened, but I may not be correct on that. This matters because you either need to swap that portion of trans over, or else push the t cases farther back in the truck. I was thinking going with a shorter/smaller one. But if I already have the shortest/smallest nissan 5spd I can get then guess I'll just have to roll with it. Its a good transmission I love it and beat the hell out of it one of the bolt holes on the bell housing has a nice split through it on the upper part. 1 Quote Link to comment
wayno Posted February 1, 2015 Report Share Posted February 1, 2015 OK, the early 720 4X4s had longshaft 4 or 5 speeds in them with a very short driveline between the transmission and transfer case, around 1983/84 they started to use the short shaft 5 speed with a little longer driveline between the transmission and transfer case. 1 Quote Link to comment
