ggzilla Posted April 19, 2008 Report Share Posted April 19, 2008 mmmm... FJ20.com Quote Link to comment
Burabuda Posted May 19, 2008 Report Share Posted May 19, 2008 right on the money, dd :D here's a good overview page: http://www.turbocreations.com/fj20/history.html Quote Link to comment
devilduece Posted August 20, 2008 Report Share Posted August 20, 2008 so I'm just posting some pics of my motor so far. The original intake and hopefully it's replacement. Hopefully it all works out well. whoa whoa itbs me and my buddy pout some on his vtec i know its a honda we got four neoprene oil resistant hoses same diameter as the itbs and intake lobbed off the intake after the injector bungs put the hoses in between the intake and itbs with strong hose clamps car still runs good tps needs recalibrated no intake leaks either cause the type of hose we used is super conforming spendy stuff but thats whats used on the gsxr motor there is also how too site you can use the existing manifolds and when vtec kicked it in was a sweet sound Quote Link to comment
FJ20_S12 Posted October 27, 2008 Report Share Posted October 27, 2008 does anyone have an idea if an L Series oil pump will work for an FJ20? im looking to find one close to the FJ20ET's flow rate Quote Link to comment
datzenmike Posted October 27, 2008 Report Share Posted October 27, 2008 Do you have a picture or diagram of the FJ pump? I looked at the engine diagrams and couldn't see an external mount one. Perhaps it's a crank driven eccentric like the FWD KA24Es have. . Quote Link to comment
Pedro Posted December 14, 2008 Report Share Posted December 14, 2008 FJ20 gasket numbers here Quote Link to comment
69FJWagon Posted December 15, 2008 Report Share Posted December 15, 2008 does anyone have an idea if an L Series oil pump will work for an FJ20? im looking to find one close to the FJ20ET's flow rate not even close the fj oil pump is driven off the crank and is in the timing chain cover, like the KADE oil pump Quote Link to comment
defdes Posted April 4, 2009 Report Share Posted April 4, 2009 (edited) How's the build going naz? I haven't posted up much about my project on this site, but since there's a "sticky"... Mine's bored out to 2.1 (91mm) with Wiseco pistons, 10.5:1 CR, Electromotive crank fire ignition, and dual 44 Mikunis, headers I pieced out of a set of long tube NISMO L16's welded to a water jet cut mounting flange and jet coated. I also have a stock FI intake which I plan to convert to some day. I have heard though have no verification, that a 83-85 200SX (same years as the FJ, S12 CA20) EFI stuff is a plug in. The gasket set from that years SX is a pretty much direct fit so it might make sense. http://s16.photobucket.com/albums/b40/defdes/ Edited April 5, 2009 by defdes couldnt post photo Quote Link to comment
Icehouse Posted April 4, 2009 Report Share Posted April 4, 2009 Defdes, I actually hung out with Naz tonight. A good friend of ours had a little get together. The company he worked for is going out of business so I don't think he will be installing the engine any time soon. Since he sold his 510 a while back but planned on picking up a cleaner one once the engine was done. From what he tells me the engine machine work is done. All he needs to do is order a head gasket and head bolt. I tried to buy it off him but he won't sell it :( I'm first in line though :D I did however talk to a friend of a friend that has an FJ. I've been trying to buy that one for over 5 years!! It sounds like he might sell it to me though :D I would like to keep my L series 510 powered by an L series but I would do an FJ just because they are so bad ass!!! Quote Link to comment
defdes Posted April 4, 2009 Report Share Posted April 4, 2009 I did however talk to a friend of a friend that has an FJ. I've been trying to buy that one for over 5 years!! It sounds like he might sell it to me though :D I would like to keep my L series 510 powered by an L series but I would do an FJ just because they are so bad ass!!! Keep applying the full court press...he'll crack eventually! Quote Link to comment
Zombro Posted April 26, 2009 Report Share Posted April 26, 2009 Can we get more General info about this motor in here? The Nissan FJ series engine Straight-4 DOHC 2.0- or 2.4 L internal combustion engine produced by Nissan in the 1980s The FJ20 weighs 366lb (166 kg); the KA24DE weighs 368 lb (167 kg). The 2.0 L variant was used in the US110 and US12 Nissan Silvia/Nissan Gazelle, and DR30 Nissan Skyline. The FJ has an aluminium head, chain driven cams, and an iron block. Turbo motors were only available in Japan and the non turbo variants were available in Japan, Hong-Kong, Australia and Europe. Datsun enthusiasts like to swap FJ engines into L or Z series powered vehicles. The FJ has similar mounting points to L/Z/KA blocks. It featured large ports,dual valve-springs and a wide angle bucket on shim valvetrain design similar to other (later) Nissan twincams like the VG, CA, RB, and KA, series DOHC motors and the previous S20 6 cyl DOHC motor from the early 1970's GT-R. This valve train design is also found in several motorcycle engines, it has a rev-happy over-square bore/stroke, combined with a stout forged bottom end, and wide bore spacing, the FJ20's strength is legendary . Quote Link to comment
Nismo Silvia Posted April 26, 2009 Report Share Posted April 26, 2009 The FJ20ET was also put into some JDM Silvia's in the 80's and early 70's. there was also the FJ24E which was a monster N/A engine used in the rally cars making these engine's even more rare than the FJ20E(T) It was originally only in some Skylines. I heard it was really made for racing homologation, and is way overengineered. The short block can handle 3 bar boost right from the factory ... Quote Link to comment
Nismo Silvia Posted April 26, 2009 Report Share Posted April 26, 2009 Don't quote me on this but I've heard that the FJ20ET and the FJ24E produced the same HP but different TQ arround the 270HP range frome the factory Quote Link to comment
610SSS Posted June 7, 2009 Report Share Posted June 7, 2009 FJ20t i love em. Ever since i went for a ride and drove my mates fjt 510:cool: Quote Link to comment
M.Creer Posted August 24, 2009 Report Share Posted August 24, 2009 FJ20's how much do they usually cost? Quote Link to comment
defdes Posted September 30, 2009 Report Share Posted September 30, 2009 Anywhere between $600 and $1500 depending on induction... it's importing all of the extraneous parts from Oz that adds up. Quote Link to comment
peterjems Posted November 27, 2009 Report Share Posted November 27, 2009 FJ20 Gearbox is nearly identical to the 6-Cyl L-Series gearbox, except for the bellhousing and the angle at which the gearbox sits. The bellhousings can be easily changed. The FJ20DET gearbox has larger bearings and is obviously thus stronger. Both models were available in only two vehicles, both of which came to Australia, but not with the FJ20 as an option. Quote Link to comment
610SSS Posted December 19, 2009 Report Share Posted December 19, 2009 Im picking up a complete fj20 and box for 1500, Just gotta get christmas outta the way and let my spending money grow back. Plenty of pics when i upload them. Quote Link to comment
ppeters914 Posted January 24, 2010 Report Share Posted January 24, 2010 I hate you! Seriously, I'd love a FJ20, and that one sure looks nice. Quote Link to comment
610SSS Posted January 24, 2010 Report Share Posted January 24, 2010 I hate you! Seriously, I'd love a FJ20, and that one sure looks nice. LOL, U should buy one, they're going cheap these days. :cool: Quote Link to comment
610SSS Posted March 26, 2010 Report Share Posted March 26, 2010 This thread needs more FJ20. :lol: Quote Link to comment
defdes Posted August 16, 2010 Report Share Posted August 16, 2010 This is from a long time ago but... Quote Link to comment
dat16v Posted August 17, 2010 Report Share Posted August 17, 2010 Me too: Engine Bay by iggy1600, on Flickr Quote Link to comment
610SSS Posted August 17, 2010 Report Share Posted August 17, 2010 Finally more fj action in here. :frantics: Quote Link to comment
