Ranman72 Posted December 27, 2014 Report Share Posted December 27, 2014 just going by what I read from Dmike in the other thread the motors came up in both threads recently Quote Link to comment
Laecaon Posted December 27, 2014 Report Share Posted December 27, 2014 Dmike can be a little non adventuress... The "other head" Im pretty sure is the same head, different valve cover, and yes it looks very good! 1 Quote Link to comment
Ranman72 Posted December 27, 2014 Report Share Posted December 27, 2014 adventures with trannys :devil: :devil: :devil: :devil: transmissions that is :thumbup: :thumbup: :thumbup: :thumbup: 1 Quote Link to comment
mrbigtanker Posted December 27, 2014 Author Report Share Posted December 27, 2014 Dmike can be a little non adventuress... The "other head" Im pretty sure is the same head, different valve cover, and yes it looks very good! Thats the one, It looks better inn my to me. Nissan's answer to Honda's VTEC Oh and by the way I just rubbed one out, God i am way to fast. 1 Quote Link to comment
Cmac Posted December 27, 2014 Report Share Posted December 27, 2014 First head is a p11 sr20de VVL. Second is a P12 primavera sr20de vvl. The P12 valve cover will bolt onto a P11 head and is a common swap. These two head swaps onto a sr20det are very well documented on the net. 1 Quote Link to comment
datsunfreak Posted December 27, 2014 Report Share Posted December 27, 2014 Hard to tell from that pic, but it sort of looks like part of the firewall was cut out? Have you never seen a NEO head converted for RWD?... In a 510 even! 1 Quote Link to comment
mrbigtanker Posted December 28, 2014 Author Report Share Posted December 28, 2014 Hard to tell from that pic, but it sort of looks like part of the firewall was cut out? It is because of the VVl solenoids behind the head. There is a company that makes a relocation kit to move it from the back of the head. 1 Quote Link to comment
kevwal Posted December 29, 2014 Report Share Posted December 29, 2014 You can use the P12 CAS or the Mazworx sensor and a solenoid relocation kit to work on the RWD bottom end. This has been done many times in several RWD applications. You also need to use the VVL metal head gasket with the VVL oil pump with a modified pickup. 1 Quote Link to comment
mrbigtanker Posted January 5, 2015 Author Report Share Posted January 5, 2015 I finished cutting all the little tabs out of the engine bay, I did not have a lot of time to work on it, Next is measure and cut the hole for the battery and start welding up all the holes in the engine bay. And i had to round up another tire for the left front so the car can be moved around easier. Quote Link to comment
mrbigtanker Posted January 5, 2015 Author Report Share Posted January 5, 2015 Going to take the hood in to have the under side media blasted. Quote Link to comment
mrbigtanker Posted January 5, 2015 Author Report Share Posted January 5, 2015 Pulled the hand brake off the colum, and thats it. I am going to rip all the steering components out later for powder coating just not now so he can or I can move the car around easier if needed. I also pulled the ignition out,that was a learning curve for me. 1 Quote Link to comment
mrbigtanker Posted January 5, 2015 Author Report Share Posted January 5, 2015 I could not figure out what the hell those other pins were holding the ignition on then i said screw it I am drilling it and come to find out, there a bolt rivot what ever thing. I guess thats 42 year old theft protection because the other side was 2 phillip head bolts. but its out and about. Quote Link to comment
Duncan Posted January 5, 2015 Report Share Posted January 5, 2015 Wow, you're really stripping that thing. You might be headed down a slippery slope my friend.. Quote Link to comment
shacks510 Posted January 5, 2015 Report Share Posted January 5, 2015 They're old school theft prevention. They're snap off screws. The heads break off once they're tightened from the factory. When I replaced my ignition, I used a dremel to cut a slot on the bald rounded nub that was sticking out and used a flat head screwdriver to back them out. 1 Quote Link to comment
mrbigtanker Posted January 5, 2015 Author Report Share Posted January 5, 2015 They're old school theft prevention. They're snap off screws. The heads break off once they're tightened from the factory. When I replaced my ignition, I used a dremel to cut a slot on the bald rounded nub that was sticking out and used a flat head screwdriver to back them out. Yea i found that out but its off and I got a new NOS set I bought for the wagon. Quote Link to comment
shacks510 Posted January 5, 2015 Report Share Posted January 5, 2015 Yea i found that out but its off andI got a new NOS set i bought for the wagon. They're only good for steering wheel locks. It isn't cool to start the car with a key. Quote Link to comment
mrbigtanker Posted January 11, 2015 Author Report Share Posted January 11, 2015 There i did something i cut a hole for the battery box. Quote Link to comment
mrbigtanker Posted January 11, 2015 Author Report Share Posted January 11, 2015 Has any one ever taken apart the hood mounts by cutting the riot to paint or chrome and then bolted back up with some sort of sleeve and nut and bolt? Some help would be nice.thank you Quote Link to comment
thisismatt Posted January 11, 2015 Report Share Posted January 11, 2015 Why not rivet it back together? Looks like a semi-tubular rivet like the wing windows on your 521. Quote Link to comment
mrbigtanker Posted January 11, 2015 Author Report Share Posted January 11, 2015 Why not rivet it back together? Looks like a semi-tubular rivet like the wing windows on your 521. Were do you get the riot gun for this size though. I have never see one. Its just there stiff and i would like to get it all painted or chromed right nor with it together. Quote Link to comment
thisismatt Posted January 11, 2015 Report Share Posted January 11, 2015 You'd have to ask one of your VW buddies I think. A button socket cap screw wouldn't look too bad I guess. Quote Link to comment
datsunfreak Posted January 12, 2015 Report Share Posted January 12, 2015 Has any one ever taken apart the hood mounts by cutting the riot to paint or chrome and then bolted back up with some sort of sleeve and nut and bolt? Roll pins with circlips like what holds the shifter on? 1 Quote Link to comment
tr8er Posted January 12, 2015 Report Share Posted January 12, 2015 What you are looking for is called a "book screw". It would be perfectly suited for the task, and removing the hood at the pivot would be rad. 2 Quote Link to comment
mrbigtanker Posted January 14, 2015 Author Report Share Posted January 14, 2015 Bought another set of NOS euro tail lights. Just in case I crack one. :rofl: Quote Link to comment
thisismatt Posted January 15, 2015 Report Share Posted January 15, 2015 I bought a storage locker sight unseen. Yup, full of NOS 521 tail light assemblies. Quote Link to comment
