heywier427 Posted August 13, 2017 Report Share Posted August 13, 2017 Id bang that jew. 2 Quote Link to comment
Profile Posted August 13, 2017 Report Share Posted August 13, 2017 Looks like the Trans-Am car in the late (I think) 80's. Don't think it ever won a T-A race. Quote Link to comment
q-tip Posted August 14, 2017 Report Share Posted August 14, 2017 Why is she wearing a newspaper hat? 2 Quote Link to comment
datzenmike Posted August 14, 2017 Report Share Posted August 14, 2017 Cheap, easy to make, easy to find, light and disposable. Used to make these when I was a kid. We made all our toys and play things back then. Quote Link to comment
VFR800 Posted August 14, 2017 Report Share Posted August 14, 2017 Why is she wearing a newspaper hat? If you're noticing the hat - then you're not looking at the picture correctly. 2 Quote Link to comment
q-tip Posted August 14, 2017 Report Share Posted August 14, 2017 If you're noticing the hat - then you're not looking at the picture correctly. Oh I noticed that the air-cooled flat 4 was sitting on the shoulder but that's all too common to comment about. 2 Quote Link to comment
VFR800 Posted August 14, 2017 Report Share Posted August 14, 2017 True. Needed moar shark in the pic to make it valid. 1 Quote Link to comment
q-tip Posted August 14, 2017 Report Share Posted August 14, 2017 True. Needed moar shark in the pic to make it valid. Always need more shark. 1 Quote Link to comment
difrangia Posted August 15, 2017 Report Share Posted August 15, 2017 I'm thinking V4 Czech ?? 1 Quote Link to comment
VFR800 Posted August 15, 2017 Report Share Posted August 15, 2017 I'm thinking V4 Czech ?? ZAZ 965 Saporoshez, made in the 1960’s in the Ukraine. Quote Link to comment
125 CSL Posted August 31, 2017 Report Share Posted August 31, 2017 This model V10 has fuel injection, a dry sump oil system, and a triple plate clutch. But this isn't just a model, this is a one-third scale model that displaces 125 cc... and it runs. http://www.modelenginemaker.com/index.php/topic,3007.0.html MAAAAD machine shop skills Intro from the link Hello all. After completing a V8 I decided I wanted to do another engine. V8 and V12 have been done so I thought I'd try a V10. Initial research showed there wasn't much info out there, but I figured out the firing order and crank design eventually.To get an even firing sequence the block vee should be 72 degrees, to match the crank angles.The Dodge Viper has a 90 degree block and unequal firing angles.Some engines have 90 degree blocks but have an 18 degree offset on the crank pins, to compensate.I decided on a 10 degree crank pin offset and an 82 degree block.It'll become more apparent when I get the pics up. It took a while for me to get my head round it all.I'm a couple of months into the build now, so I'll just bang a load of pics up first, to get up to date.I tend to just put pics up with a brief description, so if anyone wants more info then please just ask.I've got no secrets, everything I do is available if requested, drawings, methods etc.I also tend to make things up as I go along, so at the moment I've no idea what the heads or exhaust or cooling system etc is going to look like. 5 Quote Link to comment
