Daily Randomness.........Back to Randomness........................................
  • Replies 25.2k
  • VFR800
    2479
  • datzenmike
    2344
  • q-tip
    1360
  • hobospyder
    1255
I love you D-Mike.
meeting you, Lou, and Flatcat is the main reason I'm probably going to Canby. RVD can come if he pays for the gas and crack rocks
Flat won't be there.
Fucking Lou didn't go last year either
a glue lam is when 2x4 or 2x6 or 2x whatever are glued together stacked on top of one another and they are usualy built with a certain amount of arch in them
this is called a micro-lam which is plywood laminated together in a vertical pattern and are typically lazer straight
the house we are working on was built in the 60,s and had 4 2x12 bolted together with 1/2 inch bolts
we are remodeling the house and the 2x12 does not meet the snow load requirement for the area so we added 1 3/4 micro lambs to each side and bolted them together
glue lamb
FC9988B25A8BA39280DEE707533B1B42_boise_g
micro lam or also called LVL
 then there are also parralams which are particles compressed and glued together they are very dense and heavy
the engineer will use any and all of the above to meet load requirements and also to suit different installation needs
Oh, I now see the problem with my floor, I used lambs. Common mistake probably.
calm down i build airplanes not houses, be glad i didn't say thingamajig. we have those on airplanes, lots of them. and whatsits and bobbles
glue lamb
i was close, makes sense though, had to do that with my dads mobile a few years back. whole lotta work for... well he sold the house
