Icehouse Posted November 22, 2018 Report Share Posted November 22, 2018 1 hour ago, datsunfreak said: FYI, if you go with the twin cam KA24DE, there are much easier wiring options... https://www.wiringspecialties.com/s13-ka24de-datsun/ Or just get a can/am box. The wiring is so easy on S13 harness. I can't imagine spending 500 bucks for a pre made harness. 1 Quote Link to comment
Dguy210 Posted November 22, 2018 Author Report Share Posted November 22, 2018 (edited) 3 hours ago, Icehouse said: Or just get a can/am box. The wiring is so easy on S13 harness. I can't imagine spending 500 bucks for a pre made harness. Seriously this. I actually had a whole untouched harness I was going to use and my personal can/am knockoff. If I hadn't gotten the harness with the JWT ECU for way way less than the ECU itself I wouldn't have bothered. Edited November 22, 2018 by Dguy210 Quote Link to comment
datsunfreak Posted November 22, 2018 Report Share Posted November 22, 2018 15 hours ago, Icehouse said: The wiring is so easy on S13 harness. I can't imagine spending 500 bucks for a pre made harness. I can. It's not 25-30 years old like the S13 harness... ? Quote Link to comment
Icehouse Posted November 24, 2018 Report Share Posted November 24, 2018 On 11/22/2018 at 7:37 AM, datsunfreak said: I can. It's not 25-30 years old like the S13 harness... ? Must be your dry climate. Our harnesses are still really nice. The cars are rusted to hell through!! 2 Quote Link to comment
datsunfreak Posted November 25, 2018 Report Share Posted November 25, 2018 9 hours ago, Icehouse said: Must be your dry climate. Our harnesses are still really nice. The cars are rusted to hell through!! I don't think it's the dry as much as the oppressive summer heat? Any harness from a car that lives outside gets very crunchy after 20+ years. My 1200 harness is still decent, but that's spending 30+ years indoors. Every other 1200 harness I've seen here is literally falling apart. It's crazy... You guys definitely won the "wiring harness and window rubber longevity" lottery, we won the "way less rust" lottery... ? 1 Quote Link to comment
datzenmike Posted November 25, 2018 Report Share Posted November 25, 2018 9 minutes ago, datsunfreak said: I don't think it's the dry as much as the oppressive summer heat? Any harness from a car that lives outside gets very crunchy after 20+ years. ? Quote Link to comment
Dguy210 Posted June 22, 2020 Author Report Share Posted June 22, 2020 Almost ready for a shakedown run. Just need to get a driveshaft shortened (~1.5 in I think, actual measurements in my build notebook). Still lots of minor stuff left of course. 3 Quote Link to comment
datsunfreak Posted June 24, 2020 Report Share Posted June 24, 2020 On 6/22/2020 at 12:21 AM, Dguy210 said: Almost ready for a shakedown run. Just need to get the rear lowered... 😁 1 Quote Link to comment
Dguy210 Posted June 24, 2020 Author Report Share Posted June 24, 2020 4 hours ago, datsunfreak said: 😁 Lol, a lot of that is the big tires I've got on those rims I used for towing. They had a good offset for the 510 H190 diff in the rear and the tires are still decent so my cheap ass is leaving them on for now. I do kind of like the slanted front look though on the 1200 coupe's, always thought it paired well with the "mini musclecar" styling they can have. I've got a set of in still in the box Advan A3's rims that will eventually go on this car when I've got it running correctly which will drop it a bit. Although, now that I think about it I really should mock them up and see how their offset looks. Might need to move those to the B210 and find something different or find a different offset pair for the rear. I do keep flip-flopping back and forth on actually going the other way and raising it up more for driving on the dirt logging rounds. Front has custom coilovers already and I have a set of blocks in a box somewhere around here for the rear. 1 Quote Link to comment
datsunfreak Posted June 25, 2020 Report Share Posted June 25, 2020 6 hours ago, Dguy210 said: I do keep flip-flopping back and forth on actually going the other way and raising it up more for driving on the dirt logging rounds. I am a fan of that... 😁 2 Quote Link to comment
Dguy210 Posted November 25, 2021 Author Report Share Posted November 25, 2021 Update: It lives! Finally got a 510 driveshaft lengthened to fit it and the engine fired up. Engine runs but is a bit rough, probably a injector issue maybe, haven't torn into it to much aside from timing. Got some minor issues to work through as there is a bit of clutch drag (rear wheels turn in neutral when on jack stands) and a leaking heater core valve. Will dig into it and get it tuned in the coming months. Technically it currently is drivable. 1 Quote Link to comment
datzenmike Posted November 25, 2021 Report Share Posted November 25, 2021 If it's in neutral with clutch up and engaged, the countershaft is turning all the gears on the mainshaft. That's more likely just transmission oil transferring motion. Put the clutch down in neutral it should stop. 1 Quote Link to comment
Dguy210 Posted November 25, 2021 Author Report Share Posted November 25, 2021 8 hours ago, datzenmike said: If it's in neutral with clutch up and engaged, the countershaft is turning all the gears on the mainshaft. That's more likely just transmission oil transferring motion. Put the clutch down in neutral it should stop. Yeah, that specifically didn't occur to me but makes sense too. I kind of figured it might be something that if sitting on the ground it wouldn't move. It is a bit of a kludge of transmission/engine/clutch etc.. so I was just being safe when testing it initially. Quote Link to comment
Dguy210 Posted February 14, 2022 Author Report Share Posted February 14, 2022 Well that only took 9 years to get it moving under its own power. Still need to adjust idle and do a bunch of other little things. Converted to gif to get it to upload here. 6 Quote Link to comment
datsunfreak Posted February 14, 2022 Report Share Posted February 14, 2022 11 hours ago, Dguy210 said: Well that only took 9 years to get it moving under its own power. Took me 11 years, so you're doing good. 😋 And my car did not run under it's own power from 1990-2019... 1 Quote Link to comment
Draker Posted February 16, 2022 Report Share Posted February 16, 2022 Dude! Congrats! 1 Quote Link to comment
Zrookie Posted March 10, 2022 Report Share Posted March 10, 2022 Any updates? 1 Quote Link to comment
Dguy210 Posted March 11, 2022 Author Report Share Posted March 11, 2022 14 hours ago, Zrookie said: Any updates? 2 hours ago, Mattndew76 said: Yeah! Lol, no. Fixing small stuff. Still trying to get it to idle right. Think the IACV is likely having problems. Considering getting it registered soon. Quote Link to comment
Dguy210 Posted November 19, 2023 Author Report Share Posted November 19, 2023 Finishing off this thread. The 1200 is pretty much done at this point. Still a bunch of random noises to sort out but it is drivable without making me deaf. Going to pivot away from this at this point and start work on the 510 which has been sitting in the shop since 2020. 2 Quote Link to comment
Dguy210 Posted November 19, 2023 Author Report Share Posted November 19, 2023 As seen in the 1200 threads. 3 Quote Link to comment
