Ryoskatekov Posted April 21, 2013 Author Report Share Posted April 21, 2013 throw some octane booster and your tank and see what happens, the motor in my eclipse is a swapped jdm 6bolt 4g63 and was getting pre-detonation every now and then on 86 octane, put some premuim in there and I didn't get any pre-detonation, tried 86 octane again later on and it started knocking again. I am currently using high octane gas... Plus, I'm even on colder plug (BPR6ES-11) than what the engine had (BPR5ES) and changing the plug to colder ones gave me a little more power... Im not sure if its Pre-ignition... also it doesn't make the sound when rpm is dropping no matter what range it is in btw. and it makes a small.. Very small mis/backfire every 3~5 sec or so randomly at idle. Quote Link to comment
Ryoskatekov Posted April 22, 2013 Author Report Share Posted April 22, 2013 video was going to make one, but I forgot to bring microphone and camera with me yesterday... Quote Link to comment
Ryoskatekov Posted April 24, 2013 Author Report Share Posted April 24, 2013 FUAAAAAAAAAAAAAAAAAAAAAAAQ Hopefully 215/60/r15 can clear the spring perch and struts... Quote Link to comment
Ryoskatekov Posted April 24, 2013 Author Report Share Posted April 24, 2013 #Hellalift4lyfe 1 Quote Link to comment
Ryoskatekov Posted April 24, 2013 Author Report Share Posted April 24, 2013 I'm really hoping It'll clear.... Quote Link to comment
Laecaon Posted April 24, 2013 Report Share Posted April 24, 2013 They should fit... Widest part is right at the rim, and should only go past the rim if the tires have rim protectors on them. Assuming 15x9 and 215/60/15 on the front. Quote Link to comment
Ryoskatekov Posted April 24, 2013 Author Report Share Posted April 24, 2013 They should fit... Widest part is right at the rim, and should only go past the rim if the tires have rim protectors on them. Assuming 15x9 and 215/60/15 on the front. ^ woah, Exactly the tire size I was planning on getting. Yeah Hopefully it does... cause I think 215 stretched on 15x9 should clear the spring perch (NOT SHOWN ON PIC) the strut case its self isnt too much of a problem Quote Link to comment
Ryoskatekov Posted April 28, 2013 Author Report Share Posted April 28, 2013 You can barely hear the rattle but ad the engine warms up and visco goes down, it starts making the noise vid of warmed up engine you can sorta hear the ratatatatata sound at beggining but barely.... It makes no vibration of that of piston,rod slaps My best bet is that I'm not familliar with noises older car makes Quote Link to comment
PurePontiacKid Posted April 28, 2013 Report Share Posted April 28, 2013 plz no 215/60 plz 195/60 or 205/55 Quote Link to comment
Ryoskatekov Posted April 29, 2013 Author Report Share Posted April 29, 2013 plz no 215/60 plz 195/60 or 205/55 Srsly , Im NOT going that low anytime soon. Houston roads are terrible and i can barely clear my driveway at stock height and its guna look stupid with huge arse wheel gap. I got Fat wheels... I want fat tires. Quote Link to comment
Ryoskatekov Posted April 30, 2013 Author Report Share Posted April 30, 2013 Well probably due to the 200k miles + hot houston weather and design of damn non cross frow inline six, the poor z suffered heatsoak / slight vaporlock yesterday. So I did this Hard to see but put heatshield tape allover the stock top portion of in-mani and injector and fuel lines. hopefully itll stay on there. also guna prly make a custom fiberglass induction cowl to replace the crappy hood vents Quote Link to comment
datzenmike Posted April 30, 2013 Report Share Posted April 30, 2013 Anyways, I took off the Injector fans that seemed non funtional. (or atleast I hope it was) I hate when things come back to bite you in the ass... Quote Link to comment
Ryoskatekov Posted April 30, 2013 Author Report Share Posted April 30, 2013 I hate when things come back to bite you in the ass... Lol, When I ment "non-functional" I mean It really wasnt working... Someone in the past seems to have replaced the fuse but it was blow again somehow... So I assumed If I put the fuse back in there it'll blow again.. Probably a short in the circuit somewhere... and I'm not all that electrical.. Quote Link to comment
Ryoskatekov Posted May 7, 2013 Author Report Share Posted May 7, 2013 So I drained my oil yesterday and its finally stopping to drip... and guess what came out. Quote Link to comment
Dirttrack510 Posted May 7, 2013 Report Share Posted May 7, 2013 I'm guessing little shiny metal bits... :( Aka... glitter Quote Link to comment
Ryoskatekov Posted May 7, 2013 Author Report Share Posted May 7, 2013 I'm guessing little shiny metal bits... :( Aka... glitter gladly and amazingly none of that from looking at the pan. might be able to see some when i put it back in the container Quote Link to comment
Ryoskatekov Posted May 7, 2013 Author Report Share Posted May 7, 2013 oil? yes... its oil if you could even call that anymore... Quote Link to comment
Ryoskatekov Posted May 8, 2013 Author Report Share Posted May 8, 2013 Heres another lame video... but the crappy microphone quality sorta stood out the sound I was talking about. Quote Link to comment
Ryoskatekov Posted May 9, 2013 Author Report Share Posted May 9, 2013 My steering wheel was squishy as tofu... So I chopped it up like one and put double layer of Road Bike tape. Fab'd up some Injector Heatshield from Sheet metal and rivets... Still not sure how effective this one would be. Quote Link to comment
Ryoskatekov Posted May 12, 2013 Author Report Share Posted May 12, 2013 well I reinstalled the ignition fan and I check the motor with multi meter and it works.... but somewhere in the circuit its fucked up. I'm missing 2 relays in the box.... any clue? Quote Link to comment
Ryoskatekov Posted May 15, 2013 Author Report Share Posted May 15, 2013 nvm got it working. I just made a ground witch for the water temp Quote Link to comment
datzenmike Posted May 15, 2013 Report Share Posted May 15, 2013 My steering wheel was squishy as tofu... So I chopped it up like one and put double layer of Road Bike tape. . You should try holding the 510/610/710 wheels. Hard as rock and about as thick as your little finger. Your hand get bruised from lots of hard steering. I have that model steering wheel in both my 710s and love the feel and the horn locations. Perfect. Quote Link to comment
