wanted interior rear view mirror
INTERIOR MIRROR
THINGS I HAVE TO TRADE
A PAIR OF INTERIOR DOOR HANDLE 520/521 CHROME OE
A PAIR OF WINDOW CRANKS WITH BLACK HANDLES OE I THINK
ONE PASS REAR MARKER LIGHT ASMBLY OE A LITTLE FADED
A PAIR OF FRONT 521 TURN SIGNAL LENSES
A OE BUTERFLY FUEL CAP
A 521 OE BROWN ASHTRAY IN FAIR SHAPE / A FEW CHIPS ON LIP
HAS A PETRIFIED ROACH IN THE CORNER
A PAIR OF 68 GOON TAIL LIGHT LENSES SOLID RED EURO NEW AFTERMARKET
A 520/521 USED SHIFTER BOOT IN GOOD SHAPE
A STOCK 78 L20B CARB W EL CHOKE & IDLE SHUT SOL.
NOT REBUILT , LOOKS GOOD
A OE CIGAR LIGHTER FROM A 620
A E OR A SER ENGINE EL DIZZY MATCHBOX DIST WITH NO MOD.
ON IT .
I CAN ALSO PAY MONEY FOR THESES PARTS SO PLEASE PM IF YOU HAVE ANY
  • Replies 11
To get back to the original posting title. 68 510 or 66 520? You didn't specify and the track record on mind reading is poor.
P.S. Stop shouting with the all caps! Bad manners unless you are using an original TI99 that didn't have lower case.
On my 620 I simply did away with the stock one. I glued a Monte Carlo one on. Has twin map reading lamps along the bottom, easy day/night and the interior lamp door switches can be wired so it works like an interior lamp. If you are trying to remain stock please ignore.
Great suggestions was kinda going for stock vintage look.
I searched ebay vintage rear view mirror and found some cool options
67 vdub bug & bus look pretty good for the price. I always liked the offset
oval 67 bug mirror. But i bid on a older oval unknown mirror. I guess ill find out.
But thanks for idea i could go with map.lights and compass too.
Im stoked think a chevy truck one wire alt. Is going to fit on my j1300 easy.
I saw some info you mentioned Datzen about saturn alt. and was going to pick a part
to find one but after removing the alt the PO started to put on,reman motorcraft
I see the bracket is more like a chevy type. Went to atic found a internal reg chevy alt
The will work. Made me happy not to go to muddy cold junk yard but still got something
Done.
