Shonuff Posted May 14, 2008 Report Share Posted May 14, 2008 just wait, i bet the lifted celica will end up towin us both home at the same time:lol: its been awhile sence i used a celica as a tow rig....ahem ryaninseattle cough cough Quote Link to comment
Shonuff Posted June 11, 2008 Report Share Posted June 11, 2008 well his jeep aint on crack any more.... sounds more like rocks listen real carefully and you can here the quality tranny from detroit i already did a thread about this particular adventure over on a celica board, and im too lazy to cut n paste over here. but its just one click away (might be a lil toyota biased tho) http://www.celica-gts.com/forums/index.php?showtopic=14653 Quote Link to comment
]2eDeYe Posted June 11, 2008 Author Report Share Posted June 11, 2008 BOOM Clack Clack Clack Clack Clack Hey whats all that smoke...Dood your on fire :D Quote Link to comment
Shonuff Posted June 11, 2008 Report Share Posted June 11, 2008 ya i never seen that much smoke from a clutch b4, cant wait to see if there is anything left of it, and what type of river rocks you got in your tranny now, they must be polished up pretty nice:fu: Quote Link to comment
]2eDeYe Posted June 12, 2008 Author Report Share Posted June 12, 2008 Dunno going to pick up the Jeep tonight. I'll have the tranny out on Sat. :) Quote Link to comment
]2eDeYe Posted June 24, 2008 Author Report Share Posted June 24, 2008 Yep, crack, my jeep is all over it... Quote Link to comment
]2eDeYe Posted August 11, 2008 Author Report Share Posted August 11, 2008 So the new T18 4 speed kicks ass. The new low range in the t-case does as well. I swapped some Dana 18 gears into my Dana 20 to get a lower low range. Had to fab up a crossmember as the stock one was mangled beyond repair... Here's some pic's cause I like them, even if nobody else is reading this thread but me and nuff 😛 old crossmember New crossmember. Gonna weld some 'ramps' on there to smooth over the bottom...or maybe I'll just go wheelin and get some work done on the datto. Took it out for a test drive last weekend. I need a new powersteering pump and brackets...mine got broke somehow 😛 Oh and nuff is a wus :fu: I actually got all my underhood wiring repaired Sat. so hopefully no more mysterious ignition problems. Even got the new horn wired up. Now I just have to learn how to drive without full throttle and clutch madness 🙂 Quote Link to comment
yello620 Posted August 12, 2008 Report Share Posted August 12, 2008 Sucked on a little seat vinyl at the end of that video didnt ya.. Steve, you need a spring over with so soft springs to get so articulation out of that thing. Jason Quote Link to comment
Cuts metal like mad Posted August 12, 2008 Report Share Posted August 12, 2008 love it... HA! My bros FSJ has a very similiar setup, the D20, T18 (unusable 1st on the street), D44s fr n rr, 258... etc we'll be doing the spring over and maybe pull a leaf, he also wants 39s (his 35" procomps have like 2000 miles on them if that lol) with better gears, aussie lockers, and a chev vortec 350... but we'll see Quote Link to comment
]2eDeYe Posted August 12, 2008 Author Report Share Posted August 12, 2008 Ya, that was a fun almost flop, definetley got the blood flowing :) I haven't decided what to do with the suspension when I build the new frame, but I'm starting to think 4-links and coilovers are in my future... Quote Link to comment
Shonuff Posted August 12, 2008 Report Share Posted August 12, 2008 2eDeYe;73508'] I actually got all my underhood wiring repaired Sat. so hopefully no more mysterious ignition problems. Even got the new horn wired up. Now I just have to learn how to drive without full throttle and clutch madness :) so can i have my spare yota coil back? :fu: heep ones dont fit in yota brackets. the day you start easing up on the throttle is the day i like off camber trails:D and you need ta truss your x-mem, when ya got the full wheight of the heep on it it flexes a bit. Quote Link to comment
]2eDeYe Posted August 12, 2008 Author Report Share Posted August 12, 2008 Bet it don't flex near as much as that stock one lol :D Quote Link to comment
Icehouse Posted August 12, 2008 Report Share Posted August 12, 2008 You guys are crazy!! I like to watch but you wouldn't catch me in that thing :D More vids!! :D Quote Link to comment
]2eDeYe Posted August 13, 2008 Author Report Share Posted August 13, 2008 Buddy in a stock K5 on the same spot You'd have a blast Ice, full throttle assaults are legal and sometimes required :D Quote Link to comment
Shonuff Posted August 13, 2008 Report Share Posted August 13, 2008 what no love for me or danger ranger :eek: :fu: believe it or not this was the most reliable rig that day flat tire wheelin not quite enuff mass Quote Link to comment
hang_510 Posted August 13, 2008 Report Share Posted August 13, 2008 2eDeYe;73660'']full throttle assaults are legal and sometimes required :D ...sometimes :eek: Quote Link to comment
]2eDeYe Posted August 13, 2008 Author Report Share Posted August 13, 2008 The rest of the time it's just for fun :D Quote Link to comment
]2eDeYe Posted October 8, 2008 Author Report Share Posted October 8, 2008 I got some more work done on this thing...Went to Walker Valley a couple weeks ago, had a blast, wheeled all day and din't break anything...did get stuck in low range though. The drive home with 35 mph top speed was goodtimes. 😄 First room had to be made, and since I'm in the design stage on the datto I had some room to make. :lol: 😛 Found a bent spring under my shift rail retention ball, easy fix, but I had to pull the t-case...shift's like butter now though. Figured I'd take care of a few other things I've been slackin on while I have it in the garage. Got a deal on a full set of longer shocks. Picked up some Ford F-250 shock towers from the dealer (can't beat $15 each). A little cuttin and weldin and I got them mounted up in the front. old junk new junk Also gonna redo my drag link,x as it's too short after the steering box fixes I did...and the tie rod needs a bit of straightening and reinforcement as well. To top off the steering I ordered a full set of tie rod ends, better safe than sorry 😄 I also removed the spring clamp bolts from the front springs for a little more flex. Then I welded the clamps to the spring to keep the leafs in line (the rivets weren't holding the clamps on anymore). There's still another clamp holding 2 leaves to the main leaf front and back on each spring. Still gotta relocate my front brake lines and stick the t-case back in, should be ready for some wheeling this weekend 😄 Quote Link to comment
Phlebmaster Posted October 8, 2008 Report Share Posted October 8, 2008 That looks like alot of work! But I bet the fun is worth it. I like your vids. Quote Link to comment
]2eDeYe Posted October 8, 2008 Author Report Share Posted October 8, 2008 Added a pic.... It's all fun. Half the fun of a Jeep is chasing the weak spots and upgrading. The other half if is pointing the next one out by goin wheeling after you work on it. :D Quote Link to comment
Shonuff Posted October 9, 2008 Report Share Posted October 9, 2008 1 hr wheelin = 2 hrs werkin Quote Link to comment
xtrmemtnmn Posted October 9, 2008 Report Share Posted October 9, 2008 2eDeYe;86840']Added a pic.... It's all fun. Half the fun of a Jeep is chasing the weak spots and upgrading. The other half if is pointing the next one out by goin wheeling after you work on it. :D I agree that is why my jeep is the way it is, pretty much rebuilt the whole thing, I found all the weak spots...ha ha Quote Link to comment
]2eDeYe Posted October 9, 2008 Author Report Share Posted October 9, 2008 Yep, figure I'll keep patchin and learning until my parts hauler is finished. Then rebuild the Jeep completely with what I've learned. :) Quote Link to comment
hang_510 Posted October 9, 2008 Report Share Posted October 9, 2008 owning a jeep means... 1 hr wheelin = 2 hrs werkin Quote Link to comment
]2eDeYe Posted October 9, 2008 Author Report Share Posted October 9, 2008 lol... That guy you quoted wheels a yota, same rule applies no matter the brand ;) Quote Link to comment
