620 rear end
  • Replies 50
Well got my new u joints in while it was out took the diff apart an it's not good had metal shavings like No tomorrow pinion gear is missing some bite an after a lil I seen the pin that go's through the carier for the spider gears was out some Well it was snapped an was hitting the ring gear great day to spend my bday Lol but at least I checked it
Pics when I get home
good on u-joints and uhhhhhh errrrrrrrr :blink: ouch !
Yeah pics would be good errrrr ...
Can you just swap in a new H190 carrier ? ( If tight on money )
Maybe a whole new rear end swap is easier. IDK honestly as I have never worked on one.
I would try to get the shavings out of the axle as much as possible before re-assembly though.
If it were me ,,, I would just go with an entire good used axle assembly as you planned before :)
but that's just me !
'79 4 and 5 speeds had 4.11 gears. I doubt you will find a set as that was the only year for the 620. All 2wd '80 720s had them and automatic long boxes. On the 720s look on the engine tag located on the inner fender under the pass side hood hinge. Look on the lower right corner. If it says HF43 that's a 4.375 ratio, HF41 is 4.11 and so on. The 720 tag below is HF38 for a 3.889 ratio diff. I wouldn't use a 4x4 diff stick with 2wd.
If you can only find 4.375 be sure to pull the speedo drive cog out of that transmission. It's mated to the rear end and when swapped into your tranny will keep your speedometer accurate.
If you have a '79 standard transmission it came with 4.11 from the factory.
Well you have it out.... look on the outer rim of the crown gear. The ratio is stamped there.
37/9 = 4.111
35/8 = 4.375
37/8 = 4.625
419992_472423529442574_1651022999_n.jpg293143_472422206109373_931064032_n.jpg there is the poor thing the shaft was fused to the spider gear on the other side hit it with a sledge hammer an cant even get it out the
I bet that,, that is as bad as it could be and still be able to drive it around..
Oops ,, i just noticed this was a wanted ad after i posted,,,sorry man.
Guy here in Springfield (OREGON) has a good rear-end 4 $75. I know he would take less...he made me a smokin deal on some other parts. Check the Craigslist postings in the "eugene" area & you should spot the ad. I regularly put 12oo-2200 lbs of payload(scrap steel) in my 82 720, and pull a trailer (1500-5000lbs) and have had ZERO problems w/the rear end-wheel bearings-driveline-ujoints. I do run redline synthetic fluids trans &rear-end. Believe it or not I have had 3060lbs(in other words 1.5 tons!) of steel in the back of my pick-up B-4 & drove 50 miles (30-50mph)......all time record truck-n-trailer together 10,215lbs-five tons+(1500frt axle,4480lbs rear axle, rest trailer). I have the load/scale tickets 2 prove it!! Someone must have been real "mean" or done something stupid to hurt the rear-end........I have had 3 720's 82-85-86 and couldn't break any of them. The 85 had 298 thousand miles (didn't burn any oil) & I never heard a clunk/whine/ping/etc from the rear-end.
If you can't find the ad 4 the rear-end message me and I can dig up his e-mail I think. I need a windshield/gasket (cheap/free) 4 my 74 620 if u know of one. Also have a L18 w/ 120k original miles 4 sale (very strong!).Thanks...hope this helps.
