VintageRice Posted July 14, 2012 Report Share Posted July 14, 2012 Ok, how bout this. I took the stock ebrake out of my 510. Cable was bad, wanted a floor mount. Before my ka swap I had a sentra floor mount e-brake set up and worked pretty well but not perfect. Now the Ka shifter is in the way, and my new center console just wont accommodate a off center lever. Sooooooooo. I was trying to think of a creative way to pull the e-brake cable remotely. Just for parking purposes, dont need e-brake slides(although they are fun!) How bout this! Make some mounts for under the car, attach cable to this actuator, and e-brake is engaged at the flip of a switch. Good idea?? I wonder if these need constant power to hold the load or just to engage one way or the other. If so it could will drian the battery, But I think its just using power when it moves. Anyone like this idea??? I might try it. Actuator like this(or similar) http://www.ebay.com/itm/4-stroke-1-7-in-sec-12v-450lb-static-load-liner-actuator-/251103752153?pt=LH_DefaultDomain_0&hash=item3a76f32fd9#ht_500wt_1416 Quote Link to comment
VintageRice Posted July 14, 2012 Author Report Share Posted July 14, 2012 For example Quote Link to comment
Boaty Posted July 14, 2012 Report Share Posted July 14, 2012 Electronics fail. Fuses blow. What happens if battery dies? Quote Link to comment
Laecaon Posted July 14, 2012 Report Share Posted July 14, 2012 Electronics fail. Fuses blow. What happens if battery dies? If left in gear appropriately car might roll 1cm and stop again... Quote Link to comment
72240z Posted July 14, 2012 Report Share Posted July 14, 2012 If left in gear appropriately car might roll 1cm and stop again... Not if your on a real hill. Lots of stock higher end cars use push button ebrakes. I personally like a cable, it can fail just as easily as an electronic part but if I wanted a bunch of electronics I wouldnt own a 40yo car. Quote Link to comment
ggzilla Posted July 14, 2012 Report Share Posted July 14, 2012 Lots of stock higher end cars use push button ebrakes.Yes, but they work differently than the proposal here. Quote Link to comment
Laecaon Posted July 14, 2012 Report Share Posted July 14, 2012 Really? I need to measure, but my driveway is probably about 15-20 degrees. I guess if both electronics and compression fails, well fun. But really this is only viable if the actuator holds without electricity. And if it does that, then it is all mechanical whether it fails or not. Quote Link to comment
Laecaon Posted July 14, 2012 Report Share Posted July 14, 2012 http://www.creativecontrolsinc.com/products/epb.htm Quote Link to comment
datzenmike Posted July 14, 2012 Report Share Posted July 14, 2012 Hand or foot e brakes have been around for ever and they work and hardly ever fuck up because they are simple and human powered. The only thing that works as good and is simpler is a fuckin' brick. Quote Link to comment
Alex Datsun Posted July 14, 2012 Report Share Posted July 14, 2012 why not just do a hydro ebrake? I would be terrified to watch my car roll down the hill when my battery is low or fuse blows Quote Link to comment
Laecaon Posted July 14, 2012 Report Share Posted July 14, 2012 I would be terrified to watch my car roll down the hill when my battery is low or fuse blows Again, why is battery power holding it? That is retarded, and mentioned in the first post, of course it would drain the battery if it was only held with electricity applied, and therefore a flawed system. But its not held by electricity. It is locked into place mechanically. You could remove the battery and its not going anywhere. I say try it! Sounds simple enough. You already have half the mind to do so, and probably have done a fair amount of research. Quote Link to comment
bananahamuck Posted July 14, 2012 Report Share Posted July 14, 2012 It would work just fine ..If the battery died it would be stuck ON it because it couldn`t rotate therefore could not move..Have a jumper wire back up just in case battery dies or fuse blows.... ,,,,,having typed all that, i personally would try to make a " normal " one work ..less chance of it not--not working.. Quote Link to comment
DAT510 Posted July 14, 2012 Report Share Posted July 14, 2012 Kiss Keep it simple stupid 1 Quote Link to comment
HRH Posted July 14, 2012 Report Share Posted July 14, 2012 Why is everyone parking on hills? I rarely ever use my e-brake unless the hill is stupid steep. And then, why am I parking there? (Excluding San Francisco ratsuners.) 1 Quote Link to comment
kelowg Posted July 14, 2012 Report Share Posted July 14, 2012 if actuator is connected to standard type e brake mechanism(ratcheting part of it) then it would work fine. figuring out how to actuate release mechanism, require a little creativity. Quote Link to comment
datzenmike Posted July 14, 2012 Report Share Posted July 14, 2012 Why is everyone parking on hills? I rarely ever use my e-brake unless the hill is stupid steep. And then, why am I parking there? (Excluding San Francisco ratsuners.) I always set my hand brake. First a foremost it reduces the chance of the car moving... for any reason. If nothing else no one can push it somewhere. What if your car is hit or nudged by another car? it could roll out into traffic. Second.... the cables won't rust up if constantly used. Nothing worse than just once having to actually use the e-brake and you pull it on but it's so stiff and rusty it won't release. The e-brake should always be in good working order... after all, it's your back up braking system, the most important safety system on your vehicle. Quote Link to comment
72240z Posted July 14, 2012 Report Share Posted July 14, 2012 Why is everyone parking on hills? I rarely ever use my e-brake unless the hill is stupid steep. And then, why am I parking there? (Excluding San Francisco ratsuners.) My town is the 2nd hilliest town in the country behind SF. Dont have the luxuary of always parking flat lol. Really? I need to measure, but my driveway is probably about 15-20 degrees. I guess if both electronics and compression fails, well fun. But really this is only viable if the actuator holds without electricity. And if it does that, then it is all mechanical whether it fails or not. Its not a failure of compression its a matter of weight vs the gear ratio. My truck in 1st on even a moderate hill creeps, very slowly an inch at a time. Since my truck is so high and easy to do damage to others I chock it when on hills. Quote Link to comment
brodster Posted July 15, 2012 Report Share Posted July 15, 2012 I haven't researched this particular actuator, but it appears to be a DC motor driving a gear. If there is no mechanical latching mechanism, I wouldn't recommend using it. I think people unfairly give electronics a bad rap; however, with any mechanal latching, this thing would just sit there and consume power. Worse I am not sure if that thing is designed to constantly hold a load under power. Your standard DC motor when stalled or stopped has no counter electro-motive force. In other words a stalled DC motor only has the winding resistance to impeded current. This would mean the motor would just fry. However, if you could couple this linear actuator with a mechanical latch, that may be really cool. And besides the complication (which really isn't that bad) it should work just fine. Also, for an E-Brake I think a hydro brake is not a good solution. My understanding is that these hand brakes are more suited for drifting and such. A cabled E-brake, separated from your hydraulic system, provides a pretty fail-safe isolated means of making sure your car doesn't roll down hills. Quote Link to comment
