cant really think of a clever title...... 710 coupe
Skib
How did you remove the stainless trim around the rear window? I'm having a tough time popping the trim off of my car.
will, i use a dental style hook/pic. Its verry easy to break the clip, or tweak the trim. The fsm does cover it breifly. Start in the middle of the trim peice and shim it away from the glass gently, you might have to get a popsicle stick in there to push the sealent aroumd but once yu see the clips you can hook the edge of the clip with your pic, then pull it gently. There are several clips on each peice, make shure to shim eah on away from the window when you get them unhooked or they snap back in.
  • Like 5
  • Replies 697
