Bamboo Banzai
Skib
Ah, gotcha. I did a rear pan for my KA. Definitely better than flipping the crossmember for a number of reasons.
Isn't the E pretty close to the L-series pan? Is it just the bolt pattern that's different? Haven't messed with em much..
  • Replies 380
I concur
not sure I havent pulled it off and looked yet. thoughts crossed my mind tho.
got plenty of work to do before I get around to the oil pan.
I just drilled out the a-arm pins and flipped them. With a drill press it was no problem at all. Though having the pan more protected would probably be a better Idea. But since they make new sway bars that fit the front sump that is not a factor. I don't like cutting the center of the cross member which is why I just fliped the pin mounts. It was easy.
yeah they make em for the front sump but DGR is no moar and shipping from AUS sucks koala balls.
if your flipping the cross member doing the pins is the way to go.
Tom brought a drill press for the shop but the jig as long been MIA.
for me personally its simpler to flip and fab a pan. its more labour but Ill be happier with the end result.
the name of the project is bamboo bonzai, that should give an indication of the colour
So green and tan with black flares OR is it going to be Black and white like the Pandas that eat the Bamboo?
Or literally a faux bamboo bark paint scheme with green leaves here and there? lol
there is a concept drawing in the thread ;)
literally just going to glue bamboo stalks all over the car
picked up a mckinny sr/ka trans crossmember at the swap meet
shavin the shit out of the bay and should be sealed/painted soon
as it sits
