Duncan's 71 "Oz" Goon
Duncan
  • 4 months later...
  • Replies 1.8k
Been quite a while since I updated this thread.  I've just been driving and enjoying the wagon over the summer.
I have a chromed valve cover on the L20B in my wagon, and it's looks okay in photos, but in person the chrome doesn't look so great, so I decided to do a little something to it to make it look better.  Frankly, I've been a bit embarrassed when people ask me to see under the hood..
I popped the valve cover off and hit a few chrome shops to find out the cost of having the chrome removed, and most places quoted me $70-$80 dollars just to remove the chrome.  I can buy a used valve cover for $50-$75 that has never been chromed so a quick call to a friend turned up a suitable one for free...
I haven't really decided yet what to do with it, so I stripped off the paint and was very careful not to put any deep scratches in it.
My friend has a bead blast cabinet at his shop, so I'm going to take it over there this coming week and give a glass bead shower.  If I like it, I might just use some urethane clear on it.  I can also paint it, polish it, or powder coat it.  We'll see what happens.
Edited by Duncan
Color match your car.
Will probably do that.  I already have the paint.  I'll probably throw a few coats of clear on top of it to make it more resistant to fumes and oil stains.
I even have some pearl flakes I can throw in the clear to make it look all sexy like a stripper at the gentleman's club...
Edited by Duncan
  • Haha 2
On 12/4/2019 at 8:28 AM, the510keeper said:
Whatever you do im sure it will be bad ass
Thanks James.
I need to pick up some clear, but I'm going to paint it to match the car.  I may actually put a small bit of pearl in the clear, but we'll see.  That may be a bit out there for this old fart.
If I knew someone decent and close by, I was thinking it could be fun pulling a few pinstripes on it.
I did bead blast it, and it didn't clean up as well as I had hoped, so straight clear is out the window...
Edited by Duncan
3 hours ago, mrbigtanker said:
Mold in the the vent. And round out the spark plug wire holder.
Highly doubt it's mold.  I'll be sure to soak it in Lysol and CLR prior to spraying the primer, just in case.  🙂
Edited by Duncan
7 hours ago, hobospyder said:
I think he meant shave it off and patch the hole to clean up the top of the cover
Well that makes sense.  Never heard that term called mold before 🙂
I actually like the wire holder, and I think blocking the vent is a bad idea.  But, that's just me...
You don't need it. It was an emissions thing, you have a block vent already. Or go see John he has a old twist cap cover if you want.
You really do need the valve cover vent. It's how filtered make up air gets into the engine to replace the vapors drawn out through the block vent by the PCV valve. Fresh air in and dirty combustion gasses and water vapor out. Oil and engine block stays cleaner. In the 50s it was common to change the oil at 1,000 mile intervals and engines rarely got to 100K miles. By the 60s most all cars had oil filters and the PCV valve ('62?) helped extend this to 2,000 miles. Better oils have extend this again to at least 3K miles. The Positive Crankcase Ventilation is one of the greatest inventions ever put on an internal combustion engine. It's importance should never be under estimated just because it doesn't seem to do much, but in reality it more than doubles the life of an engine.
14 hours ago, mrbigtanker said:
I fuckin love it. Just needs a John Williams oil cap.
Yeah, John makes nice stuff, for sure..
Problem is now I'm putting lipstick on a pig.  I wanna go through the L20 and make it look like yours, but I'm still a bit burned out working on it for now.  I still have to pull the gas tank and get the fuel sender modified and getting it reading correctly.  Always something..
Thanks for the kind words, Ray!
Edited by Duncan
