Form > Function S30
Got the battery relocation finished yesterday. There's not a whole lot of room in the hatch, so I'll probably be getting a Miata battery and cutting a hole in the hatch floor so it'll sit down lower.
The 4g wire we sell at work is shitty, so I just got a set of Kobalt jumper cables, cut off the alligator clips, crimped on connectors and battery terminals, and ran the ground to the transmission bolt next to the starter. Starts perfect now.
  • Replies 780
Wheels should be here next weekish. Diamond has to build the wheels to order so it takes about 2 weeks.
My wheel fell off when I was driving back in the day, and the fender I replaced it with wasn't straight. Idk why, but it was crushed in about an inch. You can kind of tell in the pictures that it doesn't flare out as much as the other side.
