ComicArtist Posted July 24, 2013 Author Report Share Posted July 24, 2013 PBM sleeves are aluminum, idk what the thread pitch is, I just dropped off one of the coils at a machine shop and told them what I wanted Quote Link to comment
Alex Datsun Posted July 30, 2013 Report Share Posted July 30, 2013 Dam yo thats pretty harsh but glad to see the suspension is revitalized which my will be on its way over time. Quote Link to comment
ComicArtist Posted July 31, 2013 Author Report Share Posted July 31, 2013 Dropped the spindles off to be welded last night, should be tigged up and ready to go in a few days. Before powdercoating I'm having the old bearings pressed out, and new ones pressed in after the powdercoating, then they'll be going back on the car. 1 Quote Link to comment
Camtron Posted August 1, 2013 Report Share Posted August 1, 2013 Where do you get your powder coating done? I live a few hours southeast near McAlester, but I'm in OKC quite a bit. I've looked around quite a bit online, but a word of mouth recommendation would be worth a lot more to me. Edit: Also, I could use a machine shop rec, too, if you don't mind. Quote Link to comment
Camtron Posted August 1, 2013 Report Share Posted August 1, 2013 I wanna stop in that Chef Store every time I drive by and then I forget about it. Someday man... someday. Quote Link to comment
ComicArtist Posted August 1, 2013 Author Report Share Posted August 1, 2013 A buddy of mine just had his valve covers and intake manifold for his RB25 powdercoated at a shop here, can't remember the name but I'll probably go there, he said it was only $75 for his parts. For machining I used Wrights Welding and Machine on NE 10th. Guys up there were super cool about getting me exactly what I needed 1 Quote Link to comment
Mannyvig Posted August 1, 2013 Report Share Posted August 1, 2013 Holy crap, I paid $75 for an l series valve cover, and it was already prepped and blasted. Never going back to my shop, beside the fact that it took three weeks. Quote Link to comment
ComicArtist Posted August 26, 2013 Author Report Share Posted August 26, 2013 Well, Doug is finishing up my spindles today and they'll be going to the powdercoater tomorrow. Since I'm getting close to reassembly, I figured I needed to find out what I was going to do about camber plates. I'm re-using the Techno Toy Tuning plates up front, doing something different for the rear. So since Z32's don't have camber plates, I have to somehow make this tophat fit this camber plate: After some cutting, grinding, drilling and tapping, I came up with a rough version of a camber plate/tophat, which looked like this: Looked entirely janky and not at all what I wanted. So then I was like, maybe I can make the Techno Toy Tuning tophats fit the Z32 coils? Basically, this nut holds the tophat onto the coilover. The round smooth part at the bottom is what fits inside the pillowball bearing, perfectly clearanced to allow full motion of the tophat. Spherical pillowballs are important, especially since I'm low and the way my suspension is designed. Unfortunately, PBM's pillowball bearings are bigger than Techno Toy Tunings, so the nut from my coilover wouldn't fit into the T3 tophat. I was debating shaving it down, but then I remembered I had a pair of nuts from when I originally bought the T3 camber plate kit for S30 shocks. Dug them out of the drawer and discovered they had the EXACT same thread pitch as the Z32 coils, and were perfectly clearanced to fit into the T3 bearing, so using that nut, the Techno Toy Tuning camber plate/tophat assembly fits perfectly onto the PBM Z32 coilover. Pillowball works perfectly, everything is clearanced perfectly, so nothing is loose, and I'll have full camber adjustment in the front. For the rear, I'm having new plates made to weld in, the tophat of the coilover will bolt up just like in an s13. Camber, caster, and toe will be adjusted with the Techno Toy Tuning LCA's. 1 Quote Link to comment
ComicArtist Posted August 27, 2013 Author Report Share Posted August 27, 2013 Just picked up the front spindles, welds look awesome. Very happy with the way everything's turning out. Had to end up migging them, in order to tig the cast Doug would've had to heat them up to like 3000* and that wasn't happening. Even with the mig they had to be heated up to like 325*. Either way, I have no fear of these ever breaking. Did a little coilover mockup, super excited about the way it's all lining up. Closeup of the welds 2 Quote Link to comment
ComicArtist Posted August 30, 2013 Author Report Share Posted August 30, 2013 Got the rear spindles back last night, don't have any pics of them. Nothing too impressive, going to try to get the spindle pins out tonight : / any tips on removing them? I imagine it'll be a bitch. Got the rear weld in plates back from the machine shop yesterday, test fitted them on the coils and they fit perfectly. I'm going to go ahead and clean up the top of the strut towers so the plates will fit better and tack them in place, my welder buddy is going to come over and weld them in with his mobile setup for me. Also got some rear brake rotors, ordered calipers the other day so all I'm waiting on is powdercoating and a little more welding. Quote Link to comment
ComicArtist Posted September 6, 2013 Author Report Share Posted September 6, 2013 In case anybody's still interested, here's an update. Had to get my mind off this so I finished up the 5 lug on this hunk. My rear brake calipers came in the mail today, so I started mocking up the rear discs to see how everything was going to line up. So far it looks good. Just have to weld in the camber plates and strut tower tops now, and have the spindles powdercoated and everything will be all done. I get paid tomorrow, so we'll see how much I have leftover after tuition and bills and I may make some more progress. I started taking classes at OCCC again this semester to finish up my degree and I haven't had a whole lot of time to do anything. Coils just waiting to be put on. Quote Link to comment
erichwaslike Posted September 6, 2013 Report Share Posted September 6, 2013 Bought a bike for a summer daily/fun vehicle while I rebuild the suspension on the s30. Needs tires, and the tags brought up to date but it runs and drives GREAT and I got a good deal on it. First thing I'll do is paint it and put a solo seat on it so it looks like this you should see my neighbors. he is almost done with it. hes changes the seat up a bit and we did a hard tail on it, but this has the basic idea. Quote Link to comment
ComicArtist Posted September 6, 2013 Author Report Share Posted September 6, 2013 That's whats up! I like that a lot Quote Link to comment
sedition88 Posted September 6, 2013 Report Share Posted September 6, 2013 Why 5 lug on the 240? Quote Link to comment
72240z Posted September 6, 2013 Report Share Posted September 6, 2013 More wheel options... well thats why most do anyway. Quote Link to comment
Rhapakatui Posted September 6, 2013 Report Share Posted September 6, 2013 you should see my neighbors. he is almost done with it. hes changes the seat up a bit and we did a hard tail on it, but this has the basic idea. Good looking bike. I don't know why he went to a hardtail though. Makes me wish my wife would let me have one. I guess that's why I have 9 cars ATM. If I can't have a bike, I'll just get every car. Quote Link to comment
ComicArtist Posted September 10, 2013 Author Report Share Posted September 10, 2013 I'm gonna paint the engine bay in this thing since I'm too broke to do anything to the suspension right now. Had a bachelor party last weekend and spent all my money on Dallas strippers, so it'll be sitting until my next paycheck. Then I got really drunk at the wedding and took pictures with everybody I'm also really drunk right now 2 Quote Link to comment
ComicArtist Posted September 19, 2013 Author Report Share Posted September 19, 2013 Doug came over and welded in my camber plates. Quote Link to comment
ComicArtist Posted September 19, 2013 Author Report Share Posted September 19, 2013 Started smoothing the welds on the camber plates, looking awesome. Also put on this BRE style wing, was going to paint it but got tired of sanding halfway through it and just put it on. Quote Link to comment
ComicArtist Posted September 25, 2013 Author Report Share Posted September 25, 2013 Coils are on. By this weekend, the brakes, wheel bearings, tranny mount bushings, and everything else should be wrapped up and I can drive it. Quote Link to comment
Spoona_Jay21 Posted September 25, 2013 Report Share Posted September 25, 2013 great work man! Just an Idea, a set of 15x8 Centerline Convo Pro's in Matte black would look EPIC! Quote Link to comment
ComicArtist Posted September 25, 2013 Author Report Share Posted September 25, 2013 Thanks! Wanting to go wider than that, at least 10's. I'd really like to find 11's for the rear Quote Link to comment
Spoona_Jay21 Posted September 25, 2013 Report Share Posted September 25, 2013 At Jegs.com you can get Centerline Convo pro's brand new, 15"x10" 5x4-1/2 (5x144.3) for 265.99Per wheel, with free shipping. i know it is a bit steep but as said, just an idea, and a nudge :devil: Quote Link to comment
ComicArtist Posted September 29, 2013 Author Report Share Posted September 29, 2013 Well, finished this up today and am driving it. I actually ran into no problems with the brake swap, which I wasn't expecting. Brakes feel awesome, the 4 pistons up front and discs in the rear feel great. Only thing I haven't hooked up is the e brake, I'll have to fab a bracket for the cables to attach to the calipers. Whole completed assembly in the back. You can see the big calipers peeking out in the front haha 1 Quote Link to comment
