conversion and rebuild
Hello my name is adrian and my older brother gave me his 72 orange wagon. It has a automatic with a L16 single weber. So my project is to convert it to manual with a L18 and jdm 219 head with SU's. Already did some work to it. started 2 mouths ago.
Here is whts been done with it.
  • Replies 29
Here's the rest of his work on his wagon.
L18 Motor
Cleaned out
.50 over Pistons
Polished Crank
Front end build up
Man hours: ???
Build Cost: minimum $1k
Motor, paint, sand paper..............
Current status: Not running
Motor is still apart
More updates to come
nice wagon! but if i may make a suggestion? two words. load leveller. makes engine swaps a touch easier. i helped swap a motor on a 91 cressida and my leveler cut about 2 hours off the install time since we could adjsut the angles while it was going in.
Very nice ride you got there, nice brother too. In your first few pics, what kind of ignition coil is that? Is is a later model nissan coil? Got any specs? Wondering if the use of a later model coil could clean up the original coil/ballast resistor area.
Jason
  • 4 weeks later...
