PtheDude Posted February 1, 2008 Report Share Posted February 1, 2008 http://seattle.craigslist.org/sno/car/559627754.html Quote Link to comment
datsunaholic Posted February 1, 2008 Report Share Posted February 1, 2008 That has to be an old Boeing truck. They had hundreds of 620s in the 70s and 80s and most, if not all, were Propane for running inside the plant buildings. I have a propane carb and manifold set, but I didn't get the propane head that went with it because the guy wanted too much for the head. Quote Link to comment
Rusty Posted February 1, 2008 Report Share Posted February 1, 2008 :eek: thats trippy? :confused: Quote Link to comment
hang_510 Posted February 1, 2008 Report Share Posted February 1, 2008 icehouse needs that to drive around and fix all the 'under the tree' datsuns :D Quote Link to comment
DatDoug Posted February 1, 2008 Report Share Posted February 1, 2008 I remeber I had a little 68 Datsun 520 back in 2001. I forgot about that little truck. I saw it @ a jobsite in South Seattle with a 4-sale sign. It was too cool looking and I asked the neighbor whos it was. It was his and I bot a battery and drove it home for $100 (no brakes:eek:) He told me it was an old Boeing truck. It had a serial # under the hood. Your mention of Boeing just reminded me of that.:rolleyes: Quote Link to comment
]2eDeYe Posted February 2, 2008 Report Share Posted February 2, 2008 Cool, the trucks the drive around now are little d50's and mitsubishi's Quote Link to comment
datsunfish Posted February 2, 2008 Report Share Posted February 2, 2008 Out of curiosity,what would be different in the head to make it run on propane? Quote Link to comment
Icehouse Posted February 2, 2008 Report Share Posted February 2, 2008 icehouse needs that to drive around and fix all the 'under the tree' datsuns :D One by one we will save them all :D The biggest problem with propane is it has even lower BTU's than gas..... 98,000 if I remember correctly. hhhmmmm I will have to figure out what it ends up being per mile compared to gas Quote Link to comment
datzenmike Posted February 2, 2008 Report Share Posted February 2, 2008 One by one we will save them all :D The biggest problem with propane is it has even lower BTU's than gas..... 98,000 if I remember correctly. hhhmmmm I will have to figure out what it ends up being per mile compared to gas True but propane has an octane rating of 104, so it would be sensible to extract as much power as you can by raising the compression ratio. This narrows the gap between gas and propane quite a bit. Cleaner burn, less emissions, longer between oil changes, cleaner motors. Quote Link to comment
shane_lxi Posted February 2, 2008 Report Share Posted February 2, 2008 I saw that earlier today looking for 521 stuff. I was trying to think of a reason/excuse to buy it, but I didnt have one. It's cool though! There's a diesel 720 up right now too, kinda beat but still cool. Quote Link to comment
gen4maxima536 Posted February 2, 2008 Report Share Posted February 2, 2008 there is a 620 at the old jims auto wrecking in poulsbo. at least i think it was at one point, all the stuff for it had been stripped out of the engine bay by the time i saw it Quote Link to comment
e_racer1999 Posted February 2, 2008 Report Share Posted February 2, 2008 i see the topic of compression has been discussed :) i had been considering modifying an L-series to run on LPG or CNG, but hadn't done much research. the folks at hybridz.org had a few links in one thread... anyway, a turbo + 10:1 compression, anyone? >:) Quote Link to comment
datzenmike Posted February 2, 2008 Report Share Posted February 2, 2008 Duh, duh, duh, duh.......Duh! If you wanna hang out you've got to take her out, propane If you wanna get down, down on the ground, propane She don't lie, she don't lie, she don't lie..... Propane!! Duh, duh, duh, duh.......Duh! (sorry, eric) Quote Link to comment
spiffinspudater Posted February 3, 2008 Report Share Posted February 3, 2008 Are the propane slower than regular gas? Quote Link to comment
e_racer1999 Posted February 3, 2008 Report Share Posted February 3, 2008 ^inherently, yes. as was mentioned fewer BTUs than petrol. but the thing is that most current/prior propane powered cars are only LIGHTLY modified to run LPG, ie small carb/fi replacements, no modification done to raise compression. Quote Link to comment
